IPsec RouterOS to ASA 5505
I’m having problems getting this IPsec connection setup. The SA never goes past larval stage. I’m just trying to setup a tunnel. First time I’ve ever tried doing this.
RouterOS Config (v3.14)
/ip ipsec policy> print
Flags: X - disabled, D - dynamic, I - inactive
0 src-address=192.168.30.0/24:any dst-address=192.168.20.0/24:any protocol=all action=encrypt
level=require ipsec-protocols=esp tunnel=yes sa-src-address=206.51.xxx.xxx
sa-dst-address=98.28.xxx.xxx proposal=default manual-sa=none priority=0
/ip ipsec proposal> print
Flags: X - disabled
0 name=“default” auth-algorithms=sha1 enc-algorithms=3des lifetime=8h pfs-group=modp1024
/ip ipsec peers> print
Flags: X - disabled
0 address=98.28.xxx.xxx/32:500 auth-method=pre-shared-key secret=“secret” generate-policy=no
exchange-mode=main send-initial-contact=yes nat-traversal=yes proposal-check=obey
hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=471859200
dpd-interval=20s dpd-maximum-failures=1
/ip firewall nat> print
0 chain=srcnat action=masquerade src-address=192.168.30.0/24 dst-address=192.168.20.0/24
out-interface=Wan
1 chain=srcnat action=masquerade out-interface=Wan
Cisco Config:
Result of the command: “wr t”
: Saved
ASA Version 7.2(4)
hostname Studio-ASA
domain-name default.domain.invalid
enable password iNu50VD6XGaWHVM6 encrypted
passwd iNu50VD6XGaWHVM6 encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.20.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
nameif dmz
security-level 50
ip address 192.168.90.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list nonat extended permit ip 192.168.20.0 255.255.255.0 192.168.30.0 255.255.255.0
access-list nonat extended permit ip 192.168.30.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.20.0 255.255.255.0 192.168.30.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool 123 192.168.20.60-192.168.20.80 mask 255.255.255.0
no failover
monitor-interface inside
monitor-interface outside
monitor-interface dmz
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 24.123.xxx.xxx 255.255.255.0 outside
http 12.37.xxx.xxx 255.255.255.0 outside
http 192.168.20.0 255.255.255.0 inside
http 206.51.xxx.xxx 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 206.51.xxx.xxx
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 1 set security-association lifetime kilobytes 5000
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
crypto isakmp ipsec-over-tcp port 500
telnet 192.168.20.0 255.255.255.0 inside
telnet timeout 5
ssh 12.37.xxx.xxx 255.255.255.0 outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.20.2-192.168.20.254 inside
ntp server 71.13.91.122 source outside prefer
username admin password usKBR9pR4f8aT7eY encrypted privilege 15
tunnel-group DefaultRAGroup general-attributes
address-pool 123
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication (outside) none
tunnel-group DefaultRAGroup ppp-attributes
authentication ms-chap-v2
tunnel-group default type ipsec-l2l
tunnel-group default ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:6bcf72e50f9ce6f33c311aaff76d635d
: end
[OK]
