IPSEC VPN to Checkpoint R77.30 using certificates
Hi. I am trying to set up VPN to checkpoint using mikrotik. I have simple setup in LAB:
10.10.10.0/24 - checkpoint - 172.16.3.0/24 - router in between - 192.168.100.0/24 - mikrotik - 192.168.88.0/24
I want to be able to communicate between 192.168.88.0/24 - 10.10.10.0/24. I have managed to get VPN working using PSK, however I am struggling to get it working using certificates. On checkpoint, I have created interoperable device with dynamic address since that “router in between” will simulate 3G router with dynamic address, but mikrotik will always use static address on wan/lan interface. I have also created community that mikrotik is part of, with correct matching criteria (DN). External CA is imported to the checkpoint, certificate for Mikrotik together with key are imported to Mikrotik.,
Mikrotik is failing to establish connection. Checkpoint shows only brief info in log:
Number:                        	27422
Date:                             	10Nov2016
Time:                             	9:04:08
Interface:                       	daemon
Origin:                           	FW_B
Type:                             	Log
Action:                           	Key Install
Source:                         	FW_B (10.10.10.3)
Destination:                  	172.16.3.10
Information:                  	IKE: Main Mode Sent Notification to Peer: invalid id information
Encryption Scheme:     	IKE
IKE Initiator Cookie:      	95e3a174948b0d05
IKE Responder Cookie:	268787f359c4752e
VPN Peer Gateway:      	172.16.3.10
Subproduct:                  	VPN
VPN Feature:                 	IKE
Product:                        	Security Gateway/Management
Product Family:            	Network
Here is mikrotik’s IPsec debug:
Nov/10/2016 09:04:14 ipsec,debug,packet ===
Nov/10/2016 09:04:14 ipsec,debug initiate new phase 1 negotiation: 192.168.100.1[500]<=>172.16.3.1[500]
Nov/10/2016 09:04:14 ipsec,debug begin Identity Protection mode.
Nov/10/2016 09:04:14 ipsec,debug,packet new cookie:
Nov/10/2016 09:04:14 ipsec,debug,packet 95e3a174948b0d05
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 56, next type 13
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 16, next type 13
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 16, next type 0
Nov/10/2016 09:04:14 ipsec,debug,packet 348 bytes from 192.168.100.1[500] to 172.16.3.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet sockname 192.168.100.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet send packet from 192.168.100.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet send packet to 172.16.3.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet src4 192.168.100.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet dst4 172.16.3.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet 1 times of 348 bytes message will be sent to 172.16.3.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet 95e3a174 948b0d05 00000000 00000000 01100200 00000000 0000015c 0d00003c
Nov/10/2016 09:04:14 ipsec,debug,packet 00000001 00000001 00000030 01010001 00000028 01010000 800b0001 000c0004
Nov/10/2016 09:04:14 ipsec,debug,packet 00015180 80010007 800e0100 80030003 80020002 80040002 0d000014 4a131c81
Nov/10/2016 09:04:14 ipsec,debug,packet 07035845 5c5728f2 0e95452f 0d000014 8f8d8382 6d246b6f c7a8a6a4 28c11de8
Nov/10/2016 09:04:14 ipsec,debug,packet 0d000014 439b59f8 ba676c4c 7737ae22 eab8f582 0d000014 4d1e0e13 6deafa34
Nov/10/2016 09:04:14 ipsec,debug,packet c4f3ea9f 02ec7285 0d000014 80d0bb3d ef54565e e84645d4 c85ce3ee 0d000014
Nov/10/2016 09:04:14 ipsec,debug,packet 9909b64e ed937c65 73de52ac e952fa6b 0d000014 7d9419a6 5310ca6f 2c179d92
Nov/10/2016 09:04:14 ipsec,debug,packet 15529d56 0d000014 cd604643 35df21f8 7cfdb2fc 68b6a448 0d000014 90cb8091
Nov/10/2016 09:04:14 ipsec,debug,packet 3ebb696e 086381b5 ec427b1f 0d000014 16f6ca16 e4a4066d 83821a0f 0aeaa862
Nov/10/2016 09:04:14 ipsec,debug,packet 0d000014 4485152d 18b6bbcd 0be8a846 9579ddcc 0d000014 12f5f28c 457168a9
Nov/10/2016 09:04:14 ipsec,debug,packet 702d9fe2 74cc0100 00000014 afcad713 68a1f1c9 6b8696fc 77570100
Nov/10/2016 09:04:14 ipsec,debug sent phase1 packet 192.168.100.1[500]<=>172.16.3.1[500] 95e3a174948b0d05:0000000000000000
Nov/10/2016 09:04:14 ipsec,debug,packet ==========
Nov/10/2016 09:04:14 ipsec,debug,packet 128 bytes message received from 172.16.3.1[500] to 192.168.100.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet 95e3a174 948b0d05 268787f3 59c4752e 01100200 00000000 00000080 0d00003c
Nov/10/2016 09:04:14 ipsec,debug,packet 00015180 80010007 800e0100 80030003 80020002 80040002 0d000014 4048b7d5
Nov/10/2016 09:04:14 ipsec,debug,packet 6ebce885 25e7de7f 00d6c2d3 00000014 90cb8091 3ebb696e 086381b5 ec427b1f
Nov/10/2016 09:04:14 ipsec,debug,packet begin.
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=1(sa) len=60
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=13(vid) len=20
Nov/10/2016 09:04:14 ipsec,debug,packet succeed.
Nov/10/2016 09:04:14 ipsec,debug received Vendor ID: FRAGMENTATION
Nov/10/2016 09:04:14 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
Nov/10/2016 09:04:14 ipsec,debug 172.16.3.1 Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02
Nov/10/2016 09:04:14 ipsec,debug,packet total SA len=56
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=2(prop) len=48
Nov/10/2016 09:04:14 ipsec,debug,packet proposal #1 len=48
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=3(trns) len=40
Nov/10/2016 09:04:14 ipsec,debug,packet transform #1 len=40
Nov/10/2016 09:04:14 ipsec,debug,packet type=Life Type, flag=0x8000, lorv=seconds
Nov/10/2016 09:04:14 ipsec,debug,packet type=Life Duration, flag=0x0000, lorv=4
Nov/10/2016 09:04:14 ipsec,debug,packet type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
Nov/10/2016 09:04:14 ipsec,debug,packet encryption(aes)
Nov/10/2016 09:04:14 ipsec,debug,packet type=Key Length, flag=0x8000, lorv=256
Nov/10/2016 09:04:14 ipsec,debug,packet type=Authentication Method, flag=0x8000, lorv=RSA signatures
Nov/10/2016 09:04:14 ipsec,debug,packet type=Hash Algorithm, flag=0x8000, lorv=SHA
Nov/10/2016 09:04:14 ipsec,debug,packet hash(sha1)
Nov/10/2016 09:04:14 ipsec,debug,packet type=Group Description, flag=0x8000, lorv=1024-bit MODP group
Nov/10/2016 09:04:14 ipsec,debug,packet dh(modp1024)
Nov/10/2016 09:04:14 ipsec,debug,packet pair 1:
Nov/10/2016 09:04:14 ipsec,debug,packet  0x4a8d78: next=(nil) tnext=(nil)
Nov/10/2016 09:04:14 ipsec,debug,packet proposal #1: 1 transform
Nov/10/2016 09:04:14 ipsec,debug,packet prop#=1, prot-id=ISAKMP, spi-size=0, #trns=1
Nov/10/2016 09:04:14 ipsec,debug,packet trns#=1, trns-id=IKE
Nov/10/2016 09:04:14 ipsec,debug,packet Compared: Local:Peer
Nov/10/2016 09:04:14 ipsec,debug,packet (lifetime = 86400:86400)
Nov/10/2016 09:04:14 ipsec,debug,packet (lifebyte = 0:0)
Nov/10/2016 09:04:14 ipsec,debug,packet enctype = AES-CBC:AES-CBC
Nov/10/2016 09:04:14 ipsec,debug,packet (encklen = 256:256)
Nov/10/2016 09:04:14 ipsec,debug,packet hashtype = SHA:SHA
Nov/10/2016 09:04:14 ipsec,debug,packet authmethod = RSA signatures:RSA signatures
Nov/10/2016 09:04:14 ipsec,debug,packet dh_group = 1024-bit MODP group:1024-bit MODP group
Nov/10/2016 09:04:14 ipsec,debug,packet an acceptable proposal found.
Nov/10/2016 09:04:14 ipsec,debug,packet agreed on RSA signatures auth.
Nov/10/2016 09:04:14 ipsec,debug,packet compute DH's private.
Nov/10/2016 09:04:14 ipsec,debug,packet 5e55cf1a ebf90294 ffc0aad9 a4a10c87 d98d72c0 7e692475 ad7259dd 76d8e640
Nov/10/2016 09:04:14 ipsec,debug,packet 26703a6d 812f9476 bcf6c524 30ba4738 23e0b729 b3297ba3 9bea72f2 f9badf13
Nov/10/2016 09:04:14 ipsec,debug,packet 48b8ac49 94c6e740 82799348 b2c152f6 b87663e5 e2e14e22 ef337304 51f9f372
Nov/10/2016 09:04:14 ipsec,debug,packet 34fab837 52b9386a e1e529c5 37ab8810 05f59c27 a887c15a b6298c40 f3656ceb
Nov/10/2016 09:04:14 ipsec,debug,packet compute DH's public.
Nov/10/2016 09:04:14 ipsec,debug,packet 3bdb5be4 c3048c55 1a4a53ba 684ad799 1c3b9648 dd255f46 48a0e318 134b9d1c
Nov/10/2016 09:04:14 ipsec,debug,packet 9e63b49e 99d81f22 f0c5070b 146b0d6e 03354c59 d6c6a4b8 3001e701 8d1cf4ec
Nov/10/2016 09:04:14 ipsec,debug,packet 772b3361 4f5b85b3 2e228e1c 9d7cf7ff fa2eb298 194fe062 1209dd26 53999300
Nov/10/2016 09:04:14 ipsec,debug,packet a1a03701 b8b42245 cf08bb3e 0704c736 2101cc6d 54977064 a6c47a77 de5e4250
Nov/10/2016 09:04:14 ipsec,debug 172.16.3.1 Hashing 172.16.3.1[500] with algo #2
Nov/10/2016 09:04:14 ipsec,debug 192.168.100.1 Hashing 192.168.100.1[500] with algo #2
Nov/10/2016 09:04:14 ipsec,debug Adding remote and local NAT-D payloads.
