My policy was set to encrypt/require/esp/tunnel. I have now changed that to encrypt/require/ah/no tunnel. The logs look very similar to me. I don’t get it.
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc,3des
add auth-algorithms=sha1,md5 enc-algorithms=aes-128-cbc,3des,blowfish lifetime=1h name=centos
/ip ipsec peer
add address=0.0.0.0/0 dh-group=modp1024 disabled=yes enc-algorithm=3des exchange-mode=main-l2tp \
generate-policy=port-override lifetime=8h
add address=x.x.x.x/32 dh-group=modp2048,modp1536,modp1024 enc-algorithm=\
aes-128,3des,blowfish generate-policy=port-strict send-initial-contact=no
/ip ipsec policy
add dst-address=x.x.x.x/32 ipsec-protocols=ah proposal=centos src-address=\
y.y.y.y/32
BTW, I also ran it with generate-policy=port-override and got the same results. I then ran it with ipsec-protocols=esp. The only difference was the MD5 part of “my single bundle” went missing with esp.
01:34:34 ipsec,debug ===== received 100 bytes from x.x.x.x[500] to y.y.y.y[500]
01:34:34 ipsec,info respond new phase 1 (Identity Protection): y.y.y.y[500]<=>x.x.x.x[500]
01:34:34 ipsec,debug begin.
01:34:34 ipsec,debug seen nptype=1(sa) len=52
01:34:34 ipsec,debug seen nptype=13(vid) len=20
01:34:34 ipsec,debug succeed.
01:34:34 ipsec received Vendor ID: DPD
01:34:34 ipsec,debug remote supports DPD
01:34:34 ipsec,debug total SA len=48
01:34:34 ipsec,debug 00000001 00000001 00000028 01010001 00000020 01010000 800b0001 800c7080
01:34:34 ipsec,debug 80010005 80030001 80020002 80040002
01:34:34 ipsec,debug seen nptype=2(prop) len=40
01:34:34 ipsec,debug proposal #1 len=40
01:34:34 ipsec,debug seen nptype=3(trns) len=32
01:34:34 ipsec,debug transform #1 len=32
01:34:34 ipsec,debug type=Life Type, flag=0x8000, lorv=seconds
01:34:34 ipsec,debug type=Life Duration, flag=0x8000, lorv=28800
01:34:34 ipsec,debug type=Encryption Algorithm, flag=0x8000, lorv=3DES-CBC
01:34:34 ipsec,debug encryption(3des)
01:34:34 ipsec,debug type=Authentication Method, flag=0x8000, lorv=pre-shared key
01:34:34 ipsec,debug type=Hash Algorithm, flag=0x8000, lorv=SHA
01:34:34 ipsec,debug hash(sha1)
01:34:34 ipsec,debug type=Group Description, flag=0x8000, lorv=1024-bit MODP group
01:34:34 ipsec,debug dh(modp1024)
01:34:34 ipsec,debug pair 1:
01:34:34 ipsec,debug 0x48c058: next=(nil) tnext=(nil)
01:34:34 ipsec,debug proposal #1: 1 transform
01:34:34 ipsec,debug prop#=1, prot-id=ISAKMP, spi-size=0, #trns=1
01:34:34 ipsec,debug trns#=1, trns-id=IKE
01:34:34 ipsec,debug Compared: Local:Peer
01:34:34 ipsec,debug (lifetime = 86400:28800)
01:34:34 ipsec,debug (lifebyte = 0:0)
01:34:34 ipsec,debug enctype = AES-CBC:3DES-CBC
01:34:34 ipsec,debug (encklen = 128:0)
01:34:34 ipsec,debug hashtype = SHA:SHA
01:34:34 ipsec,debug authmethod = pre-shared key:pre-shared key
01:34:34 ipsec,debug dh_group = 2048-bit MODP group:1024-bit MODP group
01:34:34 ipsec,debug dh_group = 1536-bit MODP group:1024-bit MODP group
01:34:34 ipsec,debug dh_group = 1024-bit MODP group:1024-bit MODP group
01:34:34 ipsec,debug enctype = 3DES-CBC:3DES-CBC
01:34:34 ipsec,debug (encklen = 0:0)
01:34:34 ipsec,debug an acceptable proposal found.
01:34:34 ipsec,debug agreed on pre-shared key auth.
