IPsec problem
Hi there,
I’ve done a network working with a zyxel usg40 and a Mikrotik using IPSec protocol.
The connection works fine but if one of these router close connection the VPN goes down.
I need a feature that restore IPsec connection when I ping the remote host.
How i can fix this problem?
Thanks in advice,
Sorry for my poor english.
Federico.
Properly configured IPSec tunnel automatically brings up when traffic defined in IPSec policies is detected.
I’ve got IPSec tunnels between MikroTik and ZyXEL USG 300 and works fine.
Check your config on both sides.
Regards,
Thanks,
When the router try to brings up the traffic logs says “No proposal chosen”.
But manually goes fine.
Can you give me some advices for fix my configuration?