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 128, next type 10
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 24, next type 130
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 20, next type 130
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 20, next type 0
Nov/10/2016 09:04:14 ipsec,debug,packet 236 bytes from 192.168.100.1[500] to 172.16.3.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet 1 times of 236 bytes message will be sent to 172.16.3.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet 95e3a174 948b0d05 268787f3 59c4752e 04100200 00000000 000000ec 0a000084
Nov/10/2016 09:04:14 ipsec,debug,packet 8200001c e4ce8a12 121253c2 47abe853 076ac7c4 95579ca2 d72ca77c 82000018
Nov/10/2016 09:04:14 ipsec,debug,packet c25993c1 52ee03df 76d10cf7 05a2a357 786532fe 00000018 513ba85d ca0afd96
Nov/10/2016 09:04:14 ipsec,debug,packet efa4a7a1 a9a0d4c5 12bafcc5
Nov/10/2016 09:04:14 ipsec,debug sent phase1 packet 192.168.100.1[500]<=>172.16.3.1[500] 95e3a174948b0d05:268787f359c4752e
Nov/10/2016 09:04:14 ipsec,debug,packet 378 bytes message received from 172.16.3.1[500] to 192.168.100.1[500]
Nov/10/2016 09:04:14 ipsec,debug,packet 95e3a174 948b0d05 268787f3 59c4752e 04100200 00000000 0000017a 0a000084
Nov/10/2016 09:04:14 ipsec,debug,packet 4cd15be6 a9363aab 734daeb7 9dabee6e ebbb05f1 537c4631 e5bb4956 e0430a0a
Nov/10/2016 09:04:14 ipsec,debug,packet 9d1d173a d040f919 e582c688 3ffbffea 627cc4f3 b9af0aab b2cc3c18 36cc92ff
Nov/10/2016 09:04:14 ipsec,debug,packet 97851e97 0389a730 edfbb7df 7b9aceea 3a3faf30 c5893fd0 e281be1b fce3c1b2
Nov/10/2016 09:04:14 ipsec,debug,packet e67a6203 9461cd67 633f23db 74776000 80e1d3ac d9d30c3d 25916016 f2170f64
Nov/10/2016 09:04:14 ipsec,debug,packet 07000018 157773f7 f1393e29 821c9f2f 460d153d d61e3860 0700001e 04301731
Nov/10/2016 09:04:14 ipsec,debug,packet 15301306 0355040a 130c4d47 4d542e2e 79746775 64690700 006f0430 68310b30
Nov/10/2016 09:04:14 ipsec,debug,packet 09060355 04061302 534b3111 300f0603 5504080c 08536c6f 76616b69 61311330
Nov/10/2016 09:04:14 ipsec,debug,packet 11060355 040a0c0a 46697273 74204461 7461310c 300a0603 55040b0c 034e5353
Nov/10/2016 09:04:14 ipsec,debug,packet 31233021 06035504 030c1a46 69727374 20446174 6120496e 7465726d 65646961
Nov/10/2016 09:04:14 ipsec,debug,packet 74652043 41820000 05048200 001893a5 d87f281a e6fda0c8 f880b905 ea1e7933
Nov/10/2016 09:04:14 ipsec,debug,packet e2f60000 0018c259 93c152ee 03df76d1 0cf705a2 a3577865 32fe
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=4(ke) len=132
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=10(nonce) len=24
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=7(cr) len=30
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=7(cr) len=111
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=7(cr) len=5
Nov/10/2016 09:04:14 ipsec,debug,packet seen nptype=130(nat-d) len=24
Nov/10/2016 09:04:14 ipsec,debug,packet CR saved:
Nov/10/2016 09:04:14 ipsec,debug,packet 30173115 30130603 55040a13 0c4d474d 542e2e79 74677564 69
Nov/10/2016 09:04:14 ipsec,debug,packet 3068310b 30090603 55040613 02534b31 11300f06 03550408 0c08536c 6f76616b
Nov/10/2016 09:04:14 ipsec,debug,packet 69613113 30110603 55040a0c 0a466972 73742044 61746131 0c300a06 0355040b
Nov/10/2016 09:04:14 ipsec,debug,packet 0c034e53 53312330 21060355 04030c1a 46697273 74204461 74612049 6e746572
Nov/10/2016 09:04:14 ipsec,debug,packet 6d656469 61746520 4341
Nov/10/2016 09:04:14 ipsec,debug NAT-D payload #0 doesn't match
Nov/10/2016 09:04:14 ipsec,debug NAT-D payload #1 verified
Nov/10/2016 09:04:14 ipsec,debug NAT detected: ME
Nov/10/2016 09:04:14 ipsec,debug KA list add: 192.168.100.1[4500]->172.16.3.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet 172.16.3.1 peer transmitted CR: X.509 Certificate Signature
Nov/10/2016 09:04:14 ipsec,debug,packet compute DH's shared.
Nov/10/2016 09:04:14 ipsec,debug,packet 074b4d30 07fe556a 8c8f119b 9d1228f5 51fdedb2 fc95a801 a3fe57ec 8c20d47f
Nov/10/2016 09:04:14 ipsec,debug,packet 1ea76072 fde70384 ca4161ff 95fb372b 83a20b8a 133366d6 ede0ce0f c31191a1
Nov/10/2016 09:04:14 ipsec,debug,packet cdb03d05 428f0fdf 64920397 9a6e76cb 65f223ea ad554191 f916b4de 3d5b45bf
Nov/10/2016 09:04:14 ipsec,debug,packet cc9a3ee4 ace04212 51ce2288 e1012968 18a54254 dcb20271 fb237d54 4eb60773
Nov/10/2016 09:04:14 ipsec,debug,packet nonce1:
Nov/10/2016 09:04:14 ipsec,debug,packet e4ce8a12 121253c2 47abe853 076ac7c4 95579ca2 d72ca77c
Nov/10/2016 09:04:14 ipsec,debug,packet nonce2:
Nov/10/2016 09:04:14 ipsec,debug,packet 157773f7 f1393e29 821c9f2f 460d153d d61e3860
Nov/10/2016 09:04:14 ipsec,debug,packet hmac(hmac_sha1)
Nov/10/2016 09:04:14 ipsec,debug,packet SKEYID computed:
Nov/10/2016 09:04:14 ipsec,debug,packet 98e1e50a 075547d7 95d0237a 32a56f77 bb2dad32
Nov/10/2016 09:04:14 ipsec,debug,packet SKEYID_d computed:
Nov/10/2016 09:04:14 ipsec,debug,packet 0905c833 7595d362 ed3a5f20 ba42108e 97e4b421
Nov/10/2016 09:04:14 ipsec,debug,packet SKEYID_a computed:
Nov/10/2016 09:04:14 ipsec,debug,packet 9d6147d6 6fd78b9a 97359d43 e3c57bcb 8b46d8b9
Nov/10/2016 09:04:14 ipsec,debug,packet SKEYID_e computed:
Nov/10/2016 09:04:14 ipsec,debug,packet 145fb67f 6a2a185c 7448261e 0ced36b3 58ddf4f2
Nov/10/2016 09:04:14 ipsec,debug,packet len(SKEYID_e) < len(Ka) (20 < 32), generating long key (Ka = K1 | K2 | ...)
Nov/10/2016 09:04:14 ipsec,debug,packet compute intermediate encryption key K1
Nov/10/2016 09:04:14 ipsec,debug,packet ebd27d71 2890ccf1 d6c38266 664131f3 a6a507e9
Nov/10/2016 09:04:14 ipsec,debug,packet compute intermediate encryption key K2
Nov/10/2016 09:04:14 ipsec,debug,packet bd7139d5 02255597 9310b4a6 eb98e9c7 7ea07d7e
Nov/10/2016 09:04:14 ipsec,debug,packet final encryption key computed:
Nov/10/2016 09:04:14 ipsec,debug,packet ebd27d71 2890ccf1 d6c38266 664131f3 a6a507e9 bd7139d5 02255597 9310b4a6
Nov/10/2016 09:04:14 ipsec,debug,packet IV computed:
Nov/10/2016 09:04:14 ipsec,debug,packet e0167c62 b6229943 5fa7dba3 c692f561
Nov/10/2016 09:04:14 ipsec,debug,packet use ID type of FQDN
Nov/10/2016 09:04:14 ipsec,debug,packet HASH with:
Nov/10/2016 09:04:14 ipsec,debug,packet 95e3a174 948b0d05 268787f3 59c4752e 00000001 00000001 00000030 01010001
Nov/10/2016 09:04:14 ipsec,debug,packet 00000028 01010000 800b0001 000c0004 00015180 80010007 800e0100 80030003
Nov/10/2016 09:04:14 ipsec,debug,packet 80020002 80040002 02000000 3139322e 3136382e 3130302e 31
Nov/10/2016 09:04:14 ipsec,debug,packet HASH computed:
Nov/10/2016 09:04:14 ipsec,debug,packet 13e81aab 21aeed42 d5e6d659 d0194bd7 0ba122de
Nov/10/2016 09:04:14 ipsec,debug,packet Certificate:
Nov/10/2016 09:04:14 ipsec,debug,packet     Data:
Nov/10/2016 09:04:14 ipsec,debug,packet         Version: 3 (0x2)
Nov/10/2016 09:04:14 ipsec,debug,packet         Serial Number: 4100 (0x1004)
Nov/10/2016 09:04:14 ipsec,debug,packet     Signature Algorithm: sha256WithRSAEncryption