01:34:34 ipsec,debug new cookie:
01:34:34 ipsec,debug 962ab4613d613c6f
01:34:34 ipsec,debug add payload of len 48, next type 13
01:34:34 ipsec,debug add payload of len 16, next type 0
01:34:34 ipsec,debug 100 bytes from y.y.y.y[500] to x.x.x.x[500]
01:34:34 ipsec,debug 1 times of 100 bytes message will be sent to x.x.x.x[500]
01:34:34 ipsec sent phase1 packet y.y.y.y[500]<=>x.x.x.x[500] 77b96f864966876c:962ab4613d613c6f
01:34:34 ipsec,debug ===== received 508 bytes from x.x.x.x[500] to y.y.y.y[500]
01:34:34 ipsec,debug compute IV for phase2
01:34:34 ipsec,debug phase1 last IV:
01:34:34 ipsec,debug 228697a1 06403767 ac306ed1
01:34:34 ipsec,debug phase2 IV computed:
01:34:34 ipsec,debug 76669a1c 0cf3bdb7
01:34:34 ipsec respond new phase 2 negotiation: y.y.y.y[500]<=>x.x.x.x[500]
01:34:34 ipsec,debug IV was saved for next processing:
01:34:34 ipsec,debug b756eb70 a056decb
01:34:34 ipsec,debug with key:
01:34:34 ipsec,debug 4745fffc 6ff98373 4793adf6 51dbf5ad ba578763 33413823
01:34:34 ipsec,debug decrypted payload by IV:
01:34:34 ipsec,debug decrypted payload, but not trimed.
01:34:34 ipsec,debug 01000018 1cc89047 d3b9cbbb 39fe20e7 b80e406e bfb1e9a3 0a000114 00000001
01:34:34 ipsec,debug 00000001 02000044 01020402 093f95f5 0300001c 01030000 80010001 80020e10
01:34:34 ipsec,debug 80040002 80050002 80030002 0000001c 02020000 80010001 80020e10 80040002
01:34:34 ipsec,debug 80050001 80030002 000000c4 01030406 08ba7628 0300001c 01030000 80010001
01:34:34 ipsec,debug 80020e10 80040002 80050002 80030002 0300001c 02030000 80010001 80020e10
01:34:34 ipsec,debug 80040002 80050001 80030002 03000020 03070000 80010001 80020e10 80040002
01:34:34 ipsec,debug 800601c0 80050002 80030002 03000020 04070000 80010001 80020e10 80040002
01:34:34 ipsec,debug 800601c0 80050001 80030002 03000020 050c0000 80010001 80020e10 80040002
01:34:34 ipsec,debug 80060080 80050002 80030002 00000020 060c0000 80010001 80020e10 80040002
01:34:34 ipsec,debug 80060080 80050001 80030002 04000014 938f89c8 eff781b5 168ef74d 92dc1fde
01:34:34 ipsec,debug 05000084 2fc726a6 e0db00be a2d87850 cd304bd8 44a52b0b bb114871 88a8cfed
01:34:34 ipsec,debug 5d0d901f 3963d6d7 20fcdcde bc2eed15 5a69b154 24a2dfd5 dde3b755 d78cc7ee
01:34:34 ipsec,debug 4d3db56a 7f0c6ab5 83528ae8 9e2d117f 2ae17ede fa74551a 4a7b1237 c74e6eac
01:34:34 ipsec,debug 6d88c2d0 fac32bab 9bbcca57 a2fa9906 060e84d9 7bcec839 d075fced bb0a32d0
01:34:34 ipsec,debug 3c715018 0500000c 01000000 d8e6e7e2 0000000c 01000000 40fa290d 9db59603
01:34:34 ipsec,debug padding len=4
01:34:34 ipsec,debug skip to trim padding.
01:34:34 ipsec,debug decrypted.
