I tried to setup an IPSec connection for the first time but I haven’t got a default Proposal. If I click + and set the options and click OK nothing happens…I tried to create it from terminal, but when I hit the enter it seems it freezed because the cursor doesn come back until I hit ctrl+c. I followed a tutorial video and set everything what was set in the video, but he just modify the default proposal click ok and contiunues the video. But I cannot create nor the Proposal nor the Peer or policies… What am I doing wrong?
Thanks for your fast reply!
I’m using version 6.15. The men who sold it said it’s a stable version. I upgraded it to version 6.24 but in that version the 3G connection didn’t work. So now I try to use PPTP connection instead of IPsec. Is there a way to fix the IPsec module? Or if it’s locked can I unlock it somehow?
I tried 6.24 but the 3G communication didn’t worked. By the way I made an upgrade to 4.17 but after its automatic restart it only beep once wich means the system started, but the two beap doesn’t happens. So the config didn’t load. I cannot log in via winbox nor with MAC nor with IP. Is there some other way to fix the system? The netinstall doesn’t see it.