Nov/10/2016 09:04:14 ipsec,debug,packet         Issuer: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Nov/10/2016 09:04:14 ipsec,debug,packet         Validity
Nov/10/2016 09:04:14 ipsec,debug,packet             Not Be
Nov/10/2016 09:04:14 ipsec,debug,packet fore: Nov  8 14:07:57 2016 GMT
Nov/10/2016 09:04:14 ipsec,debug,packet             Not After : Nov  3 14:07:57 2036 GMT
Nov/10/2016 09:04:14 ipsec,debug,packet         Subject: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Nov/10/2016 09:04:14 ipsec,debug,packet         Subject Public Key Info:
Nov/10/2016 09:04:14 ipsec,debug,packet             Public Key Algorithm: rsaEncryption
Nov/10/2016 09:04:14 ipsec,debug,packet      Public-Key: (2048 bit)
Nov/10/2016 09:04:14 ipsec,debug,packet                 Modulus:
Nov/10/2016 09:04:14 ipsec,debug,packet                     00:bb:88:eb:a3:a5:0b:57:74:19:02:bd:64:65:db:
Nov/10/2016 09:04:14 ipsec,debug,packet                     d9:3e:e3:05:c6:a7:dc:29:bb:47:80:1a:86:ba:d7:
Nov/10/2016 09:04:14 ipsec,debug,packet                     c3:53:5e:05:6f:95:d6:10:91:60:7a:9d:b3:35:bd:
Nov/10/2016 09:04:14 ipsec,debug,packet                bf:ea:dc:cb:50:6e:2f:9c:c4:aa:42:dd:7b:bb:fe:
Nov/10/2016 09:04:14 ipsec,debug,packet                     23:eb:ab:7d:a1:8b:7a:e9:77:48:37:6b:d3:79:21:
Nov/10/2016 09:04:14 ipsec,debug,packet                     88:f3:b3:72:79:55:76:74:b2:81:3a:82:27:bc:4f:
Nov/10/2016 09:04:14 ipsec,debug,packet                     5a:79:94:e7:5f:fe:60:cc:52:2a:ba:a0:b9:d4
Nov/10/2016 09:04:14 ipsec,debug,packet created CERT payload:
Nov/10/2016 09:04:14 ipsec,debug,packet 04308204 67308202 4fa00302 01020202 1004300d 06092a86 4886f70d 01010b05
Nov/10/2016 09:04:14 ipsec,debug,packet 00306831 0b300906 03550406 1302534b 3111300f 06035504 080c0853 6c6f7661
Nov/10/2016 09:04:14 ipsec,debug,packet 6b696131 13301106 0355040a 0c0a4669 72737420 44617461 310c300a 06035504
Nov/10/2016 09:04:14 ipsec,debug,packet 0b0c034e 53533123 30210603 5504030c 1a466972 73742044 61746120 496e7465
Nov/10/2016 09:04:14 ipsec,debug,packet 726d6564 69617465 20434130 1e170d31 36313130 38313430 3735375a 170d3336
Nov/10/2016 09:04:14 ipsec,debug,packet 31313033 31343037 35375a30 6b310b30 09060355 04061302 534b3111 300f0603
Nov/10/2016 09:04:14 ipsec,debug,packet 5504080c 08536c6f 76616b69 61311330 11060355 04070c0a 42726174 69736c61
Nov/10/2016 09:04:14 ipsec,debug,packet 76613113 30110603 55040a0c 0a466972 73742044 61746131 0c300a06 0355040b
Nov/10/2016 09:04:14 ipsec,debug,packet 0c034e53 53311130 0f060355 04030c08 5336414b 30303035 30820122 300d0609
Nov/10/2016 09:04:14 ipsec,debug,packet 2a864886 f70d0101 01050003 82010f00 3082010a 02820101 00bb88eb a3a50b57
Nov/10/2016 09:04:14 ipsec,debug,packet 741902bd 6465dbd9 3ee305c6 a7dc29bb 47801a86 bad7c353 5e056f95 d6109160
Nov/10/2016 09:04:14 ipsec,debug,packet 7a9db335 bdbfeadc cb506e2f 9cc4aa42 dd7bbbfe 23ebab7d a18b7ae9 7748376b
Nov/10/2016 09:04:14 ipsec,debug,packet d3792188 f3b37279 557674b2 813a8227 bc4f5a79 94e75ffe 60cc522a baa0b9d4
Nov/10/2016 09:04:14 ipsec,debug,packet d17f7bdd 1a141844 87084954 b568f47c 23b212e8 4d30b4c9 fe685cb8 828f018c
Nov/10/2016 09:04:14 ipsec,debug,packet 12a31fa7 e05fcc17 9372a08d 977f345e bc187ebc 5eaf887b 5012341a 86a4328d
Nov/10/2016 09:04:14 ipsec,debug,packet 08f22bf2 054ea583 099de4dc a8187893 b619e016 25e94695 494c504a e5b20ca0
Nov/10/2016 09:04:14 ipsec,debug,packet 708fce04 61bf0db5 a445a204 1e470cfc ff53000c 120a2d0b 769b862d 06f6d108
Nov/10/2016 09:04:14 ipsec,debug,packet e410c7ec bb1d0ebf eb9bae22 76badabd 49b6f83f f0d94702 f5020301 0001a318
Nov/10/2016 09:04:14 ipsec,debug,packet 30163014 0603551d 11040d30 0b820953 36414b30 30303541 300d0609 2a864886
Nov/10/2016 09:04:14 ipsec,debug,packet f70d0101 0b050003 82020100 0da8fe8b d04b51cb e24bba48 9bc73f45 160b24ce
Nov/10/2016 09:04:14 ipsec,debug,packet f8546c21 da573d45 11552770 80ab1f24 7a45542e b331d9a9 f7e735af 498028ef
Nov/10/2016 09:04:14 ipsec,debug,packet 8cb4a447 37ad85d1 4e0edb08 3bfac14c 3e8938d9 920cd6a4 a5fc3876 b262bf3d
Nov/10/2016 09:04:14 ipsec,debug,packet 92b4ab17 c2149659 d5e64da0 50ca9e9f c3ba07da dce37a88 afcc4065 b0628fcc
Nov/10/2016 09:04:14 ipsec,debug,packet c0e2ab74 9f29d4b2 0d1b00f2 db780682 e6872bd7 cbf33494 e46308b5 a6b2a2ec
Nov/10/2016 09:04:14 ipsec,debug,packet 52e59c08 41f0ad75 4a34bef3 7f66bb82 a4c80ee3 9ae8d36d 9b4609b5 153174cf
Nov/10/2016 09:04:14 ipsec,debug,packet 62e4260d 824c5f39 42612243 c6cb405a c960103e fde12d9d 9faec5fd 35d08906
Nov/10/2016 09:04:14 ipsec,debug,packet 62a8ec14 36b72bb9 0176dc23 2d85fbb9 da5beab4 ab0fc73a 9d5ef556 3b573197
Nov/10/2016 09:04:14 ipsec,debug,packet 82bba589 9ad9179a 1b963fff fa0968c8 82fb0af6 1840db3d 55a57d56 96deb9ce
Nov/10/2016 09:04:14 ipsec,debug,packet 04f96bfe 5a0a0871 ebf38e5f 7655e76b 4c2889ee d6958d8a c0503146 03c40b70
Nov/10/2016 09:04:14 ipsec,debug,packet 6897e84a e01be430 be2ed0d0 4000a1a1 09a412a5 e843e462 b4dffd84 08e88072
Nov/10/2016 09:04:14 ipsec,debug,packet 24a3e8ce 60dbf1d8 fc6190f9 c79c77ce 656fb244 68ce6ca8 5c033be7 62270d45
Nov/10/2016 09:04:14 ipsec,debug,packet 29df6e6b a2aae419 b49b0f16 bc83cebb 8cb9219c c64968ab 63b383af 0f86b8bd
Nov/10/2016 09:04:14 ipsec,debug,packet b5a68a7c f02e63de c771db48 9fea0950 1cce8df2 c19c977e 6e5964ce c18d5ba4
Nov/10/2016 09:04:14 ipsec,debug,packet 4e4cd48a 06af5079 5c655403 8476fc9d c2df24c3 7a3407ab 963a6195 d92f3a19
Nov/10/2016 09:04:14 ipsec,debug,packet 82f54839 e571e50b ee678f79 3fe58769 fd4c3267 698aa617 de941d66 516ff692
Nov/10/2016 09:04:14 ipsec,debug,packet ddd60177 52d292e7 46412c76
Nov/10/2016 09:04:14 ipsec,debug,packet SIGN computed:
Nov/10/2016 09:04:14 ipsec,debug,packet 5070a047 9f706feb 42936aff 4e510c13 55615cc5 23465bd8 191e260a f4fab5b3
Nov/10/2016 09:04:14 ipsec,debug,packet 67f895fd 6d2781ca 30fc180b 396822da ffecf4c9 a3ca06b9 06afebb2 c31fed3f
Nov/10/2016 09:04:14 ipsec,debug,packet b91560b5 aaa98e6f a0622f64 c7de1c62 88c5bb6a f14823a9 273596ae 3a6a0ab7
Nov/10/2016 09:04:14 ipsec,debug,packet 823e0629 a905d282 0bc8a179 dbdaee30 89e19655 015ced1b bf9c12aa 2c0b0d0e
Nov/10/2016 09:04:14 ipsec,debug,packet 7269cf97 1cd17740 2f84d5d9 d59806c6 a7af9d13 8e286257 fab292ad cbf965ed
Nov/10/2016 09:04:14 ipsec,debug,packet 72ba1e4a 07b06986 52ad48ee be773498 60bae49e 19f59775 d08445b8 941bdbf1
Nov/10/2016 09:04:14 ipsec,debug,packet dcf02170 a52a1a46 949ca1eb 4a335531 d9624c11 9b3d917a 63812cdf 39a344b4
Nov/10/2016 09:04:14 ipsec,debug,packet 8d994468 ed7d495a 3f79e63a 19ea75b8 9f874acf 4220e311 99010e5b 081ffc1e
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 17, next type 6
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 1132, next type 9
Nov/10/2016 09:04:14 ipsec,debug,packet add payload of len 256, next type 0
Nov/10/2016 09:04:14 ipsec,debug,packet begin encryption.
