I have been running the below script and it has been working until I upgraded to 5.22. If I run the script with a “:global” it runs. Any ideas what might be the issue?
:local currentip [:resolve ABC.com]
:foreach int in=[/ip ipsec policy find] do={:if ([/ip ipsec policy get $int sa-src-address] != $currentip) do={/ip ipsec policy set $int sa-src-address=$currentip}}
Was an issue with the scheduler not the script. It was failing in a terminal as the :local wasn’t persistent on the second line. Once I resolved the scheduler issue it worked.
