IPSEC ROAD WARRIOR Site-to-Site with mode configs - no ping from client to server side
Hello! I made all configs following this howto https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#RoadWarrior_client_with_NAT
SERVER SIDE LAN 192.168.1.0/24
CLIENT SIDE LAN 192.168.10.0/24
ROAD WARRIOR POOL 192.168.254.0/24
Tunnel is up, pings from PC behind the MKT on client side to PC behind the MKT on server side is OK.
BUT i spent almost 100 sleepless hours to make pings from PC behind the MKT on server side to PC behind the MKT on client side running.
The only IP on remote side responding to pings is IP from road warrior pool.
I supopse that something in FIREWALL/NAT config is missing, but actually all rules absolutely identical (mirrored where needed) on both sides.
Could somebody pleare help me? Cant wait to go to sleep, but cant go to sleep untill i’ll make it running properly.
Thanks in advance.
Could you post your configs for both ends ? /export hide-sensitive compact
