IPSec VPN latency issues
Hey guys,
Having some latency issues with an IPSec VPN between a RB750GL → RB1200. Both are running ROS 5.14, both with newest firmware. The VPN works without a problem, except for the latency rise.
Pinging RB750GL → RB1200 - WAN interfaces - 41ms average over 200 packets.
Pinging RB750GL → RB1200 - inside the VPN - 59ms average over 200 packets.
Config on the 750GL:
/ip ipsec peer
address=1200-WAN_IP/32 port=500 auth-method=pre-shared-key secret="password" generate-policy=no exchange-mode=main send-initial-contact=yes nat-traversal=no my-id-user-fqdn="" proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
/ip ipsec policy> print
src-address=192.168.2.0/24 src-port=any dst-address=192.168.1.0/24 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=750GL-WAN_IP sa-dst-address=1200-WAN_IP proposal=default priority=0
/ip ipsec proposal> print
* name="default" auth-algorithms=sha1 enc-algorithms=aes-128 lifetime=30m pfs-group=modp1024
Config on the 1200:
/ip ipsec peer> print
address=750GL-WAN_IP/32 port=500 auth-method=pre-shared-key secret="password" generate-policy=no exchange-mode=main send-initial-contact=yes nat-traversal=no my-id-user-fqdn="" proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
src-address=192.168.1.0/24 src-port=any dst-address=192.168.2.0/24 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=1200-WAN_IP sa-dst-address=750GL-WAN_IP proposal=default priority=0
Is this much latency added normal? I tried with 3DES for proposal (phase2) encryption, and it was the same.
Thanks,
tom
Any help would be appreciated.
Thanks guys,
tom
I am also having a similar issue with 450G. My pings are typically 60ms on WAN, and over IPSEC LAN jumps all the way to 200-300ms with minimal cpu usage at the time of issue.
It seems as thought 1 particular IPSEC peer seems to cause the latency, with this peer disabled the spikes do not happen.
What ethernet ports are you using for your wan on the RB1200 ? i was having latency problems with mine which was running on ether10. after i changed it over to ether5 it no longer occured
Issue happends on both ether10 and ether9 ports. Havent tried any other ports.
It is worth trying other ports on this unit:
http://forum.mikrotik.com/t/rb1200-packetloss-issue/55250/1
