IPSec Xauth PSK client-to-site?
Hello
I have the following details from the Cisco vpn
IPSec Xauth PSK
ip: x.x.x.x
group: groupID
secret: Pass2
user: user1
pass: pass1
I can set this up fine on my phone and it connects easily.
I tried to connect my mikrorik router as a client to the cisco vpn and route all the mikrotik clients traffic through this vpn.
I enabled ipsec logging and this is the error i get
here is the ipsec config on the mikrotik
[admin@MikroTik] /ip ipsec peer> print
Flags: X - disabled, D - dynamic, R - responder
 0 X   address=x.x.x.x/32 local-address=192.168.y.y(wan IP)
       auth-method=pre-shared-key-xauth secret="Pass2"
       xauth-login="user1" xauth-password="pass1"
       generate-policy=port-strict policy-template-group=default
       exchange-mode=main mode-config=request-only send-initial-contact=yes
       nat-traversal=yes proposal-check=obey
       compatibility-options=skip-peer-id-validation hash-algorithm=sha1
       enc-algorithm=aes-256,aes-192,aes-128,3des dh-group=modp1024
       lifetime=1d dpd-interval=2m dpd-maximum-failures=5
[admin@MikroTik] > ip ipsec proposal print
Flags: X - disabled, * - default
 0  * name="default" auth-algorithms=sha1,md5
      enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc,3des lifetime=30m
      pfs-group=modp1024
 1    name="proposal1" auth-algorithms=sha1
      enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc,3des lifetime=0s
      pfs-group=none
mikrotik wan interface has not a public ip(192.168.y.y), its located after a NAT router.
Can this be done this way?
Anyone had luck with this type of configuration.
I have read the other topics in here about IPSec Xauth PSK on cisco but they provide no final conclusion if it is supported or not.
http://forum.mikrotik.com/t/cisco-vpn-client-support-w-psk-xauth-native-on-routeros/84310/1
i’m bumping this once again
Anyone has any idea if this can be done?
does ROS support IPSec Xauth PSK client-to-site with a cisco router?
Post full IPsec debug logs. If I recall correctly, you have to use my-id=key-id when connecting to cisco XAuth server.
# mar/02/2019 00:22:06 by RouterOS 6.42.12
/ip ipsec policy group
set [ find default=yes ] name=groupID
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512,sha256,sha1,md5 \
    enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,3des pfs-group=none
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc,aes-192-cbc name=\
    proposal-H
/ip ipsec peer
add address=ciscoIP.10/32 auth-method=pre-shared-key-xauth \
    compatibility-options=skip-peer-id-validation dh-group="ecp256,ecp384,ecp5\
    21,ec2n185,ec2n155,modp8192,modp6144,modp4096,modp3072,modp2048,modp1536,m\
    odp1024,modp768" disabled=yes enc-algorithm="aes-256,camellia-256,aes-192,\
    camellia-192,aes-128,camellia-128,3des,blowfish,des" exchange-mode=\
    main-l2tp hash-algorithm=md5 my-id=key-id nat-traversal=no \
    proposal-check=claim secret=Pass2 send-initial-contact=no \
    xauth-login=user1 xauth-password=pass1
log
# mar/ 2/2019  0:12:51 by RouterOS 6.42.12
mar/02 00:12:16 ipsec,debug ===
mar/02 00:12:16 ipsec,info initiate new phase 1 (Identity Protection): MikrotikIP.241[500]<=>ciscoIP.10[500]
mar/02 00:12:16 ipsec,debug new cookie:
mar/02 00:12:16 ipsec,debug 8d8ce4832f371fcb
mar/02 00:12:16 ipsec,debug add payload of len 4592, next type 13
mar/02 00:12:16 ipsec,debug add payload of len 8, next type 13
mar/02 00:12:16 ipsec,debug add payload of len 16, next type 13
mar/02 00:12:16 ipsec,debug add payload of len 16, next type 0
mar/02 00:12:16 ipsec,debug 4676 bytes from MikrotikIP.241[500] to ciscoIP.10[500]
mar/02 00:12:16 ipsec,debug 1 times of 4676 bytes message will be sent to ciscoIP.10[500]
mar/02 00:12:16 ipsec,debug,packet 8d8ce483 2f371fcb 00000000 00000000 01100200 00000000 00001244 0d0011f4
mar/02 00:12:16 ipsec,debug,packet 00000001 00000001 000011e8 01010075 03000028 01010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0100 8003fde9 80020001 80040015 03000028 02010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e0100 8003fde9 80020001 80040014
mar/02 00:12:16 ipsec,debug,packet 03000028 03010000 800b0001 000c0004 00015180 80010007 800e0100 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040013 03000028 04010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e0100 8003fde9 80020001 80040004 03000028 05010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0100 8003fde9 80020001 80040003 03000028 06010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e0100 8003fde9 80020001 80040012
mar/02 00:12:16 ipsec,debug,packet 03000028 07010000 800b0001 000c0004 00015180 80010007 800e0100 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040011 03000028 08010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e0100 8003fde9 80020001 80040010 03000028 09010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0100 8003fde9 80020001 8004000f 03000028 0a010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e0100 8003fde9 80020001 8004000e
