IPSec - phase1 negotiation failed due to time up
In a highly simplified form, the network diagram looks like this:
All routers have their own local networks. “Main” routers have 3 Internet connections. All routers build 2 VPN connections for redundancy. The third Internet connections of the “main” routers perform separate functions and are not used in this scheme.
CCR1016-12G are used as “main” routers.
4011, hAP ac2, hAP ac3 are used as “client” routers.
All routers have the following settings:
/ip ipsec profile set [ find default=yes ] enc-algorithm=aes-256,aes-128 lifetime=1h
/ip ipsec proposal set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-128-cbc,aes-128-ctr lifetime=1h
New keys are exchanged periodically. Sometimes this does not happen the first time and the following errors appear in the logs:
phase1 negotiation failed due to time up ...
Question: perhaps it is necessary to somehow change the time parameters? Or something else?
Log it, even better sniff it in parallel to logging, at both ends, to see what is actually going on. Looks like some packet loss, but it may theoretically be related to some firewall issues too. If Starlink or a crowded LTE cell is involved, there may be outages long enough to make the negotiation fail.
