I am hopping that someone maybe able to help me work out what I am doing wrong setting up a IPsec tunnel between to sites, I am new to MikroTik but found most things easy to setup but the IPsec not so much, I have setup IPsec on other routers and never had any problems
I have read and configured the IPsec tunnel going by the MiktoTik example Site to Site IPsec tunnel, I get a connected I see PH2 Established but no data goes over the link, I have added the NAT and Fasttrack Bypass rule and the /ip firewall raw rule but do not see any data.
Is there some thing in the example that is not right ?
Thank you for any help you can offer