01:34:34 ipsec,debug 5a9fd6f1 3261a995 11721b76 3786bf24 08102001 ac306ed1 000001fc 01000018
01:34:34 ipsec,debug 1cc89047 d3b9cbbb 39fe20e7 b80e406e bfb1e9a3 0a000114 00000001 00000001
01:34:34 ipsec,debug 02000044 01020402 093f95f5 0300001c 01030000 80010001 80020e10 80040002
01:34:34 ipsec,debug 80050002 80030002 0000001c 02020000 80010001 80020e10 80040002 80050001
01:34:34 ipsec,debug 80030002 000000c4 01030406 08ba7628 0300001c 01030000 80010001 80020e10
01:34:34 ipsec,debug 80040002 80050002 80030002 0300001c 02030000 80010001 80020e10 80040002
01:34:34 ipsec,debug 80050001 80030002 03000020 03070000 80010001 80020e10 80040002 800601c0
01:34:34 ipsec,debug 80050002 80030002 03000020 04070000 80010001 80020e10 80040002 800601c0
01:34:34 ipsec,debug 80050001 80030002 03000020 050c0000 80010001 80020e10 80040002 80060080
01:34:34 ipsec,debug 80050002 80030002 00000020 060c0000 80010001 80020e10 80040002 80060080
01:34:34 ipsec,debug 80050001 80030002 04000014 938f89c8 eff781b5 168ef74d 92dc1fde 05000084
01:34:34 ipsec,debug 2fc726a6 e0db00be a2d87850 cd304bd8 44a52b0b bb114871 88a8cfed 5d0d901f
01:34:34 ipsec,debug 3963d6d7 20fcdcde bc2eed15 5a69b154 24a2dfd5 dde3b755 d78cc7ee 4d3db56a
01:34:34 ipsec,debug 7f0c6ab5 83528ae8 9e2d117f 2ae17ede fa74551a 4a7b1237 c74e6eac 6d88c2d0
01:34:34 ipsec,debug fac32bab 9bbcca57 a2fa9906 060e84d9 7bcec839 d075fced bb0a32d0 3c715018
01:34:34 ipsec,debug 0500000c 01000000 d8e6e7e2 0000000c 01000000 40fa290d 9db59603
01:34:34 ipsec,debug seen nptype=8(hash) len=24
01:34:34 ipsec,debug seen nptype=1(sa) len=276
01:34:34 ipsec,debug seen nptype=10(nonce) len=20
01:34:34 ipsec,debug seen nptype=4(ke) len=132
01:34:34 ipsec,debug seen nptype=5(id) len=12
01:34:34 ipsec,debug received IDci2:
01:34:34 ipsec,debug 01000000 d8e6e7e2
01:34:34 ipsec,debug received IDcr2:
01:34:34 ipsec,debug 01000000 40fa290d
01:34:34 ipsec,debug HASH(1) validate:
01:34:34 ipsec,debug HASH with:
01:34:34 ipsec,debug ac306ed1 0a000114 00000001 00000001 02000044 01020402 093f95f5 0300001c
01:34:34 ipsec,debug 01030000 80010001 80020e10 80040002 80050002 80030002 0000001c 02020000
01:34:34 ipsec,debug 80010001 80020e10 80040002 80050001 80030002 000000c4 01030406 08ba7628
01:34:34 ipsec,debug 0300001c 01030000 80010001 80020e10 80040002 80050002 80030002 0300001c
01:34:34 ipsec,debug 02030000 80010001 80020e10 80040002 80050001 80030002 03000020 03070000
01:34:34 ipsec,debug 80010001 80020e10 80040002 800601c0 80050002 80030002 03000020 04070000
01:34:34 ipsec,debug 80010001 80020e10 80040002 800601c0 80050001 80030002 03000020 050c0000
01:34:34 ipsec,debug 80010001 80020e10 80040002 80060080 80050002 80030002 00000020 060c0000
01:34:34 ipsec,debug 80010001 80020e10 80040002 80060080 80050001 80030002 04000014 938f89c8
01:34:34 ipsec,debug eff781b5 168ef74d 92dc1fde 05000084 2fc726a6 e0db00be a2d87850 cd304bd8
01:34:34 ipsec,debug 44a52b0b bb114871 88a8cfed 5d0d901f 3963d6d7 20fcdcde bc2eed15 5a69b154
01:34:34 ipsec,debug 24a2dfd5 dde3b755 d78cc7ee 4d3db56a 7f0c6ab5 83528ae8 9e2d117f 2ae17ede
01:34:34 ipsec,debug fa74551a 4a7b1237 c74e6eac 6d88c2d0 fac32bab 9bbcca57 a2fa9906 060e84d9
