Thanks for your replies.
Form Base to Site A ping ok
From Site A to Base ping ok
Form Base to Site B ping ok
From Site B to Base ping ok
From Site B to Site A ping don’t work and the networks can’t comnunicate.
I can do another ipsec tunnel directly from Site B to Site A to resolve the problem but i have many sites(10 sites in total like A and B) and is not a valid option .
To many configurations to add. ( A-B, A-C, B-C if i use only tree sites)
I need to route traffic from A to B directly from Base because all sites have a direct ipsec with the Base.
#########################################Base Configuration below
# nov/07/2019 08:20:40 by RouterOS 6.45.7
# software id = C8FI-D21V
# model = RB4011iGS+
# serial number = AAB10A53655E
add name=bridge
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full loop-protect=on mac-address=00:0C:42:56:98:66
set [ find default-name=ether7 ] loop-protect=on
set [ find default-name=ether10 ] loop-protect=on
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=Maxi name=WAN
add comment=Maxi name=LAN
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 dpd-interval=2s enc-algorithm=aes-256,3des
add dh-group=modp1024 dpd-interval=10s dpd-maximum-failures=2 enc-algorithm=aes-128 hash-algorithm=sha256 name=profile1
add dh-group=modp1024 dpd-interval=10s dpd-maximum-failures=2 enc-algorithm=3des hash-algorithm=sha256 name=L2TP_profile
/ip ipsec peer
add address=(hide ip site B) name=20th profile=profile1 send-initial-contact=no
add address=(hide ip site A) name=Ivasiuc profile=profile1 send-initial-contact=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1,md5 enc-algorithms=aes-256-cbc,aes-128-cbc,3des lifetime=1d
add auth-algorithms=sha1,md5 enc-algorithms=aes-256-cbc,aes-128-cbc,3des name=proposalBaza
add auth-algorithms=sha1,md5 enc-algorithms=aes-256-cbc,aes-128-cbc,3des name="L2TP Proposal"
add name=default-dhcp ranges=192.168.0.1-192.168.0.254
add name=VPN-L2TP ranges=10.10.10.10-10.10.10.254
add add-arp=yes address-pool=default-dhcp always-broadcast=yes authoritative=after-2sec-delay bootp-lease-time=lease-time bootp-support=dynamic disabled=no interface=bridge lease-time=2d1s name=Maxi
/ppp profile
set *0 dns-server=8.8.8.8 use-encryption=required
add bridge=bridge dns-server=8.8.8.8 local-address=10.10.10.1 name=VPN-L2TP remote-address=VPN-L2TP use-encryption=required
set *FFFFFFFE local-address=10.10.10.2 remote-address=default-dhcp
/system logging action
add email-start-tls=yes email-to=contact@maxi-marketus.ro name=email target=email
add bridge=bridge comment=Maxi interface=ether2
add bridge=bridge comment=Maxi interface=ether3
add bridge=bridge comment=Maxi interface=ether4
add bridge=bridge comment=Maxi interface=ether5
add bridge=bridge comment=Maxi interface=ether6
add bridge=bridge comment=Maxi interface=ether7
add bridge=bridge comment=Maxi interface=ether8
add bridge=bridge comment=Maxi interface=ether9
add bridge=bridge comment=Maxi interface=ether10
add bridge=bridge comment=Maxi interface=sfp-sfpplus1
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set allow-fast-path=yes default-profile=VPN-L2TP enabled=yes use-ipsec=required
add interface=ether1 list=WAN
add interface=bridge list=LAN
/interface ovpn-server server
set auth=sha1 cipher=aes256 default-profile=VPN-L2TP require-client-certificate=yes
add address=(hide ip) comment=WAN interface=ether1 network=(hide ip)
add address=192.168.0.1/24 comment=Maxi interface=bridge network=192.168.0.0
set store-leases-disk=immediately
