IPsec VPN site to site
I am trying to setup a site to site VPN using Untangle version 11.2 as the server and a Mikrotik v6.32.3
I ran through the setup guide here https://www.nasa-security.net/mikrotik/l2tp-ipsec-vpn-site-to-site-mikrotik-how-to/
I have attached a screenshot of the log and the error I’m getting.
fatal NO-PROPOSAL-CHOSEN notify message, phase 1 should be deleted.
I have obviously made a mistake somewhere but I’m not sure where to start.
Any help would be greatly appreciated
Have you tried this setup?
http://gregsowell.com/wp-content/plugins/download-monitor/download.php?id=15
I can get the routers to ping but can’t get any devices behind them to see the other side of the tunnel.
Helle,
The src-address seems to be wrong, we can see in your logs 192.168.1.2. It should be a WAN IP.
Regards,
Hi
I was able to make a VPN IPSec with this conf:
router_1
/ip ipsec policy>add src-address=<local_lan_router_1>/xx dst-address=<local_lan_router_2>/xx protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=<public_ip_router_1> sa-dst-address=<public_ip_router_2> proposal=default
priority=0
/ip ipsec peer>add address=<public_ip_router_2> port=500 auth-method=pre-shared-key secret="some_password" exchange-mode=main send-initial-contact=yes proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 dpd-interval=
120 dpd-maximum-failures=5
/ip firewall nat>add chain=srcnat src-address=<local_lan_router_1>/xx dst-address=<local_lan_router_2>/xx action=accept disabled=no
router_2
/ip ipsec policy>add src-address=<local_lan_router_2>/xx dst-address=<local_lan_router_1>/xx protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=<public_ip_router_2> sa-dst-address=<public_ip_router_1> proposal=default
priority=0
/ip ipsec peer>add address=<public_ip_router_1> port=500 auth-method=pre-shared-key secret="some_password" exchange-mode=main send-initial-contact=yes proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 dpd-interval=
/ip firewall nat>add chain=srcnat src-address=<local_lan_router_2>/xx dst-address=<local_lan_router_1>/xx action=accept disabled=no
Regards
