Hi, This is my first post, please be patient I am still new to this. I currently have an Ipsec tunnel running on Strongswan between a subnet , that I want to into the mikroTik router.
Does the rb2011il-in support that, and can I keep it only inclusive the subnet the devices are on (the Vpn should only be for devices on 192.168.13.X)?
be aware RB2011 does not support Hardware Acceleration of ipsec, and have a little CPU, the last time i checked RB2011 in the best scenario achieves almost 30mbit per second of ipsec throughput with 100% cpu usage
chechito, from those that support hardware acceleration for AES-CBC encryption SHA256 which would you recommend to get instead of the rb2011il-in?
