Hello all,
I am new to the forum and MikroTik devices in general. I hope therefor I do not ask completely stupid questions.
My issue is similar to this thread, but was not resolved as mentioned : http://forum.mikrotik.com/t/ipsec-site-to-site-can-ping-but-no-other-traffic-flows/96273/1
My IPSec tunnel is enabled between myself (RB2011UiAS) and a cloud provider which device I do not control. I have verified the IPSec policy however does match my own. The tunnel is established fine and I am able to send ICMP traffic to various hosts on both sides.
I have tried removing all DROP rules and I have opened all ports/protocols.
My challenge however is getting any other traffic to work:
- RDP traffic just states “An internal error has occured”
- HTTP - when I browse a HTTP page on the remote network the page is partially loaded and then just stops mid-load (with the browser status indicating that it’s trying to continue loading)
I have applied FORWARD rules to allow all traffic between the two network as well as a SRCNAT from my network to the remote network.
FIREWALL CONFIG:
add chain=input comment=“Allow Limited ICMP for input” limit=50,5:packet protocol=icmp
add chain=forward dst-address=192.168.88.0/24 limit=50,5:packet src-address=172.16.110.0/24
add chain=forward dst-address=172.16.110.0/24 src-address=192.168.88.0/24
add action=drop chain=input comment=“Drop excess ICMP input traffic” protocol=icmp
add chain=input comment=“defconf: accept establieshed,related” connection-state=established,related
add chain=input comment=“allow ipsec” dst-port=500 protocol=udp
add chain=input comment=“allow l2tp” dst-port=1701 protocol=udp
add chain=input comment=“allow pptp” dst-port=1723 protocol=tcp
add chain=input comment=“allow sstp” dst-port=443 protocol=tcp
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=ether1 log-prefix=“DROP - 8 -”
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add chain=forward comment=“defconf: accept established,related” connection-state=established,related
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid log-prefix="DROP - 11 - "
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=ether1 log-prefix=“DROP - 12 -”
/ip firewall mangle
add action=change-mss chain=forward dst-address=172.16.110.0/24 new-mss=1200 protocol=tcp tcp-flags=syn
add chain=srcnat comment=“allow datacentre NAT” dst-address=172.16.110.0/24 log=yes log-prefix="NAT - "
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=ether1
add action=masquerade chain=srcnat comment=“masq. vpn traffic” src-address=192.168.89.0/24
IPSEC CONFIG:
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-192-cbc,aes-192-ctr
/ip ipsec peer
add address=41.77./32 enc-algorithm=aes-256,aes-192 secret=*******
/ip ipsec policy
add dst-address=172.16.110.0/24 sa-dst-address=41.77.***** sa-src-address=154.0.***** src-address=192.168.88.0/24
tunnel=yes
Any ideas of what I can try?
