Hi
Thanks in advance for your time!
I currently have a IPSec tunnel established between my Mikrotik router and the Oracle OCI.
For configuration I followed this guide: https://tech.belidzs.hu/blog/site-to-site-vpn-between-oracle-cloud-infrastructure-and-a-mikrotik-device/
Everything was working fine, but suddenly I couldn’t connect to the apache hosted at OCI site.
I then tried to connect via ssh. This worked, but if I open e.g. “top” the connection freezes.
Also pinging works from both sides.
I guess the IPSec connection is working and there must be something wrong with Routing or the Firewall?
Here is the export of my current configuration:
/ip firewall address-list
add address=0.0.0.0/8 list=private
add address=10.0.0.0/8 list=private
add address=100.64.0.0/10 list=private
add address=127.0.0.0/8 list=private
add address=169.254.0.0/16 list=private
add address=172.16.0.0/12 list=private
add address=192.0.0.0/24 list=private
add address=192.0.2.0/24 list=private
add address=192.168.0.0/16 list=private
add address=198.18.0.0/15 list=private
add address=198.51.100.0/24 list=private
add address=203.0.113.0/24 list=private
add address=224.0.0.0/3 list=private
add address=192.168.111.0/24 list=lan
add address=10.1.0.0/16 list=ipsec
add action=drop chain=input comment="drop bogons" in-interface-list=wan ipsec-policy=in,none src-address-list=private
add action=accept chain=input comment="accept established,related" connection-state=established,related
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=drop chain=input comment="drop all from WAN" in-interface-list=wan
add action=accept chain=forward comment="accept established,related" connection-state=established,related
add action=accept chain=forward comment="accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" ipsec-policy=out,ipsec
add action=drop chain=forward comment="drop invalid connection" connection-state=invalid
add action=drop chain=forward comment="drop all from WAN not dstnat" connection-nat-state=!dstnat connection-state=new in-interface-list=wan
/ip firewall mangle
add action=log chain=prerouting comment="Mark Connection - WAN1" disabled=yes
add action=mark-connection chain=input connection-mark=no-mark in-interface=ppp-wan1 new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark in-interface=ppp-wan1 new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=output connection-mark=no-mark new-connection-mark=wan1 out-interface=ppp-wan1 passthrough=yes
add action=mark-connection chain=postrouting connection-mark=no-mark new-connection-mark=wan1 out-interface=ppp-wan1 passthrough=yes
add action=log chain=prerouting comment="Mark Connection - WAN2" disabled=yes
add action=mark-connection chain=input connection-mark=no-mark in-interface=ether2_wan2 new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark in-interface=ether2_wan2 new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=output connection-mark=no-mark new-connection-mark=wan2 out-interface=ether2_wan2 passthrough=yes
add action=mark-connection chain=postrouting connection-mark=no-mark new-connection-mark=wan2 out-interface=ether2_wan2 passthrough=yes
add action=log chain=prerouting comment="Mark Connection - WAN3" disabled=yes
add action=mark-connection chain=input connection-mark=no-mark in-interface=ether3_wan3 new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark in-interface=ether3_wan3 new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=output connection-mark=no-mark new-connection-mark=wan3 out-interface=ether3_wan3 passthrough=yes
add action=mark-connection chain=postrouting connection-mark=no-mark new-connection-mark=wan3 out-interface=ether3_wan3 passthrough=yes
add action=accept chain=srcnat comment="oci ipsec bypass" dst-address-list=ipsec src-address-list=lan
add action=masquerade chain=srcnat comment="masquerade wan1 ppp" out-interface=ppp-wan1
add action=masquerade chain=srcnat comment="masquerade wan1 interface" out-interface=ether1_wan1
add action=masquerade chain=srcnat comment="masquerade wan2 interface" out-interface=ether2_wan2
add action=masquerade chain=srcnat comment="masquerade wan3 interface" out-interface=ether3_wan3
/ip ipsec identity
add peer=oci-1 policy-template-group=oci
/ip ipsec peer
add address=130.61.194.105/32 name=oci-1 profile=oci
/ip ipsec policy
add dst-address=10.1.0.0/16 peer=oci-1 proposal=oci src-address=192.168.111.0/24 tunnel=yes
/ip ipsec policy group
add name=oci
/ip ipsec profile
add dh-group=ecp256,ecp384,modp2048,modp1536,modp1024 enc-algorithm=aes-256,aes-192,aes-128 hash-algorithm=sha384 lifetime=8h name=oci nat-traversal=no
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc,aes-256-gcm,aes-192-cbc,aes-192-gcm,aes-128-cbc,aes-128-gcm lifetime=1h name=oci pfs-group=modp1536
add distance=1 gateway=10.255.255.3 routing-mark=wan3_route
add distance=2 gateway=10.255.255.1 routing-mark=wan3_route
add distance=3 gateway=10.255.255.2 routing-mark=wan3_route
add distance=1 gateway=10.255.255.1 routing-mark=wan1_route
add distance=2 gateway=10.255.255.2 routing-mark=wan1_route
add distance=3 gateway=10.255.255.3 routing-mark=wan1_route
add distance=1 gateway=10.255.255.2 routing-mark=wan2_route
add distance=2 gateway=10.255.255.1 routing-mark=wan2_route
add distance=3 gateway=10.255.255.3 routing-mark=wan2_route
add comment=wan1_route distance=1 gateway=10.255.255.1
add comment=wan2_route distance=2 gateway=10.255.255.2
add comment=wan3_route distance=3 gateway=10.255.255.3
add comment=wan2_check distance=1 dst-address=8.8.4.4/32 gateway=192.168.0.1 scope=10
add comment=wan1_check distance=1 dst-address=8.8.8.8/32 gateway=62.52.192.142 scope=10
add comment=wan1_check distance=1 dst-address=9.9.9.10/32 gateway=62.52.192.142 scope=10
add distance=1 dst-address=10.1.0.0/16 gateway=132.145.232.34
add check-gateway=ping comment=wan1_virtual_hop distance=1 dst-address=10.255.255.1/32 gateway=8.8.8.8 scope=10
add check-gateway=ping comment=wan1_virtual_hop distance=1 dst-address=10.255.255.1/32 gateway=1.0.0.1 scope=10
add check-gateway=ping comment=wan2_virtual_hop distance=1 dst-address=10.255.255.2/32 gateway=8.8.4.4 scope=10
add check-gateway=ping comment=wan2_virtual_hop distance=1 dst-address=10.255.255.2/32 gateway=208.67.222.222 scope=10
add check-gateway=ping comment=wan3_virtual_hop distance=1 dst-address=10.255.255.3/32 gateway=208.67.220.220 scope=10
add check-gateway=ping comment=wan3_virtual_hop distance=1 dst-address=10.255.255.3/32 gateway=149.112.112.112 scope=10
add comment=wan3_check distance=1 dst-address=149.112.112.10/32 gateway=46.0.0.1 scope=10
add comment=wan3_check distance=1 dst-address=208.67.220.220/32 gateway=46.0.0.1 scope=10
add comment=wan2_check distance=1 dst-address=208.67.222.222/32 gateway=192.168.0.1 scope=10
What can I do to debug the issue and which other information do you need to help me?
I would appreciate any help!
Edit: It seems to work until the wan connection disconnects. After a reboot of the router the connection is working again. What could cause this issue and is there anything I can do to prevent this happening?
