IPsec s2s and src-nat :-/
Hello my follow tiks :slight_smile:
We have kind of a situation here…
i have
zabbix 172.30.5.190 with default gw mtik1
mtik 1:
ether2 - 172.30.5.1/24
and mtik 2:
 ether2 - 172.30.5.110/24
 ether3 - 172.24.255.1/24
and offsite
mtik 3:
ether2 - 172.24.60.1/24
mtik1 is default gw for zabbix and i added a route to it:
add distance=1 dst-address=172.24.0.0/16 gateway=172.30.5.110
mtik2 connects to mtik3 with IPsec IKEv2
Policies are 172.24.255.0/24 ↔ 172.24.60.0/24
now i want to monitor mtik 3 with zabbix
to accompish that i added a src-nat to mtik2
add action=src-nat chain=srcnat dst-address=172.24.0.0/16 src-address=172.30.5.190 to-addresses=172.24.255.1
on mtik3 i see incoming ICMP from zabbix with src-address 172.24.255.1 but i can not receive echo reply on zabbix
what am i missin ?
Cheers
Chris
anybody ?
How exactly do you “see” it? Using /tool sniffer or using some action=log or log=yes firewall rule?
I would suspect most a firewall rule in chain input of /ip firewall filter to drop the ICMP echo request packets. Packets decapsulated from IPsec transport ones inherit the in-interface attribute from the transport ones, so if you drop anything coming from WAN except connection-state=established,related, this could be the explanation.
If the above is not sufficient, post the complete configuration of mtik3, following the hint in my automatic signature below.
Thanks for answering sindy. i was away for vaccation but am back now :wink:
I will try to analyze what u said and keep u posted. thanks anyways,
Cheers, chris
