RB411GL was upgraded to 5.26 from 5.24. Following the upgrade CPU is 100% all the time. Error log shows repeating message:
echo: ipsec,warning,critical libipsec failed pfkey open Address family not supported by protocol
Tried a /reset-config and reprogramed it and it's still doing the same thing
[admin@###-###_###] > export compact
dec/16/2014 07:59:56 by RouterOS 5.26
software id = ####-####
add l2mtu=1526 name=Local
/interface wireless
set 0 band=5ghz-a/n channel-width=20/40mhz-ht-below country=canada disabled=no
frequency=5320 frequency-mode=regulatory-domain ht-rxchains=0,1
ht-txchains=0,1 hw-retries=15 l2mtu=2290 max-station-count=5 mode=ap-bridge
nv2-cell-radius=20 radio-name=###DPD ssid=###-### tdma-period-size=4
tx-power=19 tx-power-mode=card-rates wireless-protocol=nv2
/interface wireless nstreme
set wlan1 disable-csma=yes framer-policy=dynamic-size
#error exporting /ip ipsec proposal
/queue simple
add limit-at=1586k/3600k max-limit=1586k/3600k name="##### #####"
target-addresses=###.###.###.89/32
/snmp community
set [ find default=yes ] addresses=###.###.36.0/23
add addresses=###.###.36.0/23 name=#########01
add bridge=Local interface=wlan1
add bridge=Local interface=ether1
add address=###.###.###.108/26 interface=Local
set enabled=no
#error exporting /ip ipsec peer
#error exporting /ip ipsec policy
/ip neighbor discovery
set wlan1 disabled=yes
add distance=1 dst-address=###.###.###.0/26 gateway=###.###.###.120
add distance=1 dst-address=###.###.###.128/26 gateway=###.###.###.120
add distance=1 dst-address=###.###.2.30/32 gateway=###.###.###.120
add distance=1 dst-address=###.###.36.0/23 gateway=###.###.###.102
add comment="For BW Testing" distance=1 dst-address=###.###.###.230/32 gateway=
###.###.###.121
#error
/snmp
set contact="#############@#########.ca ###-###-####" enabled=yes location=
"86 Ch" trap-community=#########01 trap-target=
###.###.36.6
/system clock
set time-zone-name=America/Toronto
/system identity
set name=###-######
/system ntp client
set enabled=yes mode=unicast primary-ntp=###.###.###.121 secondary-ntp=###.###.###.101
/system scheduler
add interval=3d name=backup on-event=backup policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api
start-date=apr/30/2013 start-time=18:19:44
/system script
add name=backup policy=
source="/export file=([/system identity get name] . "-" . \\r
\n[:pick [/system clock get date] 7 11] . [:pick [/system clock get date] 0
3] . [:pick [/system clock get date] 4 6]); \\r
\n/tool e-mail send to="backup@######.#########.ca" subject=([/system identity
_get name] . " Backup " . \\r
\n[/system clock get date]) file=([/system identity get name] . "-" . [:pi
ck [/system clock get date] 7 11] . \\r
\n[:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6
] . ".rsc"); :delay 10; \\r
\n/file rem [/file find name=([/system identity get name] . "-" . [:pick [
] . ".rsc")]; \\r
\n:log info ("System Backup emailed at " . [/sys cl get time] . " " . [/
sys cl get date])"
/tool e-mail
set address=###.###.2.30 from=<###-######@#########.###>
/tool graphing
set store-every=24hours
/tool graphing interface
add allow-address=###.###.36.0/23
/tool graphing queue
/tool graphing resource
(28904 messages discarded)
ed by protocol
