Hello, I set up a laboratory to test IPsec site to site, with two routers 751.
The tunnel is established correctly, but I do not achieve connectivity between the ends point, no ping.
I established the firewall rules without restrictions, since I only want the IPSec tunnel to work.
Follow the mkt instructions for this version of this link: RouterOS - RouterOS - MikroTik Documentation , the only change its after several attempts with other instructions.
(the only change is that the wan interfaces are in the same network to make it easier.)
R1
Config of each routers and attached verbose export:
jan/02/1970 00:10:03 by RouterOS 6.41.2
software id = 4XFG-ZISK
set [ find default-name=ether1 ] name=ether1-public
add address=192.168.90.1/24 interface=ether1-public network=192.168.90.0
add address=10.1.202.1/24 interface=ether2 network=10.1.202.0
add action=accept chain=forward
add action=accept chain=input
add action=accept chain=output
add action=accept chain=srcnat dst-address=10.1.101.0/24 src-address= 10.1.202.0/24
add action=masquerade chain=srcnat out-interface=ether1-public
/ip firewall raw
add action=notrack chain=prerouting dst-address=10.1.101.0/24 src-address= 10.1.202.0/24
add action=notrack chain=prerouting dst-address=10.1.202.0/24 src-address= 10.1.101.0/24
/ip ipsec peer
add address=192.168.90.100/32 secret=test
/ip ipsec policy
add dst-address=10.1.101.0/24 sa-dst-address=192.168.90.100 sa-src-address= 192.168.90.1 src-address=10.1.202.0/24 tunnel=yes
R2
jan/01/2002 01:16:37 by RouterOS 6.41.2
software id = H1SN-W50H
model = 750UP
/tool user-manager customer
set admin access=
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add address=192.168.90.100/24 interface=ether1 network=192.168.90.0
add address=10.1.101.1/24 interface=ether2 network=10.1.101.0
add action=accept chain=srcnat dst-address=10.1.202.0/24 src-address= 10.1.101.0/24
/ip firewall raw
add action=notrack chain=prerouting dst-address=10.1.202.0/24 src-address=10.1.101.0/24
add action=notrack chain=prerouting dst-address=10.1.101.0/24 src-address=10.1.202.0/24
/ip ipsec peer
add address=192.168.90.1/32 secret=test
/ip ipsec policy
add dst-address=10.1.202.0/24 sa-dst-address=192.168.90.1 sa-src-address= 192.168.90.100 src-address=10.1.101.0/24 tunnel=yes
Thanks for all.
Daniel.
configverboselR2.rsc (27.4 KB)
configverboseR1.rsc (23.9 KB)
