Hello Experts!
I am trying to create ipsec site-to-site tunnel between Azure and Mikrotik Routerboard (ROS 6.38). VPN status in established, and i can connect to the server in Azure via RDP, but connection is not stable and in the logs on Mikrotik I see the errors:
peer sent packet for dead phase 2;
failed to pre-process ph2 packet.
But if i create ipsec site-to-site tunnel between two Mikrotiks, everything works fine. How to fix this issue? Thanks in advance.
Last week I’m having the same problem with Azure, with a tunnel that has been stable for a long time. For my part I have not made any changes to the configuration or ROS update (6.37.4), so I think it may be an Azure problem.