Nov/10/2016 09:04:14 ipsec,debug,packet pad length = 7
Nov/10/2016 09:04:14 ipsec,debug,packet 06000015 02000000 3139322e 3136382e 3130302e 31090004 70043082 04673082
Nov/10/2016 09:04:14 ipsec,debug,packet 024fa003 02010202 02100430 0d06092a 864886f7 0d01010b 05003068 310b3009
Nov/10/2016 09:04:14 ipsec,debug,packet 06035504 06130253 4b311130 0f060355 04080c08 536c6f76 616b6961 31133011
Nov/10/2016 09:04:14 ipsec,debug,packet 06035504 0a0c0a46 69727374 20446174 61310c30 0a060355 040b0c03 4e535331
Nov/10/2016 09:04:14 ipsec,debug,packet 23302106 03550403 0c1a4669 72737420 44617461 20496e74 65726d65 64696174
Nov/10/2016 09:04:14 ipsec,debug,packet 65204341 301e170d 31363131 30383134 30373537 5a170d33 36313130 33313430
Nov/10/2016 09:04:14 ipsec,debug,packet 3735375a 306b310b 30090603 55040613 02534b31 11300f06 03550408 0c08536c
Nov/10/2016 09:04:14 ipsec,debug,packet 6f76616b 69613113 30110603 5504070c 0a427261 7469736c 61766131 13301106
Nov/10/2016 09:04:14 ipsec,debug,packet 0355040a 0c0a4669 72737420 44617461 310c300a 06035504 0b0c034e 53533111
Nov/10/2016 09:04:14 ipsec,debug,packet 300f0603 5504030c 08533641 4b303030 35308201 22300d06 092a8648 86f70d01
Nov/10/2016 09:04:14 ipsec,debug,packet 01010500 0382010f 00308201 0a028201 0100bb88 eba3a50b 57741902 bd6465db
Nov/10/2016 09:04:14 ipsec,debug,packet d93ee305 c6a7dc29 bb47801a 86bad7c3 535e056f 95d61091 607a9db3 35bdbfea
Nov/10/2016 09:04:14 ipsec,debug,packet dccb506e 2f9cc4aa 42dd7bbb fe23ebab 7da18b7a e9774837 6bd37921 88f3b372
Nov/10/2016 09:04:14 ipsec,debug,packet 79557674 b2813a82 27bc4f5a 7994e75f fe60cc52 2abaa0b9 d4d17f7b dd1a1418
Nov/10/2016 09:04:14 ipsec,debug,packet 44870849 54b568f4 7c23b212 e84d30b4 c9fe685c b8828f01 8c12a31f a7e05fcc
Nov/10/2016 09:04:14 ipsec,debug,packet 179372a0 8d977f34 5ebc187e bc5eaf88 7b501234 1a86a432 8d08f22b f2054ea5
Nov/10/2016 09:04:14 ipsec,debug,packet 83099de4 dca81878 93b619e0 1625e946 95494c50 4ae5b20c a0708fce 0461bf0d
Nov/10/2016 09:04:14 ipsec,debug,packet b5a445a2 041e470c fcff5300 0c120a2d 0b769b86 2d06f6d1 08e410c7 ecbb1d0e
Nov/10/2016 09:04:14 ipsec,debug,packet bfeb9bae 2276bada bd49b6f8 3ff0d947 02f50203 010001a3 18301630 14060355
Nov/10/2016 09:04:14 ipsec,debug,packet 1d11040d 300b8209 5336414b 30303035 41300d06 092a8648 86f70d01 010b0500
Nov/10/2016 09:04:14 ipsec,debug,packet 03820201 000da8fe 8bd04b51 cbe24bba 489bc73f 45160b24 cef8546c 21da573d
Nov/10/2016 09:04:14 ipsec,debug,packet 45115527 7080ab1f 247a4554 2eb331d9 a9f7e735 af498028 ef8cb4a4 4737ad85
Nov/10/2016 09:04:14 ipsec,debug,packet d14e0edb 083bfac1 4c3e8938 d9920cd6 a4a5fc38 76b262bf 3d92b4ab 17c21496
Nov/10/2016 09:04:14 ipsec,debug,packet 59d5e64d a050ca9e 9fc3ba07 dadce37a 88afcc40 65b0628f ccc0e2ab 749f29d4
Nov/10/2016 09:04:14 ipsec,debug,packet b20d1b00 f2db7806 82e6872b d7cbf334 94e46308 b5a6b2a2 ec52e59c 0841f0ad
Nov/10/2016 09:04:14 ipsec,debug,packet 754a34be f37f66bb 82a4c80e e39ae8d3 6d9b4609 b5153174 cf62e426 0d824c5f
Nov/10/2016 09:04:14 ipsec,debug,packet 39426122 43c6cb40 5ac96010 3efde12d 9d9faec5 fd35d089 0662a8ec 1436b72b
Nov/10/2016 09:04:14 ipsec,debug,packet b90176dc 232d85fb b9da5bea b4ab0fc7 3a9d5ef5 563b5731 9782bba5 899ad917
Nov/10/2016 09:04:14 ipsec,debug,packet 9a1b963f fffa0968 c882fb0a f61840db 3d55a57d 5696deb9 ce04f96b fe5a0a08
Nov/10/2016 09:04:14 ipsec,debug,packet 71ebf38e 5f7655e7 6b4c2889 eed6958d 8ac05031 4603c40b 706897e8 4ae01be4
Nov/10/2016 09:04:14 ipsec,debug,packet 30be2ed0 d04000a1 a109a412 a5e843e4 62b4dffd 8408e880 7224a3e8 ce60dbf1
Nov/10/2016 09:04:14 ipsec,debug,packet d8fc6190 f9c79c77 ce656fb2 4468ce6c a85c033b e762270d 4529df6e 6ba2aae4
Nov/10/2016 09:04:14 ipsec,debug,packet 19b49b0f 16bc83ce bb8cb921 9cc64968 ab63b383 af0f86b8 bdb5a68a 7cf02e63
Nov/10/2016 09:04:14 ipsec,debug,packet dec771db 489fea09 501cce8d f2c19c97 7e6e5964 cec18d5b a44e4cd4 8a06af50
Nov/10/2016 09:04:14 ipsec,debug,packet 795c6554 038476fc 9dc2df24 c37a3407 ab963a61 95d92f3a 1982f548 39e571e5
Nov/10/2016 09:04:14 ipsec,debug,packet 0bee678f 793fe587 69fd4c32 67698aa6 17de941d 66516ff6 92ddd601 7752d292
Nov/10/2016 09:04:14 ipsec,debug,packet e746412c 76000001 045070a0 479f706f eb42936a ff4e510c 1355615c c523465b
Nov/10/2016 09:04:14 ipsec,debug,packet d8191e26 0af4fab5 b367f895 fd6d2781 ca30fc18 0b396822 daffecf4 c9a3ca06
Nov/10/2016 09:04:14 ipsec,debug,packet b906afeb b2c31fed 3fb91560 b5aaa98e 6fa0622f 64c7de1c 6288c5bb 6af14823
Nov/10/2016 09:04:14 ipsec,debug,packet a9273596 ae3a6a0a b7823e06 29a905d2 820bc8a1 79dbdaee 3089e196 55015ced
Nov/10/2016 09:04:14 ipsec,debug,packet 1bbf9c12 aa2c0b0d 0e7269cf 971cd177 402f84d5 d9d59806 c6a7af9d 138e2862
Nov/10/2016 09:04:14 ipsec,debug,packet 57fab292 adcbf965 ed72ba1e 4a07b069 8652ad48 eebe7734 9860bae4 9e19f597
Nov/10/2016 09:04:14 ipsec,debug,packet 75d08445 b8941bdb f1dcf021 70a52a1a 46949ca1 eb4a3355 31d9624c 119b3d91
Nov/10/2016 09:04:14 ipsec,debug,packet 7a63812c df39a344 b48d9944 68ed7d49 5a3f79e6 3a19ea75 b89f874a cf4220e3
Nov/10/2016 09:04:14 ipsec,debug,packet 1199010e 5b081ffc 1e64d600 976f6506
Nov/10/2016 09:04:14 ipsec,debug,packet with key:
Nov/10/2016 09:04:14 ipsec,debug,packet encrypted payload by IV:
Nov/10/2016 09:04:14 ipsec,debug,packet save IV for next:
Nov/10/2016 09:04:14 ipsec,debug,packet 99994357 7b4346fb 8b42035c 4ddb672b
Nov/10/2016 09:04:14 ipsec,debug,packet encrypted.
Nov/10/2016 09:04:14 ipsec,debug,packet Adding NON-ESP marker
Nov/10/2016 09:04:14 ipsec,debug,packet 1456 bytes from 192.168.100.1[4500] to 172.16.3.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet 1 times of 1456 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet 00000000 95e3a174 948b0d05 268787f3 59c4752e 05100201 00000000 000005ac
Nov/10/2016 09:04:14 ipsec,debug,packet 247b2e3d fa1c5072 6a14b2cc 23055e02 40e0133e c416baf2 4e25f06f d2e21d4a
Nov/10/2016 09:04:14 ipsec,debug,packet bcf084b9 e7aafc55 bf1ee4ad 5d2b610a 6d3b8c39 d0145f30 109f09dd c1c86459
Nov/10/2016 09:04:14 ipsec,debug,packet 5c3d7e45 add10ee6 a200ae49 abea26ee 6ac93ae8 c200e286 bd18d576 cde7a204
Nov/10/2016 09:04:14 ipsec,debug,packet 27f66d4c 53f02d7d dd24aa7b 4bf89006 1e0ecf58 a8071b33 fce14545 ab3f7fa5
Nov/10/2016 09:04:14 ipsec,debug,packet 900bcd9d aaff1291 90c0e3f8 5eb03edc d1d1d4a3 8b6bfd9a be3fca80 9676cc8a
Nov/10/2016 09:04:14 ipsec,debug,packet 7e28b228 f849dab2 0e5e5ad4 89791951 c6894dd8 06aa5f8d b7062385 e5e6e58f
Nov/10/2016 09:04:14 ipsec,debug,packet efc301c7 a91e6663 e96f06ba 5b7110aa 378b6446 b990452a 180d409b a9fc2d95
Nov/10/2016 09:04:14 ipsec,debug,packet 910b683e 7a26e256 c4a2dcd8 f89ce1f4 df187e81 605b07ad 32f8e30b 5c70f07e
Nov/10/2016 09:04:14 ipsec,debug,packet ce35391a 9c71e492 6ebb2547 695c4503 b6dc7957 827b3ec2 2ce3dda2 e7a15322
Nov/10/2016 09:04:14 ipsec,debug,packet 94c7e3a0 15d17af1 02956226 19161167 fc4decec 8680ece2 71c0d741 665303e8
Nov/10/2016 09:04:14 ipsec,debug,packet b1567f8c c0ec556e 60d3c81b 76b60cc7 bf49525f 3cf43df2 a156ad80 d14f73e2
Nov/10/2016 09:04:14 ipsec,debug,packet 950e50c3 078089fc 7a7ffe8b 34c80289 5e8fd2a5 a7caba03 f2294f70 3e7f5d12
Nov/10/2016 09:04:14 ipsec,debug,packet bbab5528 57f2dd73 31af2997 0fcfd455 05cdf30f d73e89f1 096129fa 23712fc8
Nov/10/2016 09:04:14 ipsec,debug,packet e27e18dc 62e93c23 67f30f40 94b17ec5 fd023877 c70e759c a3319e26 d48ce99c
