Wanted to know if RouterOS 3.22 support Peer to Peer IPSec tunnel ?
I am trying to established a tunnel using MK on one side, the other side would be Nortel VPN Router.
Unfortunately, the session can only last once and is initiated from Nortel VPN. MK has no options for me to set as a initiator IPSec.
Oh I have solve it myself.
Nortel VPN and other enterprise VPN routers has too much features and parameters which are missing in MR.
I have since fine tune the ISKAMP proposal interval and retry attempts in Nortel but which is missing in MR.
And also reduce the idle timeout before a new SA is generated.
This has solved somehow. But i really look forward to more IPSec parameters added inside winbox. Or is it available in CLI ?