mar/02 00:12:16 ipsec,debug,packet 03000028 0b010000 800b0001 000c0004 00015180 80010007 800e0100 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040005 03000028 0c010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e0100 8003fde9 80020001 80040002 03000028 0d010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0100 8003fde9 80020001 80040001 03000028 0e010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0100 8003fde9 80020001 80040015
mar/02 00:12:16 ipsec,debug,packet 03000028 0f010000 800b0001 000c0004 00015180 80010008 800e0100 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040014 03000028 10010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e0100 8003fde9 80020001 80040013 03000028 11010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e0100 8003fde9 80020001 80040004 03000028 12010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0100 8003fde9 80020001 80040003
mar/02 00:12:16 ipsec,debug,packet 03000028 13010000 800b0001 000c0004 00015180 80010008 800e0100 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040012 03000028 14010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e0100 8003fde9 80020001 80040011 03000028 15010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e0100 8003fde9 80020001 80040010 03000028 16010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0100 8003fde9 80020001 8004000f
mar/02 00:12:16 ipsec,debug,packet 03000028 17010000 800b0001 000c0004 00015180 80010008 800e0100 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 8004000e 03000028 18010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e0100 8003fde9 80020001 80040005 03000028 19010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e0100 8003fde9 80020001 80040002 03000028 1a010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0100 8003fde9 80020001 80040001
mar/02 00:12:16 ipsec,debug,packet 03000028 1b010000 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040015 03000028 1c010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e00c0 8003fde9 80020001 80040014 03000028 1d010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e00c0 8003fde9 80020001 80040013 03000028 1e010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9 80020001 80040004
mar/02 00:12:16 ipsec,debug,packet 03000028 1f010000 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040003 03000028 20010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e00c0 8003fde9 80020001 80040012 03000028 21010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e00c0 8003fde9 80020001 80040011 03000028 22010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9 80020001 80040010
mar/02 00:12:16 ipsec,debug,packet 03000028 23010000 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 8004000f 03000028 24010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e00c0 8003fde9 80020001 8004000e 03000028 25010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e00c0 8003fde9 80020001 80040005 03000028 26010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9 80020001 80040002
mar/02 00:12:16 ipsec,debug,packet 03000028 27010000 800b0001 000c0004 00015180 80010007 800e00c0 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040001 03000028 28010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e00c0 8003fde9 80020001 80040015 03000028 29010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e00c0 8003fde9 80020001 80040014 03000028 2a010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e00c0 8003fde9 80020001 80040013
mar/02 00:12:16 ipsec,debug,packet 03000028 2b010000 800b0001 000c0004 00015180 80010008 800e00c0 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040004 03000028 2c010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e00c0 8003fde9 80020001 80040003 03000028 2d010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e00c0 8003fde9 80020001 80040012 03000028 2e010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e00c0 8003fde9 80020001 80040011
mar/02 00:12:16 ipsec,debug,packet 03000028 2f010000 800b0001 000c0004 00015180 80010008 800e00c0 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040010 03000028 30010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e00c0 8003fde9 80020001 8004000f 03000028 31010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e00c0 8003fde9 80020001 8004000e 03000028 32010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e00c0 8003fde9 80020001 80040005
mar/02 00:12:16 ipsec,debug,packet 03000028 33010000 800b0001 000c0004 00015180 80010008 800e00c0 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040002 03000028 34010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e00c0 8003fde9 80020001 80040001 03000028 35010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0080 8003fde9 80020001 80040015 03000028 36010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e0080 8003fde9 80020001 80040014
