IPsec tunnel configuration
Shot at 2012-09-02
This is my network and I need to do IPsec tunnel between side1 an side 2. Users from side 2 (192.168.2.0/24) must communicate with server (172.16.1.10) on side 2 or with subnet 172.16.1.0/24. How can I configure IP sec tunel?
side 2:
ADDRESS NETWORK INTERFACE
0 ;;; default configuration
192.168.2.1/24 192.168.2.0 bridge LAN - WLAN1
1 192.168.20.1/30 192.168.20.0 management link (not important)
2 D 93.138.77.119/32 172.29.252.64 INTERNET
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 172.29.252.64 1
1 ADC 172.29.252.64/32 93.138.77.119 INTERNET 0
2 ADC 192.168.2.0/24 192.168.2.1 bridge LAN - WLAN1 0
3 ADC 192.168.20.0/30 192.168.20.1 management link 0
NAME TYPE MTU L2MTU MAX-L2MTU
0 management link ether 1500 1598 4074
1 R LAN ether 1500 1598 4074
2 X ether3-slave-local ether 1500 1598 4074
3 X ether4-slave-local ether 1500 1598 4074
4 R LAN-net ether 1500 1598 4074
5 wlan1 wlan 1500 2290
6 R bridge LAN - WLAN1 bridge 1500 1598
7 R INTERNET pppoe-out 1480
0 chain=srcnat action=masquerade src-address-list=LAN out-interface=INTERN
side 1:
ADDRESS NETWORK BROADCAST INTERFACE
172.16.0.254/30 172.16.0.252 172.16.0.255 LAN
1 192.168.10.1/24 192.168.10.0 192.168.10.255 management link
2 D 78.0.208.170/32 172.29.252.58 0.0.0.0 INTERNET
0 ADS 0.0.0.0/0 172.29.252.58 1
1 ADC 172.16.0.252/30 172.16.0.254 LAN 0
2 A S 172.16.1.0/24 172.16.0.253 1
3 ADC 172.29.252.58/32 78.0.208.170 INTERNET 0
4 ADC 192.168.10.0/24 192.168.10.1 management link 0
0 ;;; exit to internet
out-interface=INTERNET
you may try this, if you have static ip-addresses on your pppoe-client interfaces
on side1
/ip ipsec peer add addr=93.138.77.119 secret="your_very_strong_secret" nat-traversal=yes
/ip ipsec policy add src-addr=172.16.1.0/24 dst-addr=192.168.2.0/24 sa-src-addr=78.0.208.170 sa-dst-addr=93.138.77.119 tunnel=yes
/ip firewall nat add place-before=0 chain=srcnat action=accept src-addr=172.16.1.0/24 dst-addr=192.168.2.0/24 out-interface=INTERNET comment="NAT bypass for IPsec"
on side2
/ip ipsec peer add addr=78.0.208.170 secret="your_very_strong_secret" nat-traversal=yes
/ip ipsec policy add src-addr=192.168.2.0/24 dst-addr=172.16.1.0/24 sa-src-addr=93.138.77.119 sa-dst-addr=78.0.208.170 tunnel=yes
/ip firewall nat add place-before=0 chain=srcnat action=accept src-addr=192.168.2.0/24 dst-addr=172.16.1.0/24 out-interface=INTERN comment="NAT bypass for IPsec"
It works, but I haven’t static IP addresses.
Thank you.
I don’t have a static IP address.
On booth sides is script which resolves DDNS:
name="Resolve DDNS" owner="admin"
     policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,
       sensitive,api
     last-started=dec/06/2012 20:53:02 run-count=10
     source=
       :global newr1 [:resolve xxx.dyndns.org]
       :global newr2 [:resolve xxx.dyndns.org]
       /ip ipsec policy set 0 sa-dst-address=$newr1
       /ip ipsec peer set 0 address=$newr1
       /ip ipsec policy set 0 sa-src-address=$newr2
       :log info "resolve IP for Ipsec"
IPsec settings:
Flags: X - disabled, D - dynamic, I - inactive
 0   src-address=172.16.0.0/16 src-port=any dst-address=192.168.2.0/24
     dst-port=any protocol=all action=encrypt level=require
     ipsec-protocols=esp tunnel=yes sa-src-address=93.136.224.249
     sa-dst-address=93.136.52.220 proposal=default priority=0
Flags: X - disabled
 0   address=93.139.39.81/32 port=500 auth-method=pre-shared-key
     secret="test" generate-policy=no exchange-mode=main
     send-initial-contact=yes nat-traversal=yes my-id-user-fqdn=""
     proposal-check=obey hash-algorithm=md5 enc-algorithm=3des
     dh-group=modp1024 lifetime=1d lifebytes=0
     dpd-interval=disable-dpd dpd-maximum-failures=1
Netwach:
Flags: X - disabled
 #   HOST                 TIMEOUT              INTERVAL
 0   192.168.2.1          1s                   1m30s
If netwach ping, run script:
name="DisaSched_1" owner="admin"
       sensitive,api
     last-started=dec/06/2012 20:54:00 run-count=1
     source=system scheduler disable "IPsec"
if not ping, run script
       sensitive,api