Nov/10/2016 09:04:14 ipsec,debug,packet c82d348d 4b5ecc1f 146a8a91 a1b08a0a fd90f11a cb32d163 03e8cd67 24b71a43
Nov/10/2016 09:04:14 ipsec,debug,packet 56051e8e efba24c9 2e5a4999 6eb869db bb8ada7d 3f3369ca 3924ed46 b98778f8
Nov/10/2016 09:04:14 ipsec,debug,packet cb0f7d7b 7e4ec848 cd220fca 439fe324 58f339f0 16336814 2fac6922 a8d79e9a
Nov/10/2016 09:04:14 ipsec,debug,packet dcd9965d 20303a73 939bf61f ebd2fb73 84930a22 f4f5864b bfe38ed1 6dfa1a87
Nov/10/2016 09:04:14 ipsec,debug,packet 3bd8d6af 1741947a fdbb095a e8b44892 97b657b0 bc544def 2d7a261f b9f0f612
Nov/10/2016 09:04:14 ipsec,debug,packet 95579acf 761b00df 73dddf87 94c89162 e917888e f5ec5138 90d1e87f 30a3b6f3
Nov/10/2016 09:04:14 ipsec,debug,packet b370c1d5 5575b6e6 2d032ae5 eaba2dd9 0e5d654a 1bb77f59 b7a01316 78d845ff
Nov/10/2016 09:04:14 ipsec,debug,packet 62d2401a 3b66904c 428c2780 788b53e7 7ad31766 9b9ca040 0a84c67a 1ad93cd5
Nov/10/2016 09:04:14 ipsec,debug,packet 35ce380d 96a0f910 8e18d054 30f07f0b 84ae17f2 4451715d 34f2d18b 423b03a5
Nov/10/2016 09:04:14 ipsec,debug,packet cc01524c 5dde652f 407c8e8a fd9a1fbf f3b9ed4a 48037f3a 74c21f24 a3fe2ebd
Nov/10/2016 09:04:14 ipsec,debug,packet 9bfec8ab ea5a831d ee00e2f9 25f20a2d 626fc808 341a09b2 c051faf4 6d6e61b9
Nov/10/2016 09:04:14 ipsec,debug,packet 85b49154 59d5febd 9a5144f8 e4c459fb 087ceb14 b1d7e442 35735e8c ea871b7d
Nov/10/2016 09:04:14 ipsec,debug,packet ec4fc76d 91ee595d 0eae5528 c769ee22 461eb94c 2b9bab57 49896127 49b75f14
Nov/10/2016 09:04:14 ipsec,debug,packet ad327e84 2ed95bbc 6427f85a ecc2a227 9c6e7061 6ad0077e 5d04bf4f d949d95d
Nov/10/2016 09:04:14 ipsec,debug,packet e97bcde3 d88ef6a3 fcd1c31e f03ac63d 9367be39 7a796498 b6aa7185 26b35f82
Nov/10/2016 09:04:14 ipsec,debug,packet 2b3d84b3 9a3a358d 32467a2e 4f63a329 36ed113a 40a3da20 d8d7f238 eba89560
Nov/10/2016 09:04:14 ipsec,debug,packet 7d903aee d1cb3cf9 d03d662a 093df4aa 53252342 fda90c06 83d70fbd 9567fc09
Nov/10/2016 09:04:14 ipsec,debug,packet 383f6fb6 8c514b5e c95112b7 c1ef4143 b671cb9e e92bf0df 9db179d8 0a1f6ae5
Nov/10/2016 09:04:14 ipsec,debug,packet 26ac83d2 fe8ab4ed 4d105ffc cb84e9f7 5867830a 355c6de2 229690a6 ea0c1995
Nov/10/2016 09:04:14 ipsec,debug,packet 58fc2589 496fda70 ee5898a5 10794aa5 7879577e e6c98192 74b29cd9 45ec65b3
Nov/10/2016 09:04:14 ipsec,debug,packet a9190a8d d02f5d1f 23633656 30be110b 16bead19 041767d2 a19332b1 1e1b6367
Nov/10/2016 09:04:14 ipsec,debug,packet e4b12d3d faaf5caa fa77f40f eab85675 d8d74d11 0bd4b097 d6bc140b 626ef065
Nov/10/2016 09:04:14 ipsec,debug,packet f57fb183 b2e0cb69 57e8eb6c eae8a654 2d6bb125 65e99412 7084bb36 04afd3ae
Nov/10/2016 09:04:14 ipsec,debug,packet 3143e4ed d895f264 24016fb9 657a86ca 7adcdd24 ee9c45ef 5df51533 e526b03d
Nov/10/2016 09:04:14 ipsec,debug,packet 689a20d2 d2205839 2477f797 4115eba0 0920a8d1 306471c0 52809bba 2e983c1d
Nov/10/2016 09:04:14 ipsec,debug,packet b14f4d7b bf00c09e abd4830b 66de6a42 b20b7164 884a244a d732a48a fea3edf1
Nov/10/2016 09:04:14 ipsec,debug,packet 6e7d0843 5eb65d58 c77bd9f7 34dc12aa e9a3def5 196de3c9 2a4a201e 44eccc54
Nov/10/2016 09:04:14 ipsec,debug,packet 399f076f 44d07d91 dcf9865e 12ac2029 2bfb8d90 4a19faf7 6abff2a4 a7a3d2f5
Nov/10/2016 09:04:14 ipsec,debug,packet c9d65a60 4efa3472 e7c02b90 d722ab04 4344d986 5b866920 317c6aa3 75080b3d
Nov/10/2016 09:04:14 ipsec,debug,packet ee62ca74 bae04f06 fbbbad5e 25f90c88 77103dcd 94ad0007 6b3f930b 6aed3e24
Nov/10/2016 09:04:14 ipsec,debug sent phase1 packet 192.168.100.1[4500]<=>172.16.3.1[4500] 95e3a174948b0d05:268787f359c4752e
Nov/10/2016 09:04:14 ipsec,debug,packet 40 bytes message received from 172.16.3.1[4500] to 192.168.100.1[4500]
Nov/10/2016 09:04:14 ipsec,debug,packet 95e3a174 948b0d05 268787f3 59c4752e 0b100500 3a955a03 00000028 0000000c
Nov/10/2016 09:04:14 ipsec,debug,packet 00000000 01000012
Nov/10/2016 09:04:14 ipsec,debug,packet receive Information.
Nov/10/2016 09:04:14 ipsec,debug 172.16.3.1 none message must be encrypted
Nov/10/2016 09:04:16 ipsec,debug,packet KA: 192.168.100.1[4500]->172.16.3.1[4500]
Nov/10/2016 09:04:16 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:16 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:16 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:16 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:16 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:16 ipsec,debug,packet 1 times of 1 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:16 ipsec,debug,packet ff
Nov/10/2016 09:04:24 ipsec,debug,packet Adding NON-ESP marker
Nov/10/2016 09:04:24 ipsec,debug,packet 1456 bytes from 192.168.100.1[4500] to 172.16.3.1[4500]
Nov/10/2016 09:04:24 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:24 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:24 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:24 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:24 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:24 ipsec,debug,packet 1 times of 1456 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:24 ipsec,debug,packet 00000000 95e3a174 948b0d05 268787f3 59c4752e 05100201 00000000 000005ac
Nov/10/2016 09:04:24 ipsec,debug,packet 247b2e3d fa1c5072 6a14b2cc 23055e02 40e0133e c416baf2 4e25f06f d2e21d4a
Nov/10/2016 09:04:24 ipsec,debug,packet bcf084b9 e7aafc55 bf1ee4ad 5d2b610a 6d3b8c39 d0145f30 109f09dd c1c86459
Nov/10/2016 09:04:24 ipsec,debug,packet 5c3d7e45 add10ee6 a200ae49 abea26ee 6ac93ae8 c200e286 bd18d576 cde7a204
Nov/10/2016 09:04:24 ipsec,debug,packet 27f66d4c 53f02d7d dd24aa7b 4bf89006 1e0ecf58 a8071b33 fce14545 ab3f7fa5
Nov/10/2016 09:04:24 ipsec,debug,packet 900bcd9d aaff1291 90c0e3f8 5eb03edc d1d1d4a3 8b6bfd9a be3fca80 9676cc8a
Nov/10/2016 09:04:24 ipsec,debug,packet 7e28b228 f849dab2 0e5e5ad4 89791951 c6894dd8 06aa5f8d b7062385 e5e6e58f
Nov/10/2016 09:04:24 ipsec,debug,packet efc301c7 a91e6663 e96f06ba 5b7110aa 378b6446 b990452a 180d409b a9fc2d95
Nov/10/2016 09:04:24 ipsec,debug,packet 910b683e 7a26e256 c4a2dcd8 f89ce1f4 df187e81 605b07ad 32f8e30b 5c70f07e
Nov/10/2016 09:04:24 ipsec,debug,packet ce35391a 9c71e492 6ebb2547 695c4503 b6dc7957 827b3ec2 2ce3dda2 e7a15322
Nov/10/2016 09:04:24 ipsec,debug,packet 94c7e3a0 15d17af1 02956226 19161167 fc4decec 8680ece2 71c0d741 665303e8
Nov/10/2016 09:04:24 ipsec,debug,packet b1567f8c c0ec556e 60d3c81b 76b60cc7 bf49525f 3cf43df2 a156ad80 d14f73e2
Nov/10/2016 09:04:24 ipsec,debug,packet 950e50c3 078089fc 7a7ffe8b 34c80289 5e8fd2a5 a7caba03 f2294f70 3e7f5d12
Nov/10/2016 09:04:24 ipsec,debug,packet bbab5528 57f2dd73 31af2997 0fcfd455 05cdf30f d73e89f1 096129fa 23712fc8
Nov/10/2016 09:04:24 ipsec,debug,packet e27e18dc 62e93c23 67f30f40 94b17ec5 fd023877 c70e759c a3319e26 d48ce99c
Nov/10/2016 09:04:24 ipsec,debug,packet c82d348d 4b5ecc1f 146a8a91 a1b08a0a fd90f11a cb32d163 03e8cd67 24b71a43
Nov/10/2016 09:04:24 ipsec,debug,packet 56051e8e efba24c9 2e5a4999 6eb869db bb8ada7d 3f3369ca 3924ed46 b98778f8
Nov/10/2016 09:04:24 ipsec,debug,packet cb0f7d7b 7e4ec848 cd220fca 439fe324 58f339f0 16336814 2fac6922 a8d79e9a
Nov/10/2016 09:04:24 ipsec,debug,packet dcd9965d 20303a73 939bf61f ebd2fb73 84930a22 f4f5864b bfe38ed1 6dfa1a87
Nov/10/2016 09:04:24 ipsec,debug,packet 3bd8d6af 1741947a fdbb095a e8b44892 97b657b0 bc544def 2d7a261f b9f0f612
