IPSec Tunnel Configuration
Greetings,
New to Mikrotik. I have two RB2011 units running OS 6.19. Basic configuration as in static IP on WAN port
ether 1. Remainder of ethernet ports bridged as LAN sitting behind a masquerade NAT rule to 192.168.1.X.
Other unit is the same except LAN IP range is 192.168.0.X. Computers conencted to both units can surf the web without a problem. Attempted to configure an IPSec tunnel between units using the tutorial provided by Greg Sowell. In the logs, I can see that the ISAKMP-SA will establish without difficulty but if I attempt to ping
an IP in the remote network nothing else appears in the logs and the tunnel doesn’t come up. I suspect the reason for the tunnel not coming up is that it doesn’t recoginize “Interesting Traffic”.
Not sure where to look so posting here for some insight.
Thank You in Advance.
Aaron
