Ipsec with destination 0.0.0.0/0 and local lan disconnecting
I would to configure Mikrotik IPSEC, to forward all local subnet throught remote site, so created Ip Ipsec Policy:
/ip ipsec policy
add action=none dst-address=192.168.5.0/24 src-address=192.168.5.0/24
add action=none dst-address=10.11.0.0/20 src-address=10.11.0.0/20
add dst-address=0.0.0.0/0 peer=Remote_Router proposal=Remote_Router sa-dst-address=x.x.x.30 \
    sa-src-address=x.x.x.122 src-address=192.168.5.0/24 tunnel=yes
add dst-address=0.0.0.0/0 level=unique peer=Remote_Router proposal=Remote_Router sa-dst-address=\
    x.x.x.30 sa-src-address=x.x.x.122 src-address=10.11.0.0/20 tunnel=yes
and then configured NAT:
add action=accept chain=srcnat dst-address=0.0.0.0/0 src-address=192.168.5.0/24
add action=accept chain=srcnat dst-address=0.0.0.0/0 src-address=10.11.0.0/20
add action=masquerade chain=srcnat out-interface=sfp1
The problem, I every couple of seconds loose connectivity on all computers in 192.168.5.0 lan, pings from mikrotik to local lan looks like:
[admin@Mikrotik] > ping 192.168.5.71
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.5.71                               56 128 0ms
    1 192.168.5.71                               56 128 0ms
    2 192.168.5.71                               56 128 0ms
    3 192.168.5.71                               56 128 0ms
    4 192.168.5.71                               56 128 0ms
    5 192.168.5.71                               56 128 0ms
    6 192.168.5.71                               56 128 0ms
    7 192.168.5.71                               56 128 0ms
    8 192.168.5.71                               56 128 0ms
    9 192.168.5.71                               56 128 0ms
   10 192.168.5.71                               56 128 0ms
   11 192.168.5.71                               56 128 0ms
   12 192.168.5.71                               56 128 0ms
   13 192.168.5.71                               56 128 0ms
   14 192.168.5.71                               56 128 0ms
   15 192.168.5.71                               56 128 0ms
   16 192.168.5.71                               56 128 0ms
   17 192.168.5.71                               56 128 0ms
   18 192.168.5.71                               56 128 0ms
   19 192.168.5.71                                            timeout
    sent=20 received=19 packet-loss=5% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
   20 192.168.5.71                                            timeout
   21 192.168.5.71                                            timeout
   22 192.168.5.71                                            timeout
   23 192.168.5.71                                            timeout
   24 192.168.5.71                                            timeout
   25 192.168.5.71                                            timeout
   26 192.168.5.71                                            timeout
   27 192.168.5.71                                            timeout
   28 192.168.5.71                                            timeout
   29 192.168.5.71                                            timeout
   30 192.168.5.71                                            timeout
   31 192.168.5.71                                            timeout
   32 192.168.5.71                                            timeout
   33 192.168.5.71                                            timeout
   34 192.168.5.71                                            timeout
   35 192.168.5.71                                            timeout
   36 192.168.5.71                                            timeout
   37 192.168.5.71                                            timeout
   38 192.168.5.71                               56 128 0ms
   39 192.168.5.71                               56 128 0ms
    sent=40 received=21 packet-loss=47% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
   61 192.168.5.71                               56 128 0ms
   62 192.168.5.71                               56 128 0ms
   63 192.168.5.71                               56 128 0ms
   64 192.168.5.71                               56 128 0ms
   65 192.168.5.71                               56 128 0ms
   66 192.168.5.71                               56 128 0ms
   67 192.168.5.71                               56 128 0ms
   68 192.168.5.71                               56 128 0ms
   69 192.168.5.71                               56 128 0ms
   70 192.168.5.71                               56 128 0ms
   71 192.168.5.71                               56 128 0ms
   72 192.168.5.71                               56 128 0ms
   73 192.168.5.71                               56 128 0ms
   74 192.168.5.71                               56 128 0ms
   75 192.168.5.71                               56 128 0ms
    sent=76 received=36 packet-loss=52% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
Problem resolved, was not related to mikrotik config.