Nov/10/2016 09:04:24 ipsec,debug,packet 95579acf 761b00df 73dddf87 94c89162 e917888e f5ec5138 90d1e87f 30a3b6f3
Nov/10/2016 09:04:24 ipsec,debug,packet b370c1d5 5575b6e6 2d032ae5 eaba2dd9 0e5d654a 1bb77f59 b7a01316 78d845ff
Nov/10/2016 09:04:24 ipsec,debug,packet 62d2401a 3b66904c 428c2780 788b53e7 7ad31766 9b9ca040 0a84c67a 1ad93cd5
Nov/10/2016 09:04:24 ipsec,debug,packet 35ce380d 96a0f910 8e18d054 30f07f0b 84ae17f2 4451715d 34f2d18b 423b03a5
Nov/10/2016 09:04:24 ipsec,debug,packet cc01524c 5dde652f 407c8e8a fd9a1fbf f3b9ed4a 48037f3a 74c21f24 a3fe2ebd
Nov/10/2016 09:04:24 ipsec,debug,packet 9bfec8ab ea5a831d ee00e2f9 25f20a2d 626fc808 341a09b2 c051faf4 6d6e61b9
Nov/10/2016 09:04:24 ipsec,debug,packet 85b49154 59d5febd 9a5144f8 e4c459fb 087ceb14 b1d7e442 35735e8c ea871b7d
Nov/10/2016 09:04:24 ipsec,debug,packet ec4fc76d 91ee595d 0eae5528 c769ee22 461eb94c 2b9bab57 49896127 49b75f14
Nov/10/2016 09:04:24 ipsec,debug,packet ad327e84 2ed95bbc 6427f85a ecc2a227 9c6e7061 6ad0077e 5d04bf4f d949d95d
Nov/10/2016 09:04:24 ipsec,debug,packet e97bcde3 d88ef6a3 fcd1c31e f03ac63d 9367be39 7a796498 b6aa7185 26b35f82
Nov/10/2016 09:04:24 ipsec,debug,packet 2b3d84b3 9a3a358d 32467a2e 4f63a329 36ed113a 40a3da20 d8d7f238 eba89560
Nov/10/2016 09:04:24 ipsec,debug,packet 7d903aee d1cb3cf9 d03d662a 093df4aa 53252342 fda90c06 83d70fbd 9567fc09
Nov/10/2016 09:04:24 ipsec,debug,packet 383f6fb6 8c514b5e c95112b7 c1ef4143 b671cb9e e92bf0df 9db179d8 0a1f6ae5
Nov/10/2016 09:04:24 ipsec,debug,packet 26ac83d2 fe8ab4ed 4d105ffc cb84e9f7 5867830a 355c6de2 229690a6 ea0c1995
Nov/10/2016 09:04:24 ipsec,debug,packet 58fc2589 496fda70 ee5898a5 10794aa5 7879577e e6c98192 74b29cd9 45ec65b3
Nov/10/2016 09:04:24 ipsec,debug,packet a9190a8d d02f5d1f 23633656 30be110b 16bead19 041767d2 a19332b1 1e1b6367
Nov/10/2016 09:04:24 ipsec,debug,packet e4b12d3d faaf5caa fa77f40f eab85675 d8d74d11 0bd4b097 d6bc140b 626ef065
Nov/10/2016 09:04:24 ipsec,debug,packet f57fb183 b2e0cb69 57e8eb6c eae8a654 2d6bb125 65e99412 7084bb36 04afd3ae
Nov/10/2016 09:04:24 ipsec,debug,packet 3143e4ed d895f264 24016fb9 657a86ca 7adcdd24 ee9c45ef 5df51533 e526b03d
Nov/10/2016 09:04:24 ipsec,debug,packet 689a20d2 d2205839 2477f797 4115eba0 0920a8d1 306471c0 52809bba 2e983c1d
Nov/10/2016 09:04:24 ipsec,debug,packet b14f4d7b bf00c09e abd4830b 66de6a42 b20b7164 884a244a d732a48a fea3edf1
Nov/10/2016 09:04:24 ipsec,debug,packet 6e7d0843 5eb65d58 c77bd9f7 34dc12aa e9a3def5 196de3c9 2a4a201e 44eccc54
Nov/10/2016 09:04:24 ipsec,debug,packet 399f076f 44d07d91 dcf9865e 12ac2029 2bfb8d90 4a19faf7 6abff2a4 a7a3d2f5
Nov/10/2016 09:04:24 ipsec,debug,packet c9d65a60 4efa3472 e7c02b90 d722ab04 4344d986 5b866920 317c6aa3 75080b3d
Nov/10/2016 09:04:24 ipsec,debug,packet ee62ca74 bae04f06 fbbbad5e 25f90c88 77103dcd 94ad0007 6b3f930b 6aed3e24
Nov/10/2016 09:04:24 ipsec,debug,packet 99994357 7b4346fb 8b42035c 4ddb672b
Nov/10/2016 09:04:24 ipsec,debug resent phase1 packet 192.168.100.1[4500]<=>172.16.3.1[4500] 95e3a174948b0d05:268787f359c4752e
Nov/10/2016 09:04:34 ipsec,debug,packet Adding NON-ESP marker
Nov/10/2016 09:04:34 ipsec,debug,packet 1456 bytes from 192.168.100.1[4500] to 172.16.3.1[4500]
Nov/10/2016 09:04:34 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:34 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:34 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:34 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:34 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:34 ipsec,debug,packet 1 times of 1456 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:34 ipsec,debug,packet 00000000 95e3a174 948b0d05 268787f3 59c4752e 05100201 00000000 000005ac
Nov/10/2016 09:04:34 ipsec,debug,packet 247b2e3d fa1c5072 6a14b2cc 23055e02 40e0133e c416baf2 4e25f06f d2e21d4a
Nov/10/2016 09:04:34 ipsec,debug,packet bcf084b9 e7aafc55 bf1ee4ad 5d2b610a 6d3b8c39 d0145f30 109f09dd c1c86459
Nov/10/2016 09:04:34 ipsec,debug,packet 5c3d7e45 add10ee6 a200ae49 abea26ee 6ac93ae8 c200e286 bd18d576 cde7a204
Nov/10/2016 09:04:34 ipsec,debug,packet 27f66d4c 53f02d7d dd24aa7b 4bf89006 1e0ecf58 a8071b33 fce14545 ab3f7fa5
Nov/10/2016 09:04:34 ipsec,debug,packet 900bcd9d aaff1291 90c0e3f8 5eb03edc d1d1d4a3 8b6bfd9a be3fca80 9676cc8a
Nov/10/2016 09:04:34 ipsec,debug,packet 7e28b228 f849dab2 0e5e5ad4 89791951 c6894dd8 06aa5f8d b7062385 e5e6e58f
Nov/10/2016 09:04:34 ipsec,debug,packet efc301c7 a91e6663 e96f06ba 5b7110aa 378b6446 b990452a 180d409b a9fc2d95
Nov/10/2016 09:04:34 ipsec,debug,packet 910b683e 7a26e256 c4a2dcd8 f89ce1f4 df187e81 605b07ad 32f8e30b 5c70f07e
Nov/10/2016 09:04:34 ipsec,debug,packet ce35391a 9c71e492 6ebb2547 695c4503 b6dc7957 827b3ec2 2ce3dda2 e7a15322
Nov/10/2016 09:04:34 ipsec,debug,packet 94c7e3a0 15d17af1 02956226 19161167 fc4decec 8680ece2 71c0d741 665303e8
Nov/10/2016 09:04:34 ipsec,debug,packet b1567f8c c0ec556e 60d3c81b 76b60cc7 bf49525f 3cf43df2 a156ad80 d14f73e2
Nov/10/2016 09:04:34 ipsec,debug,packet 950e50c3 078089fc 7a7ffe8b 34c80289 5e8fd2a5 a7caba03 f2294f70 3e7f5d12
Nov/10/2016 09:04:34 ipsec,debug,packet bbab5528 57f2dd73 31af2997 0fcfd455 05cdf30f d73e89f1 096129fa 23712fc8
Nov/10/2016 09:04:34 ipsec,debug,packet e27e18dc 62e93c23 67f30f40 94b17ec5 fd023877 c70e759c a3319e26 d48ce99c
Nov/10/2016 09:04:34 ipsec,debug,packet c82d348d 4b5ecc1f 146a8a91 a1b08a0a fd90f11a cb32d163 03e8cd67 24b71a43
Nov/10/2016 09:04:34 ipsec,debug,packet 56051e8e efba24c9 2e5a4999 6eb869db bb8ada7d 3f3369ca 3924ed46 b98778f8
Nov/10/2016 09:04:34 ipsec,debug,packet cb0f7d7b 7e4ec848 cd220fca 439fe324 58f339f0 16336814 2fac6922 a8d79e9a
Nov/10/2016 09:04:34 ipsec,debug,packet dcd9965d 20303a73 939bf61f ebd2fb73 84930a22 f4f5864b bfe38ed1 6dfa1a87
Nov/10/2016 09:04:34 ipsec,debug,packet 3bd8d6af 1741947a fdbb095a e8b44892 97b657b0 bc544def 2d7a261f b9f0f612
Nov/10/2016 09:04:34 ipsec,debug,packet 95579acf 761b00df 73dddf87 94c89162 e917888e f5ec5138 90d1e87f 30a3b6f3
Nov/10/2016 09:04:34 ipsec,debug,packet b370c1d5 5575b6e6 2d032ae5 eaba2dd9 0e5d654a 1bb77f59 b7a01316 78d845ff
Nov/10/2016 09:04:34 ipsec,debug,packet 62d2401a 3b66904c 428c2780 788b53e7 7ad31766 9b9ca040 0a84c67a 1ad93cd5
Nov/10/2016 09:04:34 ipsec,debug,packet 35ce380d 96a0f910 8e18d054 30f07f0b 84ae17f2 4451715d 34f2d18b 423b03a5
Nov/10/2016 09:04:34 ipsec,debug,packet cc01524c 5dde652f 407c8e8a fd9a1fbf f3b9ed4a 48037f3a 74c21f24 a3fe2ebd
Nov/10/2016 09:04:34 ipsec,debug,packet 9bfec8ab ea5a831d ee00e2f9 25f20a2d 626fc808 341a09b2 c051faf4 6d6e61b9
Nov/10/2016 09:04:34 ipsec,debug,packet 85b49154 59d5febd 9a5144f8 e4c459fb 087ceb14 b1d7e442 35735e8c ea871b7d
Nov/10/2016 09:04:34 ipsec,debug,packet ec4fc76d 91ee595d 0eae5528 c769ee22 461eb94c 2b9bab57 49896127 49b75f14
Nov/10/2016 09:04:34 ipsec,debug,packet ad327e84 2ed95bbc 6427f85a ecc2a227 9c6e7061 6ad0077e 5d04bf4f d949d95d
Nov/10/2016 09:04:34 ipsec,debug,packet e97bcde3 d88ef6a3 fcd1c31e f03ac63d 9367be39 7a796498 b6aa7185 26b35f82
Nov/10/2016 09:04:34 ipsec,debug,packet 2b3d84b3 9a3a358d 32467a2e 4f63a329 36ed113a 40a3da20 d8d7f238 eba89560
Nov/10/2016 09:04:34 ipsec,debug,packet 7d903aee d1cb3cf9 d03d662a 093df4aa 53252342 fda90c06 83d70fbd 9567fc09
Nov/10/2016 09:04:34 ipsec,debug,packet 383f6fb6 8c514b5e c95112b7 c1ef4143 b671cb9e e92bf0df 9db179d8 0a1f6ae5
