IPSEC problem
hey all,
first of all i never do this before. I want to create ipsec tunnel with mikrotik and cisco. Here is my network and configuration ;
Location 1
WAN IP : 4.4.4.4
NAT : 172.24.60.20
Local : 10.60.0.0 /21
Location 2
Wan IP : 5.5.5.5
Nat : 192.168.1.254 ( mikrotik )
Local : 192.168.100.0/24
Location 1 configuration (cisco),
IKE Session ( Faz 1 )
Encryption Algorithm AES-128
Hashing Algorithm MD5/HMAC-128
Diffie-Hellman Group Group 2 (1024-bit)
Authentication Mode Pre-Shared Keys
IKE Negotiation Mode Main
Rekey Time Interval 86400 seconds
IPSec Session ( Faz 2 )
Hashing Algorithm ESP/MD5/HMAC-128
Encapsulation Mode Tunnel
Rekey Time Interval 28800 seconds
Location 2 (Mikrotik 4.5 ) ,
Policy
Flags: X - disabled, D - dynamic, I - inactive
0 src-address=192.168.100.0/24:any dst-address=10.60.0.0/21:any protocol=all
action=encrypt level=require ipsec-protocols=esp tunnel=yes
sa-src-address=192.168.1.254 sa-dst-address=4.4.4.4 proposal=default
priority=0
Peer
0 address=4.4.4.4/32:500 auth-method=pre-shared-key
secret=“XXXXX” generate-policy=no exchange-mode=main
send-initial-contact=yes nat-traversal=no proposal-check=obey
hash-algorithm=md5 enc-algorithm=aes-128 dh-group=modp1024 lifetime=1d
lifebytes=0 dpd-interval=disable-dpd dpd-maximum-failures=1
Proposal
0 name=“default” auth-algorithms=md5 enc-algorithms=aes-128 lifetime=8h
pfs-group=modp1024
I cant see any remote peers and installed SAs
Anyone Help me about this configuration?
Set the sa-src-address to the public IPs.
You also need to NAT exempt traffic between the internal networks on both sides.
new policy
sa-src-address=5.5.5.5 sa-dst-address=4.4.4.4
Nat
0 chain=srcnat action=accept src-address=192.168.100.0/24
1 chain=srcnat action=masquerade
No changes… :frowning:
First, you have to EXEMPT the traffic from NAT.
add chain=srcnat src-address=192.168.100.0/24 dst-address=10.60.0.0/21 action=accept
Equivalent configuration is necessary on the Cisco, how to do that depends on how you NAT there.
Also, it’s a bad idea to blindly masquerade, you should at least qualify with ‘out-interface=WAN-interface-name’.
Now that you’ve changed SA source and destination IP addresses, do you see remote peers and policies being established? What do the logs say when you turn on debugging?
here is the new nat rule..
 1   chain=srcnat action=masquerade out-interface=ether1
and nothing change :frowning:
and i cant see any ipsec on log.. :confused:
/system logging
add topic=ipsec action=echo
Then ping from the CLI, it’ll output a bunch of debugging text. Post it.
i already add ipsec and debug :frowning: but there is no log..
i think ipsec session didnt start..
any idea?
If you want to trigger the tunnel from the box itself, you need to add a route, read http://forum.mikrotik.com/t/program-led-to-vpn-status-using-netwatch-and-scripting/31786/1
