IPSec Peer Portentry 500 goes to 62465
Hello all,
i have a problem when setting up a ipsec connection between 2 Mikrotik CCR1016-12Gs.
When i put in the standard port 500 into the peers setup the system makes a port entry of 62465, as i can see in ipsec/debug log. When i change the port-entry into 0, the port 500 will be used from the system. Am i wrong or the routeros 6.1 ?
Is this a known bug/problem?
Same problem here.
And in addition, I cannot stablish 2 IPSec tunnels with two different peers.
I have to disable a peer to get the tunnel stablished with the other one.
Regards,
…and here!
2 or more ipsec peer not work same time!
This is only ROS6 bug?
This work on ROS5 ?
Hy!
The 6.2 upgrade solved the problem!
Yes!
It works now with ROS 6.2
Thanks!
It’s a pity, but IPSec tunnels do not work fine when you have several policies with different peers.
I can establish the tunnels, but the traffic of one peer makes the other peers going down…
This is not working well yet.
I have to keep my old linux box doing these connections…
