IPsec problem
Hi - I’m having trouble getting two routerboards talking to each other over an IPsec encrypted connection.
The first board has an address of 10.50.3.131/25, and the second has 10.50.2.6/30. They’re connected through a Linux PC acting as a router, with addresses of 10.50.3.129/25 and 10.50.2.5/30. Without IPsec policies in place, they can communicate with each other, so I know the routing is working.
I’ve configured IPsec on each machine like so:
 /ip ipsec proposal
add auth-algorithms=md5 disabled=no enc-algorithms=aes-128 lifetime=30m \
    name="default" pfs-group=modp1024
/ip ipsec peer
add address=10.50.2.6/32:500 auth-method=pre-shared-key dh-group=modp1024 \
    disabled=no enc-algorithm=aes-128 exchange-mode=main generate-policy=no \
    hash-algorithm=md5 lifebytes=0 lifetime=1d nat-traversal=no \
    proposal-check=obey secret="abc" send-initial-contact=yes
/ip ipsec policy
add action=encrypt disabled=no dst-address=10.50.2.6/32:any ipsec-protocols=esp \
    level=require manual-sa=none priority=0 proposal=default protocol=all \
    sa-dst-address=10.50.2.6 sa-src-address=10.50.3.131 \
    src-address=10.50.3.131/32:any tunnel=no
/ip ipsec proposal
/ip ipsec peer
add address=10.50.3.131/32:500 auth-method=pre-shared-key dh-group=modp1024 \
/ip ipsec policy
add action=encrypt disabled=no dst-address=10.50.3.131/32:any \
    ipsec-protocols=esp level=require manual-sa=none priority=0 proposal=default \
    protocol=all sa-dst-address=10.50.3.131 sa-src-address=10.50.2.6 \
    src-address=10.50.2.6/32:any tunnel=no
I’m dumping the traffic on the Linux router, and there isn’t even any ISAKMP attempt being made in either direction.
Any idea what I’m doing wrong?
Edit: RouterOS is 3.2 on both boards. The first is an RB150, the second is an RB600.
No traffic is matching the IPSEC policy. You need to specify your internal LAN addresses on each end.
Regards
Andrew
Upgraded both routers to 3.3, and it’s working perfectly. Strange, I don’t see anything relevant in the changelog for 3.3/
I think, when MT writes changelog, they think about some changes: ‘Let it be a little surprise’ =)
