I have the same problem and I’m quite sure I have used that matching before.. so therefor i think they have change something in v6. Before you also had to allow ipsec traffic in input chain, but not anymore..
Have you found any solution or answer to this or do you have any other idea on how to match ipsec traffic?
Well, i would say depressing.. Why can’t MT give an answer or at least a pointer on how to identify ipsec traffic reliable. This thread discusses this quit a bit but most of it is really old and you should think that MT would have solved the vulnerabilites by now. Feels like using ipsec is a no go because of the fact that you open up your self for spoofing attacks.
