I am on hex s 7.1.3.
I have configured an IPsec tunnel to NordVPN following the guide at https://support.nordvpn.com/Connectivity/Router/1360295132/MikroTik-IKEv2-setup-with-NordVPN.htm
Everything seems ok, but I need a way to temporarily disable the tunnel when I need to access the whole download bandwidth (it drops from 320mbps to about 90mbps).
For now the only solution I have come across is to split the address list into single ips (I usually need to download from 2 or 3 devices) and disable the list entry when needed. This seems to not work (traffic is still routed even for disabled entries) unless I kill the tunnel/restart.
Completely killing the tunnel is also fine
Any suggestion ?
Giuliano