add address=192.168.0.0/24 comment=Maxi dns-server=8.8.8.8 gateway=192.168.0.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.0.1 name=Router.one
add action=accept chain=forward comment="Maxi: accept out ipsec policy" ipsec-policy=out,ipsec
add action=accept chain=forward comment="Maxi: accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=input comment="VPN L2TP UDP 500" dst-port=500 in-interface=ether1 protocol=udp
add action=accept chain=input comment="VPN L2TP UDP 1701" dst-port=1701 in-interface=ether1 protocol=udp
add action=accept chain=input comment="VPN L2TP 4500" dst-port=4500 in-interface=ether1 protocol=udp
add action=accept chain=input comment="VPN L2TP ESP" disabled=yes in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input comment="VPN L2TP AH" disabled=yes in-interface=ether1 protocol=ipsec-ah
add action=accept chain=forward disabled=yes dst-address=192.168.5.0/24 src-address=10.10.10.0/24
add action=accept chain=forward disabled=yes dst-address=192.168.0.0/24 src-address=10.10.10.0/24
add action=fasttrack-connection chain=forward comment="Maxi: fasttrack" connection-state=established,related
add action=accept chain=forward comment="Maxi: accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="Maxi: drop invalid" connection-state=invalid
add action=drop chain=forward comment="Maxi: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="NAT L2TP/IPsec" dst-address=192.168.3.0/24 log=yes src-address=10.10.10.0/24
add action=masquerade chain=srcnat comment="NAT L2TP/IPsec" dst-address=192.168.4.0/24 log=yes src-address=10.10.10.0/24
add action=masquerade chain=srcnat comment="NAT L2TP/IPsec" dst-address=192.168.5.0/24 log=yes src-address=10.10.10.0/24
add action=masquerade chain=srcnat comment="NAT L2TP/IPsec" dst-address=192.168.6.0/24 log=yes src-address=10.10.10.0/24
add action=masquerade chain=srcnat comment="NAT L2TP/IPsec" dst-address=192.168.7.0/24 log=yes src-address=10.10.10.0/24
add action=masquerade chain=srcnat comment="NAT L2TP/IPsec" dst-address=192.168.8.0/24 log=yes src-address=10.10.10.0/24
add action=masquerade chain=srcnat comment="Maxi: masquerade" ipsec-policy=out,none out-interface-list=WAN
/ip ipsec identity
add peer=Ivasiuc
add peer=20th
/ip ipsec policy
add dst-address=192.168.7.0/24 peer=Ivasiuc proposal=proposalBaza sa-dst-address=(hide ip site B) sa-src-address=0.0.0.0 src-address=192.168.0.0/24 tunnel=yes
add dst-address=192.168.8.0/24 peer=20th proposal=proposalBaza sa-dst-address=(hide ip site A) sa-src-address=0.0.0.0 src-address=192.168.0.0/24 tunnel=yes
add distance=1 gateway=(hide ip)
add distance=1 dst-address=192.168.7.0/24 gateway=bridge
add distance=1 dst-address=192.168.8.0/24 gateway=bridge
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ppp secret
add name=maxi profile=VPN-L2TP service=l2tp
/system clock
set time-zone-name=Europe
/system identity
set name=Router
/system logging
add disabled=yes prefix="L2TPDBG===>" topics=l2tp
add disabled=yes prefix="IPSECDBG===>" topics=ipsec
add action=email topics=critical
add prefix="L2TPDBG===>" topics=l2tp
###################################################Site A config below
# nov/06/2019 21:34:52 by RouterOS 6.45.6
# software id = 5DU9-VKRF
# model = RBD52G-5HacD2HnD
# serial number = A6470A556291
add fast-forward=no name=Bridge
set [ find default-name=ether1 ] loop-protect=off
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no frequency=auto mode=ap-bridge ssid=UPC664767A wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no frequency=auto installation=indoor mode=ap-bridge ssid=UPC664767A5GHZ wireless-protocol=802.11 wps-mode=disabled
