IPSEC RoadWarrior tunnel between Mikrotik and Shrewsoft client
I’m trying to set up a Road Warrior VPN between a mikrotik and a ShrewSoft Client using to the following tutorial :
https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Road_Warrior_setup_with_Mode_Conf#Road_Warrior_setup_with_Mode_Conf
Unfortunately, I’m struggling quite a lot.
Both MT and client are behiend a nat with required ports open
Phase 1 seems to work fine but MT returns an error on phase 2 : failed to pre-process ph2 packet. Here is the log from MT
20:06:01 ipsec,info respond new phase 1 (Identity Protection): 192.168.66.2[500]<=>109.28.218.87[2780]
20:06:01 ipsec,info ISAKMP-SA established 192.168.66.2[4500]-109.28.218.87[4500] spi:ad1c03118f9b3789:84bd4cf33e419a5a
20:06:02 ipsec,info XAuth login succeeded for user: franek
20:06:02 ipsec,info acquired 192.168.11.16 address for 109.28.218.87[4500]
20:06:03 ipsec,error 109.28.218.87 failed to pre-process ph2 packet.
20:06:08 ipsec,error 109.28.218.87 peer sent packet for dead phase2
20:06:10 ipsec,error 109.28.218.87 failed to pre-process ph2 packet.
20:06:13 ipsec,error 109.28.218.87 peer sent packet for dead phase2
20:06:15 ipsec,error 109.28.218.87 peer sent packet for dead phase2
20:06:18 ipsec,error 109.28.218.87 peer sent packet for dead phase2
20:06:20 ipsec,error 109.28.218.87 peer sent packet for dead phase2
20:06:25 ipsec,error 109.28.218.87 peer sent packet for dead phase2
20:06:30 ipsec,error 109.28.218.87 failed to pre-process ph2 packet.
The funny part is that for the Shrew client, the tunnel is established and working so it keeps sending packets that are ignored by MT.
attached to key daemon ...
peer configured
iskamp proposal configured
esp proposal configured
client configured
local id configured
remote id configured
pre-shared key configured
bringing up tunnel ...
network device configured
tunnel enabled
Here is my config. On the MT :
# model = 2011UiAS
/ip ipsec peer profile
set [ find default=yes ] dpd-interval=disable-dpd
add dh-group=modp768 dpd-interval=disable-dpd enc-algorithm=aes-256 lifetime=8h name=profile1
/ip ipsec policy group
add name=RoadWarrior
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1,md5 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-cbc,aes-128-cbc,3des lifetime=5m pfs-group=none
add name=dhcp_pool_LAN_guerin ranges=192.168.10.10-192.168.10.20
add name=ipsec-RW ranges=192.168.11.2-192.168.11.20
/ip ipsec mode-config
add address-pool=ipsec-RW name=RW-cfg split-include=192.168.10.0/24
add address=192.168.10.1/24 interface="bridge LAN Guerin" network=192.168.10.0
add action=accept chain=forward dst-address=192.168.10.0/24 src-address=192.168.11.0/24
add action=accept chain=forward dst-address=192.168.11.0/24 src-address=192.168.10.0/24
add action=accept chain=input comment=temp src-address=109.28.218.87
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input protocol=ipsec-ah
add action=accept chain=input dst-port=500,4500 protocol=udp
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=input
add action=accept chain=srcnat dst-address=192.168.10.0/24 src-address=192.168.11.0/24
/ip ipsec peer
add address=0.0.0.0/0 auth-method=pre-shared-key-xauth generate-policy=port-strict mode-config=RW-cfg passive=yes policy-template-group=RoadWarrior secret=******
/ip ipsec policy
add dst-address=192.168.11.0/24 group=RoadWarrior src-address=192.168.10.0/24 template=yes
/ip ipsec user
add name=****** password=******
On the Shrewsoft VPN client :
n:version:4
n:network-ike-port:500
n:network-mtu-size:1380
n:client-addr-auto:1
n:network-natt-port:4500
n:network-natt-rate:15
n:network-frag-size:540
n:network-dpd-enable:0
n:client-banner-enable:0
n:network-notify-enable:1
n:client-dns-used:1
n:client-dns-auto:1
n:client-dns-suffix-auto:1
n:client-splitdns-used:1
n:client-splitdns-auto:1
n:client-wins-used:1
n:client-wins-auto:1
n:phase1-dhgroup:2
n:phase1-life-secs:86400
n:phase1-life-kbytes:0
n:vendor-chkpt-enable:0
n:phase2-life-secs:300
n:phase2-life-kbytes:0
n:policy-nailed:0
n:policy-list-auto:1
s:network-host:80.11.458.74
s:client-auto-mode:pull
s:client-iface:virtual
s:network-natt-mode:enable
s:network-frag-mode:enable
s:auth-method:mutual-psk-xauth
s:ident-client-type:address
s:ident-server-type:address
b:auth-mutual-psk:RXZpX2xlX0NoaWVu
s:phase1-exchange:main
s:phase1-cipher:3des
s:phase1-hash:sha1
s:phase2-transform:auto
s:phase2-hmac:auto
s:ipcomp-transform:disabled
n:phase2-pfsgroup:0
s:policy-level:auto
I’m certainly doing something wrong but I can’t find out what it is.
If someone would be so kind to help me out, that would be greatly appreciated
Franek
Hi
You have different settings on client and server..
For example..dh group=2 is modp1024
Also enable..ipsec logging to see what client Sends to MikroTik and vice versa
