ipsec sa rekey - win 10 client
I had the problem that the ipsec sa rekeying prompted by the 100’000kb traffic rule from windows 10 client resulted in no proposal chosen and then loosing sa from client to server. Only when I set the pfs group to none under proposals, rekeying worked without any problem after every 100k kb.
I dont have this problem with android strongswan client, there it works with pfs set to modp1024 but I must admit that I did not analyze the rekeying behaviour there. It just worked for hours and lots of data volume.
Anybody some idea or hints, why? Maybe I have to customize win 10 ipsec defaults but I wanted to ask here first before I delve into powershell & co
I had to do this (adjusted for Windows 10) to connect to a Peplink. Might be some info in there for you.
Found the solution, had to set connection details using powershell
Set-VpnConnectionIPsecConfiguration -ConnectionName “Test” -AuthenticationTransformConstants SHA256128 -CipherTransformConstants AES256 -EncryptionMethod AES256 -IntegrityCheckMethod SHA256 -DHGroup Group14 -PfsGroup PFS2048 -PassThru -Force
Rekeying works fine now…