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
/ip hotspot profile
/ip ipsec profile
/ip ipsec peer
add address=((base_ip)/32 name=peer1 profile=profile1
/ip ipsec proposal
add name=dhcp_pool1 ranges=192.168.8.2-192.168.8.254
add name=dhcp_pool2 ranges=192.168.8.2-192.168.8.254
add address-pool=dhcp_pool2 authoritative=after-2sec-delay disabled=no interface=Bridge name=dhcp1
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=Bridge hw=no interface=ether2
add bridge=Bridge hw=no interface=ether3
add bridge=Bridge hw=no interface=ether4
add bridge=Bridge interface=wlan1
add bridge=Bridge hw=no interface=ether5
add bridge=Bridge interface=wlan2
set detect-interface-list=all wan-interface-list=dynamic
add interface=Bridge list=LAN
add address=192.168.8.1/24 comment="ip lan" interface=Bridge network=192.168.8.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.8.0/24 gateway=192.168.8.1
set servers=8.8.8.8
add action=accept chain=input comment="Maxi: accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="Maxi: accept ICMP" protocol=icmp
add action=accept chain=input comment="WinBox Wan Administration" dst-port=8291 protocol=tcp
add action=accept chain=input comment="allow L2TP VPN (ipsec-esp)" in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input comment="allow L2TP VPN (500,4500,1701/udp)" connection-mark="" dst-port=500,1701,4500 in-interface=ether1 protocol=udp
add action=drop chain=input comment="Maxi: drop all not coming from LAN" in-interface-list=!LAN log=yes
add action=drop chain=input comment="Maxi: drop invalid" connection-state=invalid
add action=accept chain=srcnat dst-address=192.168.0.0/24 log=yes src-address=192.168.8.0/24
add action=dst-nat chain=dstnat comment="My cloud WD -ftp in from WAN" dst-address=!192.168.8.0/24 dst-port=21 log=yes protocol=tcp src-port="" to-addresses=192.168.8.250 to-ports=21
add action=masquerade chain=srcnat comment="Local wd" dst-port=21 log=yes protocol=tcp src-address=192.168.8.0/24 to-ports=21
/ip ipsec identity
add peer=peer1
/ip ipsec policy
add dst-address=192.168.0.0/24 peer=peer1 sa-dst-address=(base_ip) sa-src-address=0.0.0.0 src-address=192.168.8.0/24 tunnel=yes
add check-gateway=ping distance=1 dst-address=192.168.0.0/24 gateway=Bridge
/ip service
/ip ssh
/system clock
set time-zone-name=Europe/Bucharest
/system identity
set name=20Th
/system ntp client
set enabled=yes
###################################################Site B config below
/interface wireless
/ip hotspot profile
/ip ipsec profile
/ip ipsec peer
/ip ipsec proposal
add name=dhcp_pool1 ranges=192.168.7.2-192.168.7.254
add name=dhcp_pool2 ranges=192.168.7.2-192.168.7.254
/snmp community
add address=192.168.7.1/24 comment="ip lan" interface=Bridge network=192.168.7.0
/ip dhcp-client
add address=192.168.7.0/24 gateway=192.168.7.1
set servers=8.8.8.8
add action=accept chain=srcnat dst-address=192.168.0.0/24 log=yes src-address=192.168.7.0/24
add action=dst-nat chain=dstnat comment="My cloud WD -ftp in from WAN" dst-address=!192.168.7.0/24 dst-port=21 log=yes protocol=tcp src-port="" to-addresses=192.168.7.250 to-ports=21
add action=masquerade chain=srcnat comment="Local wd" dst-port=21 log=yes protocol=tcp src-address=192.168.7.0/24 to-ports=21
/ip ipsec identity
add peer=peer1
/ip ipsec policy
add dst-address=192.168.0.0/24 peer=peer1 sa-dst-address=(base_ip) sa-src-address=0.0.0.0 src-address=192.168.7.0/24 tunnel=yes
/ip service
/ip ssh
/system clock
/system identity
set name=20Th
/system ntp client
set enabled=yes
