Hi I’m trying to configure IPsec to Fortigate based on a strongSwan ipsec.conf file without luck.
The log shows
Received a valid R-U-THERE, ACK sent
an den loops the same data
The ipsec.conf file contains
conn work
type=tunnel
authby=secret
ikelifetime=1440m
keylife=60m
aggressive=no
ike=3des-sha1-modp1024! #Phase1 parameters
esp=3des-sha1! #Phase2 parameters
xauth=client #Xauth client mode
left= #local IP used to connect to IOS
leftid= #IKEID (group name) used for IOS
leftsourceip=%config #apply received IP
leftauth=psk
leftauth2=xauth
rightauth=psk
rightauth2=xauth #use PSK for group RA and Xauth for user cisco
right=xxx.xxx.xxx.xxx #gateway (IOS) IP
rightsubnet=172.16.0.0/16
xauth_identity=user #identity for Xauth, password in ipsec.secrets
auto=add
my config:
Is there anything I should know?
I’m really new to this and I don’t even know where to start the debug, so any help will be really appreciated.
