IPSEC Peer Identifier
Hi All
I will try to migrate Firewall PFsense for Mikrotik Router. I have a lot of
IPSEC connection and I discover in mikrotik is not possible setup peer identifier ( FQND , peer Ip address , Ip address , Distinguished named ..etc.)
Is possible configured only in My peer ID.
Is possible configure from CLI ? or other command to scape this part of IPEC?
“My peer ID” is the peer identifier that you are sending to remote peer. So where exactly is the problem?
Hi ,
I have clients which they Identify Peer with other parameters like FQND or local IP address , no using Ipsec gateway IP.
