I have RB750Gr3 that connects by IpSec to remote site. After 7 hours both SA present, by there is no traffic from remote site.
Flush SA not helps, disabling policy help sometimes for 20-40 minutes, only router reboot helps for another 7 hours.
please help investigate this issue.
I If you provide a config export, it would greatly help to analyse the problem.
Did you setup policies to match the correct subnets and src-nat to allow IPsec to intercept egress packets? How is the remote site configured and do you have control over it?
here is config:
sep/15/2023 09:47:52 by RouterOS 6.49.10
# software id = M959-4B5W
# model = RB750Gr3
# serial number = <removed>
add admin-mac=48:A9:8A:E1:B0:C7 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] loop-protect=off
set [ find default-name=ether3 ] advertise=10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-full,100M-full,1000M-full speed=100Mbps
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec peer
add address=zzz.zz.z.229/32 local-address=xxx.xxx.xx.62 name=Site3
add address=vvv.vv.vv.56/32 local-address=xxx.xxx.xx.62 name=Site1
add address=bbb.bb.bb.110/32 local-address=xxx.xxx.xx.62 name="Site2"
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-128,3des,des lifetime=8h nat-traversal=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1,md5 enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc,3des lifetime=8h pfs-group=none
add enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc,3des name=Site1 pfs-group=none
add address=192.168.0.1/24 comment=defconf interface=bridge network=192.168.0.0
add address=xxx.xxx.xx..62/30 interface=ether1 network=xxx.xxx.xx..60
add address=yyy.yyy.yyy.202/30 interface=ether2 network=yyy.yyy.yyy.200
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
add action=fasttrack-connection chain=forward connection-state=established disabled=yes
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input connection-state=established,related,untracked
add action=accept chain=forward comment="IpSec internal traffic" dst-address=10.1.1.0/24 src-address=192.168.0.0/24
add action=accept chain=forward dst-address=192.168.11.0/24 src-address=192.168.0.0/24
add action=accept chain=forward dst-address=192.168.0.0/24 src-address=192.168.11.0/24
add action=accept chain=forward disabled=yes dst-address=192.168.0.0/24 src-address=10.1.1.0/24
add action=accept chain=input comment="rr allow" dst-port=rr protocol=tcp
add action=accept chain=input src-address=vvv.vv.vv..56
add action=accept chain=input src-address=zzz.zz.z.229
add action=accept chain=input comment="SMTP in" connection-nat-state="" disabled=yes dst-port=25 log=yes protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN log=yes
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=change-mss chain=forward comment="Change MTU for the tunel" dst-address=192.168.11.0/24 log=yes new-mss=1408 passthrough=yes protocol=tcp src-address=192.168.0.0/24 tcp-flags=syn tcp-mss=!0-1408
add action=change-mss chain=forward dst-address=192.168.0.0/24 new-mss=1408 passthrough=yes protocol=tcp src-address=192.168.11.0/24 tcp-flags=syn tcp-mss=!0-1408
add action=mark-connection chain=input comment=" ISP_ether1_inbound" in-interface=ether1 new-connection-mark=" ether1_inbound" passthrough=yes
add action=mark-connection chain=input comment=" ISP_ether2_inbound" in-interface=ether2 new-connection-mark=" ether2_inbound" passthrough=yes
add action=mark-routing chain=output comment=" ether1_outbound" connection-mark=" ether1_inbound" new-routing-mark=" ether1_outbound" passthrough=yes
add action=mark-routing chain=output comment=" ether2_outbound" connection-mark=" ether2_inbound" new-routing-mark=" ether2_outbound" passthrough=yes
add action=mark-routing chain=prerouting comment=Lan_loadBalancer2/0 dst-address-type=!local in-interface=bridge new-routing-mark=ether1_outbound passthrough=yes per-connection-classifier=both-addresses-and-ports:2/0
add action=mark-routing chain=prerouting comment=Lan_loadBalancer2/1 dst-address-type=!local in-interface=bridge new-routing-mark=ether2_outbound passthrough=yes per-connection-classifier=both-addresses-and-ports:2/1
add action=dst-nat chain=dstnat comment="Incoming SMTP" dst-address=xxx.xxx.xx..62 dst-port=25 log=yes protocol=tcp to-addresses=192.168.11.100 to-ports=25
add action=src-nat chain=srcnat dst-address=192.168.11.100 dst-port=25 log=yes protocol=tcp src-address=!192.168.0.0/24 to-addresses=192.168.0.1
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xx..62 dst-port=443 protocol=tcp to-addresses=192.168.11.100 to-ports=443
add action=src-nat chain=srcnat dst-address=192.168.11.100 dst-port=443 protocol=tcp src-address=!192.168.0.0/24 to-addresses=192.168.0.1
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add action=accept chain=srcnat dst-address=192.168.11.0/24 src-address=192.168.0.0/24
add action=accept chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.11.0/24
add action=accept chain=srcnat dst-address=10.1.1.0/24 src-address=192.168.0.0/24
add action=masquerade chain=srcnat out-interface=ether2
/ip firewall raw
add action=notrack chain=output ipsec-policy=out,ipsec
add action=notrack chain=prerouting dst-address=192.168.0.2-192.168.0.254 ipsec-policy=in,ipsec src-address=192.168.11.0/24
/ip ipsec identity
add notrack-chain=prerouting peer=Site1
add notrack-chain=prerouting peer=Site3
add generate-policy=port-strict notrack-chain=prerouting peer="Site2"
/ip ipsec policy
set 0 disabled=yes
add dst-address=10.1.1.0/24 peer=Site3 src-address=192.168.0.0/24 tunnel=yes
add dst-address=192.168.11.0/24 peer=Site1 proposal=Site1 src-address=192.168.0.0/24 tunnel=yes
add dst-address=192.168.7.0/24 peer="Site2" src-address=192.168.0.0/24 tunnel=yes
add distance=1 gateway=xxx.xxx.xx..61 routing-mark=ether1_outbound
add distance=1 gateway=yyy.yyy.yyy.201 routing-mark=ether2_outbound
/ip service
set www port=rr
/system clock
set time-zone-name=Europe/Kiev
/system identity
set name=RouterOS
/system logging
set 0 topics=ipsec
add topics=info
add topics=interface
/tool graphing interface
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=ether1 filter-ip-address=192.168.0.1/32,192.168.11.100/32 filter-ip-protocol=tcp filter-port=smtp
remote site is Windows servers, i have control on it. i have other Mikrotik routers that connect to Windows server and they don have such problem, This router have 2 ISP connected to ether1 and ether 2. Internet for internal users working fine.
Thanks. A brief description of the network topology would be helpful for getting an idea of how everything is connected and which site that is problematic, for example:
Wan xx Wan xx
Wan xx Wan xx
Wan xx Wan xx
Ps..
I’m about to travel soon so I’ll have to get back to you next week. In the meantime someone else might be able to help you out
Thanks Larsa for reply.
i’m interested with site1 connection.
network topology:
<hex local sub-net 192.16.0.0/24 ipsec> Wan xxx.xxx.xx.62 Wan vvv.vv.vv.56/32 <windows SITE1 ipsec local subnet 192.168.11.0/24.>
is the any suggestions to fix this problem?
