IPSec VPN with PSK & RSA Certificate Authentication
I’m trying to set up a RouterOS VPN client for an IPSec VPN that uses PSK Authentication for the Client → Server path, and Certificate auth for the Server → Client direction. Is it possible with RouterOS?
The Server Certificate is installed in System/Certificates, NTP is sync and the certificate is trusted and valid.
I configured PSK AuthType in Ipsec-Identities, but the Server is trying to do an RSA Auth and it fails because the RouterOS client is expecting also a PSK Auth from the server.
I have following logs at the Client:
ipsec requested auth method: RSA
ipsec,error requested auth method does not match config
Server Side:
received packet: from {$IP_CLIENT}[4500] to {$VPNGW}[4500] (288 bytes)
parsed INFORMATIONAL request 2 [ N(AUTH_FAILED) ]
I have a lot of StrongSwan clients do work with following config:
root@vpnclient:~# cat /etc/ipsec.conf
conn %default
ikelifetime=60m
keylife=20m
rekeymargin=3m
keyingtries=%forever
keyexchange=ikev2
auto=route
auto=start
compress=no
type=tunnel
fragmentation=yes
forceencaps=yes
ike=aes128-sha256-ecp256!
esp=aes256gcm128!
dpdaction=restart
dpddelay=30s
dpdtimeout=150s
closeaction=restart
conn asdf
leftsourceip=%config
right={$VPNGW}
rightsubnet=10.2.0.0/16
rightcert=/etc/ipsec.d/server.pem
leftauth=secret
leftid=@{$MY_ID}
esp=aes256gcm128!
The Complete logs and IPSec config are attached to this post.
Thank you!
ipsec_config.txt (1.41 KB)
logs.txt (5.78 KB)
