Ipsec using Router Board and FortiGate.
Hi Guys.
I just would like to know and also if someone have some document on IPSEC vpn between Router Board and FortiGate.
My scenario looks like this i have FortiGate as a VPN server and some Router Boards in Other places that i would like to dial into the FortiGate.
How can i make this possible?
The configuration is simple, http://forum.mikrotik.com/t/ipsec-vpn-mikrotik-rb750-to-cisco-rvs4000-help/54363/1
i tried the IPSEC tunnel with fortigate with some customers and it worked fine.
Hi Vikas.
Thanks very much for your help.
So you manage to get the IPSEC vpn between Router Board and FortiGate, and no problem all working?
I thanks you for your Documentation , i would like to know if you have some more?
Hi Dlabreu
do you need IPSEC template specifically for any Fortigate model.
By the way, you can chk this http://wiki.mikrotik.com/wiki/Manual:IP/IPsec.
Hi Vikas
Thanks for your help , yes i am dialing into a FortiGate-111C
Do you have any template for ipsec vpn , then i can put in my house and try dial to the office.
Hi Dlabreu,
sorry to say that, i donot have any template for Fortigate 111C. The thing which i know is, In ipsec tunnel phase 1 and Phase 2 configuration required.
In Mikrotik you can do the phase-1 configuration in “IP IPSEC peers” and Phase 2 in “IPSEC Policy”.
Phase 2 encryption and authentication is available in proposal.