Nov/10/2016 09:04:34 ipsec,debug,packet 26ac83d2 fe8ab4ed 4d105ffc cb84e9f7 5867830a 355c6de2 229690a6 ea0c1995
Nov/10/2016 09:04:34 ipsec,debug,packet 58fc2589 496fda70 ee5898a5 10794aa5 7879577e e6c98192 74b29cd9 45ec65b3
Nov/10/2016 09:04:34 ipsec,debug,packet a9190a8d d02f5d1f 23633656 30be110b 16bead19 041767d2 a19332b1 1e1b6367
Nov/10/2016 09:04:34 ipsec,debug,packet e4b12d3d faaf5caa fa77f40f eab85675 d8d74d11 0bd4b097 d6bc140b 626ef065
Nov/10/2016 09:04:34 ipsec,debug,packet f57fb183 b2e0cb69 57e8eb6c eae8a654 2d6bb125 65e99412 7084bb36 04afd3ae
Nov/10/2016 09:04:34 ipsec,debug,packet 3143e4ed d895f264 24016fb9 657a86ca 7adcdd24 ee9c45ef 5df51533 e526b03d
Nov/10/2016 09:04:34 ipsec,debug,packet 689a20d2 d2205839 2477f797 4115eba0 0920a8d1 306471c0 52809bba 2e983c1d
Nov/10/2016 09:04:34 ipsec,debug,packet b14f4d7b bf00c09e abd4830b 66de6a42 b20b7164 884a244a d732a48a fea3edf1
Nov/10/2016 09:04:34 ipsec,debug,packet 6e7d0843 5eb65d58 c77bd9f7 34dc12aa e9a3def5 196de3c9 2a4a201e 44eccc54
Nov/10/2016 09:04:34 ipsec,debug,packet 399f076f 44d07d91 dcf9865e 12ac2029 2bfb8d90 4a19faf7 6abff2a4 a7a3d2f5
Nov/10/2016 09:04:34 ipsec,debug,packet c9d65a60 4efa3472 e7c02b90 d722ab04 4344d986 5b866920 317c6aa3 75080b3d
Nov/10/2016 09:04:34 ipsec,debug,packet ee62ca74 bae04f06 fbbbad5e 25f90c88 77103dcd 94ad0007 6b3f930b 6aed3e24
Nov/10/2016 09:04:34 ipsec,debug,packet 99994357 7b4346fb 8b42035c 4ddb672b
Nov/10/2016 09:04:34 ipsec,debug resent phase1 packet 192.168.100.1[4500]<=>172.16.3.1[4500] 95e3a174948b0d05:268787f359c4752e
Nov/10/2016 09:04:36 ipsec,debug,packet KA: 192.168.100.1[4500]->172.16.3.1[4500]
Nov/10/2016 09:04:36 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:36 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:36 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:36 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:36 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:36 ipsec,debug,packet 1 times of 1 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:36 ipsec,debug,packet ff
Nov/10/2016 09:04:45 ipsec,debug,packet Adding NON-ESP marker
Nov/10/2016 09:04:45 ipsec,debug,packet 1456 bytes from 192.168.100.1[4500] to 172.16.3.1[4500]
Nov/10/2016 09:04:45 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:45 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:45 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:45 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:45 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:45 ipsec,debug,packet 1 times of 1456 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:45 ipsec,debug,packet 00000000 95e3a174 948b0d05 268787f3 59c4752e 05100201 00000000 000005ac
Nov/10/2016 09:04:45 ipsec,debug,packet 247b2e3d fa1c5072 6a14b2cc 23055e02 40e0133e c416baf2 4e25f06f d2e21d4a
Nov/10/2016 09:04:45 ipsec,debug,packet bcf084b9 e7aafc55 bf1ee4ad 5d2b610a 6d3b8c39 d0145f30 109f09dd c1c86459
Nov/10/2016 09:04:45 ipsec,debug,packet 5c3d7e45 add10ee6 a200ae49 abea26ee 6ac93ae8 c200e286 bd18d576 cde7a204
Nov/10/2016 09:04:45 ipsec,debug,packet 27f66d4c 53f02d7d dd24aa7b 4bf89006 1e0ecf58 a8071b33 fce14545 ab3f7fa5
Nov/10/2016 09:04:45 ipsec,debug,packet 900bcd9d aaff1291 90c0e3f8 5eb03edc d1d1d4a3 8b6bfd9a be3fca80 9676cc8a
Nov/10/2016 09:04:45 ipsec,debug,packet 7e28b228 f849dab2 0e5e5ad4 89791951 c6894dd8 06aa5f8d b7062385 e5e6e58f
Nov/10/2016 09:04:45 ipsec,debug,packet efc301c7 a91e6663 e96f06ba 5b7110aa 378b6446 b990452a 180d409b a9fc2d95
Nov/10/2016 09:04:45 ipsec,debug,packet 910b683e 7a26e256 c4a2dcd8 f89ce1f4 df187e81 605b07ad 32f8e30b 5c70f07e
Nov/10/2016 09:04:45 ipsec,debug,packet ce35391a 9c71e492 6ebb2547 695c4503 b6dc7957 827b3ec2 2ce3dda2 e7a15322
Nov/10/2016 09:04:45 ipsec,debug,packet 94c7e3a0 15d17af1 02956226 19161167 fc4decec 8680ece2 71c0d741 665303e8
Nov/10/2016 09:04:45 ipsec,debug,packet b1567f8c c0ec556e 60d3c81b 76b60cc7 bf49525f 3cf43df2 a156ad80 d14f73e2
Nov/10/2016 09:04:45 ipsec,debug,packet 950e50c3 078089fc 7a7ffe8b 34c80289 5e8fd2a5 a7caba03 f2294f70 3e7f5d12
Nov/10/2016 09:04:45 ipsec,debug,packet bbab5528 57f2dd73 31af2997 0fcfd455 05cdf30f d73e89f1 096129fa 23712fc8
Nov/10/2016 09:04:45 ipsec,debug,packet e27e18dc 62e93c23 67f30f40 94b17ec5 fd023877 c70e759c a3319e26 d48ce99c
Nov/10/2016 09:04:45 ipsec,debug,packet c82d348d 4b5ecc1f 146a8a91 a1b08a0a fd90f11a cb32d163 03e8cd67 24b71a43
Nov/10/2016 09:04:45 ipsec,debug,packet 56051e8e efba24c9 2e5a4999 6eb869db bb8ada7d 3f3369ca 3924ed46 b98778f8
Nov/10/2016 09:04:45 ipsec,debug,packet cb0f7d7b 7e4ec848 cd220fca 439fe324 58f339f0 16336814 2fac6922 a8d79e9a
Nov/10/2016 09:04:45 ipsec,debug,packet dcd9965d 20303a73 939bf61f ebd2fb73 84930a22 f4f5864b bfe38ed1 6dfa1a87
Nov/10/2016 09:04:45 ipsec,debug,packet 3bd8d6af 1741947a fdbb095a e8b44892 97b657b0 bc544def 2d7a261f b9f0f612
Nov/10/2016 09:04:45 ipsec,debug,packet 95579acf 761b00df 73dddf87 94c89162 e917888e f5ec5138 90d1e87f 30a3b6f3
Nov/10/2016 09:04:45 ipsec,debug,packet b370c1d5 5575b6e6 2d032ae5 eaba2dd9 0e5d654a 1bb77f59 b7a01316 78d845ff
Nov/10/2016 09:04:45 ipsec,debug,packet 62d2401a 3b66904c 428c2780 788b53e7 7ad31766 9b9ca040 0a84c67a 1ad93cd5
Nov/10/2016 09:04:45 ipsec,debug,packet 35ce380d 96a0f910 8e18d054 30f07f0b 84ae17f2 4451715d 34f2d18b 423b03a5
Nov/10/2016 09:04:45 ipsec,debug,packet cc01524c 5dde652f 407c8e8a fd9a1fbf f3b9ed4a 48037f3a 74c21f24 a3fe2ebd
Nov/10/2016 09:04:45 ipsec,debug,packet 9bfec8ab ea5a831d ee00e2f9 25f20a2d 626fc808 341a09b2 c051faf4 6d6e61b9
Nov/10/2016 09:04:45 ipsec,debug,packet 85b49154 59d5febd 9a5144f8 e4c459fb 087ceb14 b1d7e442 35735e8c ea871b7d
Nov/10/2016 09:04:45 ipsec,debug,packet ec4fc76d 91ee595d 0eae5528 c769ee22 461eb94c 2b9bab57 49896127 49b75f14
Nov/10/2016 09:04:45 ipsec,debug,packet ad327e84 2ed95bbc 6427f85a ecc2a227 9c6e7061 6ad0077e 5d04bf4f d949d95d
Nov/10/2016 09:04:45 ipsec,debug,packet e97bcde3 d88ef6a3 fcd1c31e f03ac63d 9367be39 7a796498 b6aa7185 26b35f82
Nov/10/2016 09:04:45 ipsec,debug,packet 2b3d84b3 9a3a358d 32467a2e 4f63a329 36ed113a 40a3da20 d8d7f238 eba89560
Nov/10/2016 09:04:45 ipsec,debug,packet 7d903aee d1cb3cf9 d03d662a 093df4aa 53252342 fda90c06 83d70fbd 9567fc09
Nov/10/2016 09:04:45 ipsec,debug,packet 383f6fb6 8c514b5e c95112b7 c1ef4143 b671cb9e e92bf0df 9db179d8 0a1f6ae5
Nov/10/2016 09:04:45 ipsec,debug,packet 26ac83d2 fe8ab4ed 4d105ffc cb84e9f7 5867830a 355c6de2 229690a6 ea0c1995
Nov/10/2016 09:04:45 ipsec,debug,packet 58fc2589 496fda70 ee5898a5 10794aa5 7879577e e6c98192 74b29cd9 45ec65b3
Nov/10/2016 09:04:45 ipsec,debug,packet a9190a8d d02f5d1f 23633656 30be110b 16bead19 041767d2 a19332b1 1e1b6367
Nov/10/2016 09:04:45 ipsec,debug,packet e4b12d3d faaf5caa fa77f40f eab85675 d8d74d11 0bd4b097 d6bc140b 626ef065
Nov/10/2016 09:04:45 ipsec,debug,packet f57fb183 b2e0cb69 57e8eb6c eae8a654 2d6bb125 65e99412 7084bb36 04afd3ae
Nov/10/2016 09:04:45 ipsec,debug,packet 3143e4ed d895f264 24016fb9 657a86ca 7adcdd24 ee9c45ef 5df51533 e526b03d
Nov/10/2016 09:04:45 ipsec,debug,packet 689a20d2 d2205839 2477f797 4115eba0 0920a8d1 306471c0 52809bba 2e983c1d
Nov/10/2016 09:04:45 ipsec,debug,packet b14f4d7b bf00c09e abd4830b 66de6a42 b20b7164 884a244a d732a48a fea3edf1
