IPSec troubles
I’m having a problem setting up an IPSec tunnel to another company. This VPN works perfectly fine on a netgear router they installed, but I’m trying to switch their netgear with a mikrotik. The information I was given was this:
PSK: password here
Local ID: company name
Services: PCAnywhere TCP/UDP 5631-5632
P1 Proposal: pre-g2-3des-sha
P2 Proposal: g2-esp-3des-sha
IPSec tunnel to their Ip
The ID is just the company name so it shouldn’t matter, its not the FQDN or anything. The services shouldnt matter as was set up to forward all the ports before.
** edit: i was just given a peer id, i’ve put this in the my id spot in the peer setup, though nothing has changed **
The problem is, theres basically no debug information on the mikrotik, I set it up as I see there, and all I get when I save the config is the following:
installing phase2 config: id=0
installing phase2 config: id=1
If I do the command /ip ipsec policy print stats:
ph2-state=no-phase2
I have no idea where the breakdown is, i dont even know what its stuck on. Is it stuck in phase 1, phase 2? What setting should i even be playing with?
The peer is set up as follows:
address: their address
port: 500
Auth: PSK
Secret: password here
Exchange Mode: main
Send initial contact: yes
nat trav: no
FQDN: [blank]
prop check: obey
hash: sha
enc alg: 3des
DH group: modp1024
generate policy: no
lifetime: 1d
dpd: 120s
dpd max fail: 5
proposal:
sha1
3des
lifetime 1h
pfs: modp1024
policies:
src address: local lan ip range
dst address: remote lan ip range
protocol: any
action: encrypt
level: require
protocol: esp
tunnel: yes
sa src address: 0.0.0.0 (our ip is dynamic, again, works on netgear, however i have also tried setting it to external IP)
sa dst address: their ip address
proposal: proposal1 (the one listed above)
priority: 0
