Hi, Just looking for a bit of advice , we have created an ipsec tunnel between a fortigate and a microtik which establishes correctly.
From the microtik side I can ping the fortigate and devices on its network.
From the fortigate side I can ping the microtik but cant get a response from any other devices on that network.
Configured as per http://www.fastbit.ro/en/ipsec-site-to-site-vpn-between-fortigate-and-mikrotik/
I have tried adding a route , and also tried a netmap rule between the ipsec accept rules and the networks masquerading rule with no luck so far.
Any ideas would be greatly appreciated.
config info that might be useful
add chain=input protocol=icmp
add chain=input dst-port=1723 protocol=tcp
add chain=input dst-port=1723 protocol=udp
add chain=input protocol=gre
add chain=input protocol=ipsec-esp
add chain=input comment=“BTest TCP, Winbox.” dst-port=2000,8291 in-interface=
pppoe-out2 protocol=tcp
add chain=input connection-state=established,related
add action=drop chain=input in-interface=pppoe-out2
add chain=forward connection-state=established,related
add action=drop chain=forward connection-nat-state=!dstnat connection-state=
new in-interface=pppoe-out2
add chain=srcnat comment=“ipsec brightstars” dst-address=192.168.45.0/24 log=
yes src-address=192.168.3.0/24
add chain=srcnat comment=“ipsec ngala” dst-address=192.168.1.0/24 log=yes
add action=netmap chain=srcnat dst-address=192.168.3.0/24 log=yes
out-interface=bridge1 to-addresses=192.168.3.254
add action=masquerade chain=srcnat comment=NAT out-interface=pppoe-out2
add action=dst-nat chain=dstnat comment=“PPTP - GSPDC” dst-port=1723
in-interface=pppoe-out2 protocol=tcp to-addresses=192.168.3.4
add action=dst-nat chain=dstnat comment=“PPTP - GSVR01” disabled=yes
dst-port=1723 in-interface=pppoe-out2 protocol=tcp to-addresses=
192.168.4.3
add action=dst-nat chain=dstnat dst-port=5060 in-interface=pppoe-out2
protocol=udp src-address=203.xxx.xxx.xxx/16 to-addresses=192.168.3.205
add action=dst-nat chain=dstnat dst-port=10020-10083 in-interface=pppoe-out2
protocol=udp src-address=203.xxx.xxx.xxx/16 to-addresses=192.168.3.206
add action=dst-nat chain=dstnat comment=“RDP - GPDC” dst-port=3390
in-interface=pppoe-out2 protocol=tcp to-addresses=10.1.1.4 to-ports=3389
add chain=srcnat disabled=yes dst-address=192.168.1.0/24 src-address=
192.168.3.0/24
/ip ipsec peer
add address=203.xxx.xxx.xxx/32 dh-group=modp1536 enc-algorithm=3des secret=
xxxxxxxx
add address=43.xxx.xxx.xxx/32 comment=“ipsec brightstars” dh-group=modp1536
enc-algorithm=3des secret=xxxxxxxx
add address=203.xxx.xxx.xxx/32 comment=“ipsec ngala” dh-group=modp1536
/ip ipsec policy
set 0 disabled=yes
add disabled=yes dst-address=192.168.1.0/24 proposal=proposal1
sa-dst-address=203.xxx.xxx.xxx sa-src-address=202.xxx.xxx.xxx src-address=
192.168.3.0/24 tunnel=yes
add comment=“ipsec brightstars” dst-address=192.168.45.0/24 proposal=
brightstarsipsec sa-dst-address=43.xxx.xxx.xxx sa-src-address=202.xxx.xxx.xxx
src-address=192.168.3.0/24 tunnel=yes
add comment=“ipsec ngala” dst-address=192.168.1.0/24 proposal=ngalaipsec
add comment=“ipsec brightstars” disabled=yes dst-address=192.168.3.0/24
proposal=brightstarsipsec sa-dst-address=43.xxx.xxx.xxx sa-src-address=
202.xxx.xxx.xxx src-address=192.168.45.0/24 tunnel=yes
add comment=“ipsec ngala” disabled=yes dst-address=192.168.3.0/24 proposal=
ngalaipsec sa-dst-address=203.xxx.xxx.xxx sa-src-address=202.xxx.xxx.xxx
src-address=192.168.1.0/24 tunnel=yes
potegos
February 17, 2017, 7:02am
3
Did you resolve the problem? I’ve the same issue.
