IPsec tunnel stablished but no traffic
Hi all!
I’ve a Mikrotik router communicating with a CISCO router out of my company, that has been set to form a IPsec VPN tunnel with one of my customers.
I managed to stablish phase 2, but I see no traffic on the tunnel. I went trough some existing posts here on the forum, but none of the solutions actually worked for me.
My PH2 Total shows 1, and the state shows “established”
The downside of this application is that I can’t debug the CISCO router, so I have only the Mikrotik to play with.
Can someone help me if I need to create additional firewall rules or NAT rules?
Thanks!!
Her is my code:
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 lifetime=1h name=VPNPh1 prf-algorithm=sha256
/ip ipsec peer
add address=PEER_IP/32 exchange-mode=ike2 name=VPNPeer profile=VPNPh1
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=1d name=VPNPh2 pfs-group=modp2048
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.1.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="IPsec Accept" protocol=ipsec-esp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip ipsec identity
add peer=VPNPeer secret=PASSKEY
/ip ipsec policy
add dst-address=DEST_IP/32 peer=VPNPeer src-address=SRC_IP/32 tunnel=yes
/ip ipsec policy
Why /32, are you running a GRE tunnel on of the IKEv2 tunell? What configuration instructions have you received from the CISCO admin?
