IPSec Tunnel and SSTP VPN - No remote lan access
We have two Mikrotik cloud routers. One at the HO and another at the branch. We have established a IPSec tunnel from the branch office to the HO router and is working fine. Branch office is able to access the resources at the HO and vice versa.
We have created a road warrior SSTP VPN for one of our user at the HO. He is able to connect to the HO network and able to access the resources hosted in the HO network. But how can I make the road warrior user to access the resources hosted at the branch office using the IPSec tunnel?
i know the post is very old but did you find the solution since i have the same case here
That is usually a matter of routing configuration at both end devices of the IPsec tunnel. If you need a more precise advice, you have to provide a more useful input, by posting the output of ****
/export hide-sensitive
from both Mikrotiks after replacing each occurrence of any public IP address you don’t want to reveal with a distnctive pattern like ****
my.public.ip.A
, the distinctive pattern must be the same in both exports for the same address.
