IPSEC tunnel with 2 WAN Failover
i have router A with 2 WAN as failover (when WAN1 is down automatically route to internet goes through WAN2) and i have a router B with the exact same setup (2 WAN as failover)
If i create a vpn ipsec tunnel between router A and B and use the mikrotik ddns as remote addresses, is it possible to have failover of the vpn?
When wan1 from router A goes down and the public IP at mikrotik ddns changes, will the ipsec tunnel go up from the 2nd WAN?
Do i need to approach it different?
thanks!
