ipsec: pre shared key works, while certificates do not?
I apologize for probably another dummy question… I’m stuck again..
I have a remote site connected to the Internet via provider’s NAT. I would like to establish an IPsec between that site and the main location. Main site has a fixed real IP. On the main site I did setup a policy to accept IPsec connections from 0.0.0.0/0. When I set Auth method to pre-shared key, the link works. But if I set it to rsa signature, connection fails with an error:
phase1 negotiation failed due to time up <remote_router_IP_behind_NAT> <==> <main_site_router_IP>
In order to be sure the certificates themselves are Ok, I tested the same configuration (and the same certificates) with a test router connected to the same ISP as the main one (so that there’s no NAT between the routers). The IPsec link established right away…
May it be that some ports are blocked at provider’s NAT so that it doesn’t let certificate-based connection to be established (but, at the same time, allows the pre-shared key)?
Experimenting further with this… Legend:
site_A - main site (acts as a server, accepting connections from 0.0.0.0/0)
site_B - the remote site I have a problem with
site_C - the test router (I configured it in the same way as site_B, but for some reason this site connects to site_A without any issues)
I’m trying to analyze and compare IPsec logs from site_B (not working) and site_C (working fine).
Both logs start with the same messages regarding certificates, computing DH, CERT payload, etc. They go about the same up until a point when “working router” (site_C) shows this:
May 13 18:16:31 10.10.3.1 ipsec,debug encryption(aes)
May 13 18:16:31 10.10.3.1 ipsec,debug with key:
May 13 18:16:31 10.10.3.1 ipsec,debug 39ac2d6f 81c86cfe 61e9f4f6 0594d280
May 13 18:16:31 10.10.3.1 ipsec,debug encrypted payload by IV:
May 13 18:16:31 10.10.3.1 ipsec,debug a7bc82de be675f36 5c4e1f7d 032083ff
May 13 18:16:31 10.10.3.1 ipsec,debug save IV for next:
May 13 18:16:31 10.10.3.1 ipsec,debug 438abaa7 ebcebe2d 6254f02c c41838c6
May 13 18:16:31 10.10.3.1 ipsec,debug encrypted.
May 13 18:16:31 10.10.3.1 ipsec,debug 1660 bytes from <site_C_IP>[500] to <site_A_IP>[500]
May 13 18:16:31 10.10.3.1 ipsec,debug 1 times of 1660 bytes message will be sent to <site_A_IP>[500]
and a “problem router” (site_B) shows this:
May 13 18:04:51 10.10.2.1 ipsec,debug encryption(aes)
May 13 18:04:51 10.10.2.1 ipsec,debug with key:
May 13 18:04:51 10.10.2.1 ipsec,debug f8d5b610 eb55b7d5 0a586406 1f43c305
May 13 18:04:51 10.10.2.1 ipsec,debug encrypted payload by IV:
May 13 18:04:51 10.10.2.1 ipsec,debug a8d1eb68 c34e9d7a 70ff007e ad8b23df
May 13 18:04:51 10.10.2.1 ipsec,debug save IV for next:
May 13 18:04:51 10.10.2.1 ipsec,debug 18cbd0db 7f56f37b 2578e900 74aceac8
May 13 18:04:51 10.10.2.1 ipsec,debug encrypted.
May 13 18:04:51 10.10.2.1 ipsec,debug Adding NON-ESP marker
May 13 18:04:51 10.10.2.1 ipsec,debug 1664 bytes from <site_B_IP>[4500] to <site_A_IP>[4500]
May 13 18:04:51 10.10.2.1 ipsec,debug 1 times of 1664 bytes message will be sent to <site_A_IP>[4500]
Mind the “Adding NON-ESP marker” message and the port suddenly changed to 4500 (instead of 500).
Then site_B router also says it gets a retransmitted packet from site_A:
May 13 18:05:00 10.10.2.1 ipsec,info the packet is retransmitted by <site_A_IP>[500].
May 13 18:05:00 10.10.2.1 ipsec,debug KA: <site_B_IP>[4500]-><site_A_IP>[4500]
That’s where it basically times out, as it sends the same packet again and again on port 4500, and site_A router keeps retransmitting its request.
As far as I can tell, configuration of site_B and site_C is absolutely the same.
What am I missing? Why does site_B shows this “Adding NON-ESP marker” message and then sends something on port 4500, when site_C router continues to use port 500 (and then succeeds establishing the connection)?
Update:
The “NON-ESP marker” and a switch to port 4500 seem to be related to the NAT Traversal.setting (although NAT Traversal is switched on on both site_B and site_C routers).
Still, I have no clue why site_B router cannot connect, while site_C router connects and works with site_A just fine… :frowning:
And another update… Analyzing the logs of site_A, looks like it doesn’t receive that 1660 bytes packet from site_B. :frowning:
Not sure what I can do about it.
Any ideas are greatly appreciated!
Same here, looks like L2TP/IPSec RSA not working with NAT-T
All 3 sites are running RouterOS? Are latest versions installed on all routers? If so, please enable IPsec debug logs (/system logging add topics=ipsec) and generate supout.rif file on all routers after each connection attempt.
On a second thought, you should sniff packets between sites A and B. The issue is with fragmentation, and it appears that site B does not fragment or forward fragmented packets correctly. You can also test certificates with smaller key size to eliminate fragmentation.