Nov/10/2016 09:04:45 ipsec,debug,packet 6e7d0843 5eb65d58 c77bd9f7 34dc12aa e9a3def5 196de3c9 2a4a201e 44eccc54
Nov/10/2016 09:04:45 ipsec,debug,packet 399f076f 44d07d91 dcf9865e 12ac2029 2bfb8d90 4a19faf7 6abff2a4 a7a3d2f5
Nov/10/2016 09:04:45 ipsec,debug,packet c9d65a60 4efa3472 e7c02b90 d722ab04 4344d986 5b866920 317c6aa3 75080b3d
Nov/10/2016 09:04:45 ipsec,debug,packet ee62ca74 bae04f06 fbbbad5e 25f90c88 77103dcd 94ad0007 6b3f930b 6aed3e24
Nov/10/2016 09:04:45 ipsec,debug,packet 99994357 7b4346fb 8b42035c 4ddb672b
Nov/10/2016 09:04:45 ipsec,debug resent phase1 packet 192.168.100.1[4500]<=>172.16.3.1[4500] 95e3a174948b0d05:268787f359c4752e
Nov/10/2016 09:04:55 ipsec,debug,packet Adding NON-ESP marker
Nov/10/2016 09:04:55 ipsec,debug,packet 1456 bytes from 192.168.100.1[4500] to 172.16.3.1[4500]
Nov/10/2016 09:04:55 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:55 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:55 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:55 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:55 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:55 ipsec,debug,packet 1 times of 1456 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:55 ipsec,debug,packet 00000000 95e3a174 948b0d05 268787f3 59c4752e 05100201 00000000 000005ac
Nov/10/2016 09:04:55 ipsec,debug,packet 247b2e3d fa1c5072 6a14b2cc 23055e02 40e0133e c416baf2 4e25f06f d2e21d4a
Nov/10/2016 09:04:55 ipsec,debug,packet bcf084b9 e7aafc55 bf1ee4ad 5d2b610a 6d3b8c39 d0145f30 109f09dd c1c86459
Nov/10/2016 09:04:55 ipsec,debug,packet 5c3d7e45 add10ee6 a200ae49 abea26ee 6ac93ae8 c200e286 bd18d576 cde7a204
Nov/10/2016 09:04:55 ipsec,debug,packet 27f66d4c 53f02d7d dd24aa7b 4bf89006 1e0ecf58 a8071b33 fce14545 ab3f7fa5
Nov/10/2016 09:04:55 ipsec,debug,packet 900bcd9d aaff1291 90c0e3f8 5eb03edc d1d1d4a3 8b6bfd9a be3fca80 9676cc8a
Nov/10/2016 09:04:55 ipsec,debug,packet 7e28b228 f849dab2 0e5e5ad4 89791951 c6894dd8 06aa5f8d b7062385 e5e6e58f
Nov/10/2016 09:04:55 ipsec,debug,packet efc301c7 a91e6663 e96f06ba 5b7110aa 378b6446 b990452a 180d409b a9fc2d95
Nov/10/2016 09:04:55 ipsec,debug,packet 910b683e 7a26e256 c4a2dcd8 f89ce1f4 df187e81 605b07ad 32f8e30b 5c70f07e
Nov/10/2016 09:04:55 ipsec,debug,packet ce35391a 9c71e492 6ebb2547 695c4503 b6dc7957 827b3ec2 2ce3dda2 e7a15322
Nov/10/2016 09:04:55 ipsec,debug,packet 94c7e3a0 15d17af1 02956226 19161167 fc4decec 8680ece2 71c0d741 665303e8
Nov/10/2016 09:04:55 ipsec,debug,packet b1567f8c c0ec556e 60d3c81b 76b60cc7 bf49525f 3cf43df2 a156ad80 d14f73e2
Nov/10/2016 09:04:55 ipsec,debug,packet 950e50c3 078089fc 7a7ffe8b 34c80289 5e8fd2a5 a7caba03 f2294f70 3e7f5d12
Nov/10/2016 09:04:55 ipsec,debug,packet bbab5528 57f2dd73 31af2997 0fcfd455 05cdf30f d73e89f1 096129fa 23712fc8
Nov/10/2016 09:04:55 ipsec,debug,packet e27e18dc 62e93c23 67f30f40 94b17ec5 fd023877 c70e759c a3319e26 d48ce99c
Nov/10/2016 09:04:55 ipsec,debug,packet c82d348d 4b5ecc1f 146a8a91 a1b08a0a fd90f11a cb32d163 03e8cd67 24b71a43
Nov/10/2016 09:04:55 ipsec,debug,packet 56051e8e efba24c9 2e5a4999 6eb869db bb8ada7d 3f3369ca 3924ed46 b98778f8
Nov/10/2016 09:04:55 ipsec,debug,packet cb0f7d7b 7e4ec848 cd220fca 439fe324 58f339f0 16336814 2fac6922 a8d79e9a
Nov/10/2016 09:04:55 ipsec,debug,packet dcd9965d 20303a73 939bf61f ebd2fb73 84930a22 f4f5864b bfe38ed1 6dfa1a87
Nov/10/2016 09:04:55 ipsec,debug,packet 3bd8d6af 1741947a fdbb095a e8b44892 97b657b0 bc544def 2d7a261f b9f0f612
Nov/10/2016 09:04:55 ipsec,debug,packet 95579acf 761b00df 73dddf87 94c89162 e917888e f5ec5138 90d1e87f 30a3b6f3
Nov/10/2016 09:04:55 ipsec,debug,packet b370c1d5 5575b6e6 2d032ae5 eaba2dd9 0e5d654a 1bb77f59 b7a01316 78d845ff
Nov/10/2016 09:04:55 ipsec,debug,packet 62d2401a 3b66904c 428c2780 788b53e7 7ad31766 9b9ca040 0a84c67a 1ad93cd5
Nov/10/2016 09:04:55 ipsec,debug,packet 35ce380d 96a0f910 8e18d054 30f07f0b 84ae17f2 4451715d 34f2d18b 423b03a5
Nov/10/2016 09:04:55 ipsec,debug,packet cc01524c 5dde652f 407c8e8a fd9a1fbf f3b9ed4a 48037f3a 74c21f24 a3fe2ebd
Nov/10/2016 09:04:55 ipsec,debug,packet 9bfec8ab ea5a831d ee00e2f9 25f20a2d 626fc808 341a09b2 c051faf4 6d6e61b9
Nov/10/2016 09:04:55 ipsec,debug,packet 85b49154 59d5febd 9a5144f8 e4c459fb 087ceb14 b1d7e442 35735e8c ea871b7d
Nov/10/2016 09:04:55 ipsec,debug,packet ec4fc76d 91ee595d 0eae5528 c769ee22 461eb94c 2b9bab57 49896127 49b75f14
Nov/10/2016 09:04:55 ipsec,debug,packet ad327e84 2ed95bbc 6427f85a ecc2a227 9c6e7061 6ad0077e 5d04bf4f d949d95d
Nov/10/2016 09:04:55 ipsec,debug,packet e97bcde3 d88ef6a3 fcd1c31e f03ac63d 9367be39 7a796498 b6aa7185 26b35f82
Nov/10/2016 09:04:55 ipsec,debug,packet 2b3d84b3 9a3a358d 32467a2e 4f63a329 36ed113a 40a3da20 d8d7f238 eba89560
Nov/10/2016 09:04:55 ipsec,debug,packet 7d903aee d1cb3cf9 d03d662a 093df4aa 53252342 fda90c06 83d70fbd 9567fc09
Nov/10/2016 09:04:55 ipsec,debug,packet 383f6fb6 8c514b5e c95112b7 c1ef4143 b671cb9e e92bf0df 9db179d8 0a1f6ae5
Nov/10/2016 09:04:55 ipsec,debug,packet 26ac83d2 fe8ab4ed 4d105ffc cb84e9f7 5867830a 355c6de2 229690a6 ea0c1995
Nov/10/2016 09:04:55 ipsec,debug,packet 58fc2589 496fda70 ee5898a5 10794aa5 7879577e e6c98192 74b29cd9 45ec65b3
Nov/10/2016 09:04:55 ipsec,debug,packet a9190a8d d02f5d1f 23633656 30be110b 16bead19 041767d2 a19332b1 1e1b6367
Nov/10/2016 09:04:55 ipsec,debug,packet e4b12d3d faaf5caa fa77f40f eab85675 d8d74d11 0bd4b097 d6bc140b 626ef065
Nov/10/2016 09:04:55 ipsec,debug,packet f57fb183 b2e0cb69 57e8eb6c eae8a654 2d6bb125 65e99412 7084bb36 04afd3ae
Nov/10/2016 09:04:55 ipsec,debug,packet 3143e4ed d895f264 24016fb9 657a86ca 7adcdd24 ee9c45ef 5df51533 e526b03d
Nov/10/2016 09:04:55 ipsec,debug,packet 689a20d2 d2205839 2477f797 4115eba0 0920a8d1 306471c0 52809bba 2e983c1d
Nov/10/2016 09:04:55 ipsec,debug,packet b14f4d7b bf00c09e abd4830b 66de6a42 b20b7164 884a244a d732a48a fea3edf1
Nov/10/2016 09:04:55 ipsec,debug,packet 6e7d0843 5eb65d58 c77bd9f7 34dc12aa e9a3def5 196de3c9 2a4a201e 44eccc54
Nov/10/2016 09:04:55 ipsec,debug,packet 399f076f 44d07d91 dcf9865e 12ac2029 2bfb8d90 4a19faf7 6abff2a4 a7a3d2f5
Nov/10/2016 09:04:55 ipsec,debug,packet c9d65a60 4efa3472 e7c02b90 d722ab04 4344d986 5b866920 317c6aa3 75080b3d
Nov/10/2016 09:04:55 ipsec,debug,packet ee62ca74 bae04f06 fbbbad5e 25f90c88 77103dcd 94ad0007 6b3f930b 6aed3e24
Nov/10/2016 09:04:55 ipsec,debug,packet 99994357 7b4346fb 8b42035c 4ddb672b
Nov/10/2016 09:04:55 ipsec,debug resent phase1 packet 192.168.100.1[4500]<=>172.16.3.1[4500] 95e3a174948b0d05:268787f359c4752e
Nov/10/2016 09:04:56 ipsec,debug,packet KA: 192.168.100.1[4500]->172.16.3.1[4500]
Nov/10/2016 09:04:56 ipsec,debug,packet sockname 192.168.100.1[4500]
Nov/10/2016 09:04:56 ipsec,debug,packet send packet from 192.168.100.1[4500]
Nov/10/2016 09:04:56 ipsec,debug,packet send packet to 172.16.3.1[4500]
Nov/10/2016 09:04:56 ipsec,debug,packet src4 192.168.100.1[4500]
Nov/10/2016 09:04:56 ipsec,debug,packet dst4 172.16.3.1[4500]
Nov/10/2016 09:04:56 ipsec,debug,packet 1 times of 1 bytes message will be sent to 172.16.3.1[4500]
Nov/10/2016 09:04:56 ipsec,debug,packet ff
Anyone would have any ideas?
Settings on Checkpoint are likely to be correct, since we use the same setup with other dynamic interoperable devices (checkpoint 1100s) successfully, we just want to see if mikrotik would be able to do the same job.
Are you successfully connect devices?
