I have RB1200 in a company connecting to another location via ipsec tunnel, working well. After the vpnfilter etc bugs, I decided to upgrade to last bugfix release 6.40.8, and it completely broke the tunnel - although I am pretty sure I saw something like “established” in ipsec - remote peers after the upgrade, but next morning, the company was totally offline. So I downgraded to 6.37.5, and voila - tunnel up again.
What the hell important has Mikrotik changed between 6.37.5<->6.40.8, that it breaks ipsec tunnels? All I get is
xx.xx.xx.xx peer sent packet for dead phase2
xx.xx.xx.xx failed to pre-process ph2 packet.
I saw some ipsec changes in changelogs, but I have very little space for experimenting, it is production router and I don’t want to break it up again - the company’s core business depends on this tunnel, so all upgrade/downgrade tests muse be done at weekend nights, but then I don’t see the traffic I’d like to see. Has anyone encountered this? Or does anyone know about a change so important, that it breaks ipsec tunnels and must be taken care of?
There was L2TP vpn server before so there are some older settings left, with no effect on the tunnel (at least in 6.37.5), all the tunnel settings are the newer ones under [1].
/ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - inactive, * - default
0 T * group=default src-address=::/0 dst-address=::/0 protocol=all
proposal=default template=yes
1 src-address=192.168.5.0/24 src-port=any dst-address=192.168.1.0/24
dst-port=any protocol=all action=encrypt level=require
ipsec-protocols=ah-esp tunnel=yes sa-src-address=yy.yy.yy.yy
sa-dst-address=xx.xx.xx.xx proposal=xxxxxx priority=0
/ip ipsec peer print
Flags: X - disabled, D - dynamic
0 address=0.0.0.0/0 local-address=0.0.0.0 passive=no port=500
auth-method=pre-shared-key secret=xxxxxx
generate-policy=port-strict policy-template-group=default
exchange-mode=main-l2tp send-initial-contact=yes nat-traversal=yes
hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d
dpd-interval=2m dpd-maximum-failures=5
1 address=xx.xx.xx.xx/32 local-address=0.0.0.0 passive=no port=500
auth-method=pre-shared-key secret=xxxxxx generate-policy=no
policy-template-group=default exchange-mode=main send-initial-contact=yes
nat-traversal=no proposal-check=obey hash-algorithm=sha1
enc-algorithm=aes-256 dh-group=modp1024 lifetime=1d lifebytes=0
/ip ipsec remote-peers print
0 local-address=yy.yy.yy.yy remote-address=xx.xx.xx.xx state=established
side=responder established=8h53m34s
/ip ipsec proposal print
Flags: X - disabled, * - default
0 * name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m
pfs-group=none
1 name="xxxxxx" auth-algorithms=sha1 enc-algorithms=aes-256-cbc
lifetime=30m pfs-group=modp1024