01:34:34 ipsec,debug 7bcec839 d075fced bb0a32d0 3c715018 0500000c 01000000 d8e6e7e2 0000000c
01:34:34 ipsec,debug hmac(hmac_sha1)
01:34:34 ipsec,debug HASH computed:
01:34:34 ipsec,debug total SA len=272
01:34:34 ipsec,debug 00000001 00000001 02000044 01020402 093f95f5 0300001c 01030000 80010001
01:34:34 ipsec,debug 80020e10 80040002 80050002 80030002 0000001c 02020000 80010001 80020e10
01:34:34 ipsec,debug 80040002 80050001 80030002 000000c4 01030406 08ba7628 0300001c 01030000
01:34:34 ipsec,debug 80010001 80020e10 80040002 80050002 80030002 0300001c 02030000 80010001
01:34:34 ipsec,debug 80020e10 80040002 80050001 80030002 03000020 03070000 80010001 80020e10
01:34:34 ipsec,debug 80040002 800601c0 80050002 80030002 03000020 04070000 80010001 80020e10
01:34:34 ipsec,debug 80040002 800601c0 80050001 80030002 03000020 050c0000 80010001 80020e10
01:34:34 ipsec,debug 80040002 80060080 80050002 80030002 00000020 060c0000 80010001 80020e10
01:34:34 ipsec,debug 80040002 80060080 80050001 80030002
01:34:34 ipsec,debug seen nptype=2(prop) len=68
01:34:34 ipsec,debug seen nptype=2(prop) len=196
01:34:34 ipsec,debug proposal #1 len=68
01:34:34 ipsec,debug seen nptype=3(trns) len=28
01:34:34 ipsec,debug transform #1 len=28
01:34:34 ipsec,debug type=SA Life Type, flag=0x8000, lorv=seconds
01:34:34 ipsec,debug type=SA Life Duration, flag=0x8000, lorv=3600
01:34:34 ipsec,debug life duration was in TLV.
01:34:34 ipsec,debug type=Encryption Mode, flag=0x8000, lorv=Transport
01:34:34 ipsec,debug type=Authentication Algorithm, flag=0x8000, lorv=hmac-sha1
01:34:34 ipsec,debug type=Group Description, flag=0x8000, lorv=2
01:34:34 ipsec,debug transform #2 len=28
01:34:34 ipsec,debug type=Authentication Algorithm, flag=0x8000, lorv=hmac-md5
01:34:34 ipsec,debug proposal #1 len=196
01:34:34 ipsec,debug transform #3 len=32
01:34:34 ipsec,debug type=Key Length, flag=0x8000, lorv=448
01:34:34 ipsec,debug transform #4 len=32
01:34:34 ipsec,debug transform #5 len=32
01:34:34 ipsec,debug type=Key Length, flag=0x8000, lorv=128
01:34:34 ipsec,debug transform #6 len=32
01:34:34 ipsec,debug 0x4ac460: next=0x49cc18 tnext=0x48ce50
01:34:34 ipsec,debug 0x49cc18: next=(nil) tnext=0x49cff8
01:34:34 ipsec,debug 0x49cff8: next=(nil) tnext=0x493e18
01:34:34 ipsec,debug 0x493e18: next=(nil) tnext=0x48b8a8
01:34:34 ipsec,debug 0x48b8a8: next=(nil) tnext=0x4b1150
01:34:34 ipsec,debug 0x4b1150: next=(nil) tnext=0x4a2b58
01:34:34 ipsec,debug 0x4a2b58: next=(nil) tnext=(nil)
01:34:34 ipsec,debug 0x48ce50: next=(nil) tnext=(nil)
01:34:34 ipsec,debug proposal #1: 8 transform
01:34:34 ipsec,debug got the local address from ID payload y.y.y.y[0] prefixlen=32 ul_proto=255
01:34:34 ipsec,debug got the peer address from ID payload x.x.x.x[0] prefixlen=32 ul_proto=255
01:34:34 ipsec searching for policy for selector: y.y.y.y <=> x.x.x.x
01:34:34 ipsec using strict match: y.y.y.y <=> x.x.x.x
01:34:34 ipsec,debug (proto_id=AH spisize=4 spi=00000000 spi_p=00000000 encmode=Transport reqid=0:0)
01:34:34 ipsec,debug (trns_id=SHA authtype=hmac-sha1)
01:34:34 ipsec,debug (trns_id=MD5 authtype=hmac-md5)
01:34:34 ipsec,debug begin compare proposals.
