Hallo everyone
I’m trying to setup up an IPSec VPN with a friend. Both are Mikrotik router with the current RouterOS version.
Setting up the Polices, the Peer,the proposal and the src-nat exclusion, no problem, the tunnel gets established. But when i try to ping an ip in his network i get a timeout and the same when he tries to ping me. The Byte Counter in the Installed SAs tab counts up but there are no packets arriving. I tried to use the “dump-kernel-policies” command but the command is not available. The challenge is that he gets acces to me DMZ (ether2-dmz. 192.168.10.0/24) subnet.
The IPSec debug Log only says:
KA: 178.190.87.165[4500]>77.117.109.238[4500]
sockname 178.190.87.165[4500]
send packet from 178.190.87.165[4500]
send packet to 77.117.109.238[4500]
src4 178.190.87.165[4500]
dst4 77.117.109.238[4500]
1 times of 1 bytes message will be send to 77.117.109.238[4500]
ff
Here is my IPSec and Firewall configuration:
Firewall
0 ;;; == Internet
chain=input action=accept connection-state=established,related in-interface=pppoe-out1 log=no log-prefix=""
1 chain=input action=accept protocol=udp in-interface=pppoe-out1 dst-port=500 log=no log-prefix=""
2 chain=input action=accept protocol=udp in-interface=pppoe-out1 dst-port=4500 log=no log-prefix=""
3 chain=input action=drop in-interface=pppoe-out1 log=no log-prefix=""
4 chain=forward action=drop connection-state=invalid in-interface=pppoe-out1 log=no log-prefix=""
5 chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=pppoe-out1 log=no log-prefix=""
6 ;;; == Internet Failover
chain=input action=accept connection-state=established,related in-interface=ether10-failover log=no log-prefix=""
7 chain=input action=drop in-interface=ether10-failover log=no log-prefix=""
8 chain=forward action=drop connection-state=invalid,new in-interface=ether10-failover log=no log-prefix=""
9 ;;; == Gast ISO
chain=forward action=accept in-interface=bridge-gast out-interface=pppoe-out1 log=no log-prefix=""
10 chain=forward action=drop connection-state=invalid,new in-interface=bridge-gast log=no log-prefix=""
11 X ;;; == DMZ ISO
chain=forward action=accept in-interface=ether2-dmz out-interface=pppoe-out1 log=no log-prefix=""
12 X chain=forward action=drop connection-state=invalid,new in-interface=ether2-dmz log=no log-prefix=""
13 chain=forward action=drop out-interface=ether8-mngt log=no log-prefix=""
14 ;;; == Defaults
chain=forward action=accept log=no log-prefix=""
15 chain=input action=accept protocol=udp dst-port=53 log=no log-prefix=""
16 chain=input action=accept protocol=icmp icmp-options=8:0 log=no log-prefix=""
Firewall Nat:
0 ;;; == IPSec Remote Subnet
chain=srcnat action=accept src-address=192.168.10.0/24 dst-address=192.168.70.0/24 log=no log-prefix=""
1 ;;; == SRC NAT
chain=srcnat action=masquerade out-interface=pppoe-out1 log=no log-prefix=""
2 chain=srcnat action=masquerade to-addresses=10.0.0.1 out-interface=ether9-modem log=no log-prefix=""
3 chain=srcnat action=masquerade to-addresses=10.0.1.1 out-interface=ether10-failover log=no log-prefix=""
4 ;;; == Port forwarding
chain=dstnat action=dst-nat to-addresses=192.168.10.50 to-ports=4545 protocol=udp
in-interface=pppoe-out1 dst-port=4545 log=no log-prefix=""
5 chain=dstnat action=dst-nat to-addresses=192.168.2.97 to-ports=38163 protocol=tcp in-interface=pppoe-out1
dst-port=38163 log=no log-prefix=""
6 chain=dstnat action=dst-nat to-addresses=192.168.2.97 to-ports=38164 protocol=udp in-interface=pppoe-out1
dst-port=38164 log=no log-prefix="
IPSec Polices
1 src-address=192.168.10.0/24 src-port=any dst-address=192.168.70.0/24 dst-port=any protocol=all
action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=178.190.87.165
sa-dst-address=77.117.109.238 proposal=default priority=
IPSec Peers
0 address=77.117.109.238/32 local-address=0.0.0.0 passive=no port=500 auth-method=pre-shared-key
secret="psk" generate-policy=no policy-template-group=default exchange-mode=main
send-initial-contact=yes nat-traversal=yes proposal-check=obey hash-algorithm=sha256
enc-algorithm=aes-192,aes-256 dh-group=modp2048 lifetime=1d lifebytes=0 dpd-interval=2m
dpd-maximum-failures=5
IPSsec Proposals
secret="12345678" generate-policy=no policy-template-group=default exchange-mode=main
