I have two Mikrotiks, both running RouterOS 6.32.2. They both have a public IPv4 address, a private IPv4-net, a public IPv6 address and a public IPv6 net:
MikroTik1:
Public IPv4: 88.91.209.xxx - Private LAN: 192.168.10.1/24
Public IPv6 2001:14b8:100:xxxx::2 - LAN: 2001:14b8:xxxx::/64
MikroTik2:
Public IPv4: 85.166.75.xxx - Private LAN: 192.168.20.1/24
Public IPv6 2001:16d8:ee00:xxxx::2 - LAN: 2001:16d8:ee00:yyyy::/64
First I configured IPSec for IPv4, using this guide. It worked perfectly, I just had to add a firewall rule stating that ipsec-esp packets were allowed.
Then I used the same guide to configure IPSec for IPv6, but that did not work. I get an error-message stating: Failed to pre-process ph2 packet
My setup on Mikrotik1:
/ip ipsec peer print
Flags: X - disabled, D - dynamic
0 address=85.166.75.xxx/32 local-address=0.0.0.0 passive=no port=500 auth-method=pre-shared-key
secret="xxxxx" generate-policy=no policy-template-group=group1 exchange-mode=main
send-initial-contact=yes nat-traversal=yes proposal-check=obey hash-algorithm=sha1
enc-algorithm=aes-128 dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=2m
dpd-maximum-failures=5
1 address=2001:16d8:ee00:xxxx::2/128 local-address=0.0.0.0 passive=no port=500 auth-method=pre-shared-key
secret="yyyyy" generate-policy=no policy-template-group=group1 exchange-mode=main
send-initial-contact=yes nat-traversal=no proposal-check=obey hash-algorithm=sha1
/ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - inactive, * - default
0 T * group=group1 src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
1 src-address=192.168.10.0/24 src-port=any dst-address=192.168.20.0/24 dst-port=any protocol=all
action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=88.91.209.xxx
sa-dst-address=85.166.75.xxx proposal=default priority=0
2 src-address=2001:14d8:xxxx::/64 src-port=any dst-address=2001:16d8:ee00:yyyy::/64 dst-port=any
protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes
sa-src-address= 2001:14b8:100:xxxx::2 sa-dst-address=2001:16d8:ee00:xxxx::2 proposal=default priority=0
My setup on Mikrotik2:
0 address=88.91.209.xxx/32 local-address=0.0.0.0 passive=no port=500 auth-method=pre-shared-key
1 address=2001:14b8:100:xxxx::2/128 local-address=0.0.0.0 passive=no port=500 auth-method=pre-shared-key
0 T * group=group1 src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all proposal=default template=yes
1 src-address=192.168.20.0/24 src-port=any dst-address=192.168.10.0/24 dst-port=any protocol=all
action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=85.166.75.xxx
sa-dst-address=88.91.209.xxx proposal=default priority=0
2 src-address=2001:16d8:ee00:yyyy::/64 src-port=any dst-address=2001:14b8:xxxx::/64 dst-port=any
sa-src-address=2001:16d8:ee00:xxxx::2 sa-dst-address=2001:14b8:100:xxxx::2 proposal=ipv6 priority=0
I have tried to only enable IPSec for IPv6, disabling IPSec over IPv4. Did not work.
I have also tried to turn off the firewalls, that didn’t help either.
Since all IPv6 adresses are unicast, I am able to ping from 2001:16d8:ee00:yyyy::/64 to 2001:14b8:xxxx::/64 when IPSec is not running, but those packages are not encrypted. I want everything sent between my IPv6 subnets to be encrypted (since they are traversing the big bad Internet
Does anyone know what might be the problem?