01:34:34 ipsec,debug pair[1]: 0x4ac460
01:34:34 ipsec,debug prop#=1 prot-id=AH spi-size=4 #trns=2 trns#=1 trns-id=SHA
01:34:34 ipsec,debug prop#=1 prot-id=AH spi-size=4 #trns=2 trns#=2 trns-id=MD5
01:34:34 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=6 trns#=1 trns-id=3DES
01:34:34 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=6 trns#=2 trns-id=3DES
01:34:34 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=6 trns#=3 trns-id=BLOWFISH
01:34:34 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=6 trns#=4 trns-id=BLOWFISH
01:34:34 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=6 trns#=5 trns-id=AES-CBC
01:34:34 ipsec,debug prop#=1 prot-id=ESP spi-size=4 #trns=6 trns#=6 trns-id=AES-CBC
01:34:34 ipsec,debug peer's single bundle:
01:34:34 ipsec,debug (proto_id=AH spisize=4 spi=093f95f5 spi_p=00000000 encmode=Transport reqid=0:0)
01:34:34 ipsec,debug (proto_id=ESP spisize=4 spi=08ba7628 spi_p=00000000 encmode=Transport reqid=0:0)
01:34:34 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-sha1)
01:34:34 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-md5)
01:34:34 ipsec,debug (trns_id=BLOWFISH encklen=448 authtype=hmac-sha1)
01:34:34 ipsec,debug (trns_id=BLOWFISH encklen=448 authtype=hmac-md5)
01:34:34 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-sha1)
01:34:34 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-md5)
01:34:34 ipsec,debug my single bundle:
01:34:34 ipsec,debug not matched
01:34:34 ipsec,error no suitable proposal found.
01:34:34 ipsec failed to get proposal for responder.
01:34:34 ipsec,error x.x.x.x failed to pre-process ph2 packet.
port-override:
01:44:54 ipsec,debug peer's single bundle:
01:44:54 ipsec,debug (proto_id=AH spisize=4 spi=0010a686 spi_p=00000000 encmode=Transport reqid=0:0)
01:44:54 ipsec,debug (trns_id=SHA authtype=hmac-sha1)
01:44:54 ipsec,debug (trns_id=MD5 authtype=hmac-md5)
01:44:54 ipsec,debug (proto_id=ESP spisize=4 spi=0eee26e7 spi_p=00000000 encmode=Transport reqid=0:0)
01:44:54 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-sha1)
01:44:54 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-md5)
01:44:54 ipsec,debug (trns_id=BLOWFISH encklen=448 authtype=hmac-sha1)
01:44:54 ipsec,debug (trns_id=BLOWFISH encklen=448 authtype=hmac-md5)
01:44:54 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-sha1)
01:44:54 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-md5)
01:44:54 ipsec,debug my single bundle:
01:44:54 ipsec,debug (proto_id=AH spisize=4 spi=00000000 spi_p=00000000 encmode=Transport reqid=0:0)
01:44:54 ipsec,debug not matched
01:44:54 ipsec,error no suitable proposal found.
01:44:54 ipsec failed to get proposal for responder.
01:44:54 ipsec,error 216.230.231.226 failed to pre-process ph2 packet.
ipsec-protocols=esp:
01:48:31 ipsec,debug peer's single bundle:
01:48:31 ipsec,debug (proto_id=AH spisize=4 spi=0e245677 spi_p=00000000 encmode=Transport reqid=0:0)
01:48:31 ipsec,debug (trns_id=SHA authtype=hmac-sha1)
01:48:31 ipsec,debug (trns_id=MD5 authtype=hmac-md5)
01:48:31 ipsec,debug (proto_id=ESP spisize=4 spi=099a2d97 spi_p=00000000 encmode=Transport reqid=0:0)
01:48:31 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-sha1)
01:48:31 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-md5)
01:48:31 ipsec,debug (trns_id=BLOWFISH encklen=448 authtype=hmac-sha1)
01:48:31 ipsec,debug (trns_id=BLOWFISH encklen=448 authtype=hmac-md5)
01:48:31 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-sha1)
01:48:31 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-md5)
01:48:31 ipsec,debug my single bundle:
01:48:31 ipsec,debug (proto_id=AH spisize=4 spi=00000000 spi_p=00000000 encmode=Transport reqid=4711:4711)
01:48:31 ipsec,debug not matched
01:48:31 ipsec,error no suitable proposal found.
01:48:31 ipsec failed to get proposal for responder.
01:48:31 ipsec,error 216.230.231.226 failed to pre-process ph2 packet.