mar/02 00:12:16 ipsec,debug,packet 03000028 37010000 800b0001 000c0004 00015180 80010007 800e0080 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040013 03000028 38010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e0080 8003fde9 80020001 80040004 03000028 39010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0080 8003fde9 80020001 80040003 03000028 3a010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e0080 8003fde9 80020001 80040012
mar/02 00:12:16 ipsec,debug,packet 03000028 3b010000 800b0001 000c0004 00015180 80010007 800e0080 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040011 03000028 3c010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e0080 8003fde9 80020001 80040010 03000028 3d010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0080 8003fde9 80020001 8004000f 03000028 3e010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010007 800e0080 8003fde9 80020001 8004000e
mar/02 00:12:16 ipsec,debug,packet 03000028 3f010000 800b0001 000c0004 00015180 80010007 800e0080 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040005 03000028 40010000 800b0001 000c0004 00015180 80010007
mar/02 00:12:16 ipsec,debug,packet 800e0080 8003fde9 80020001 80040002 03000028 41010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010007 800e0080 8003fde9 80020001 80040001 03000028 42010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0080 8003fde9 80020001 80040015
mar/02 00:12:16 ipsec,debug,packet 03000028 43010000 800b0001 000c0004 00015180 80010008 800e0080 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040014 03000028 44010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e0080 8003fde9 80020001 80040013 03000028 45010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e0080 8003fde9 80020001 80040004 03000028 46010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0080 8003fde9 80020001 80040003
mar/02 00:12:16 ipsec,debug,packet 03000028 47010000 800b0001 000c0004 00015180 80010008 800e0080 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040012 03000028 48010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e0080 8003fde9 80020001 80040011 03000028 49010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e0080 8003fde9 80020001 80040010 03000028 4a010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0080 8003fde9 80020001 8004000f
mar/02 00:12:16 ipsec,debug,packet 03000028 4b010000 800b0001 000c0004 00015180 80010008 800e0080 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 8004000e 03000028 4c010000 800b0001 000c0004 00015180 80010008
mar/02 00:12:16 ipsec,debug,packet 800e0080 8003fde9 80020001 80040005 03000028 4d010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010008 800e0080 8003fde9 80020001 80040002 03000028 4e010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010008 800e0080 8003fde9 80020001 80040001
mar/02 00:12:16 ipsec,debug,packet 03000024 4f010000 800b0001 000c0004 00015180 80010005 8003fde9 80020001
mar/02 00:12:16 ipsec,debug,packet 80040015 03000024 50010000 800b0001 000c0004 00015180 80010005 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040014 03000024 51010000 800b0001 000c0004 00015180 80010005
mar/02 00:12:16 ipsec,debug,packet 8003fde9 80020001 80040013 03000024 52010000 800b0001 000c0004 00015180
mar/02 00:12:16 ipsec,debug,packet 80010005 8003fde9 80020001 80040004 03000024 53010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010005 8003fde9 80020001 80040003 03000024 54010000 800b0001
mar/02 00:12:16 ipsec,debug,packet 000c0004 00015180 80010005 8003fde9 80020001 80040012 03000024 55010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010005 8003fde9 80020001 80040011 03000024
mar/02 00:12:16 ipsec,debug,packet 56010000 800b0001 000c0004 00015180 80010005 8003fde9 80020001 80040010
mar/02 00:12:16 ipsec,debug,packet 03000024 57010000 800b0001 000c0004 00015180 80010005 8003fde9 80020001
mar/02 00:12:16 ipsec,debug,packet 8004000f 03000024 58010000 800b0001 000c0004 00015180 80010005 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 8004000e 03000024 59010000 800b0001 000c0004 00015180 80010005
mar/02 00:12:16 ipsec,debug,packet 8003fde9 80020001 80040005 03000024 5a010000 800b0001 000c0004 00015180
mar/02 00:12:16 ipsec,debug,packet 80010005 8003fde9 80020001 80040002 03000024 5b010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010005 8003fde9 80020001 80040001 03000028 5c010000 800b0001
mar/02 00:12:16 ipsec,debug,packet 000c0004 00015180 80010003 800e0080 8003fde9 80020001 80040015 03000028
mar/02 00:12:16 ipsec,debug,packet 5d010000 800b0001 000c0004 00015180 80010003 800e0080 8003fde9 80020001
mar/02 00:12:16 ipsec,debug,packet 80040014 03000028 5e010000 800b0001 000c0004 00015180 80010003 800e0080
mar/02 00:12:16 ipsec,debug,packet 8003fde9 80020001 80040013 03000028 5f010000 800b0001 000c0004 00015180
mar/02 00:12:16 ipsec,debug,packet 80010003 800e0080 8003fde9 80020001 80040004 03000028 60010000 800b0001
mar/02 00:12:16 ipsec,debug,packet 000c0004 00015180 80010003 800e0080 8003fde9 80020001 80040003 03000028
mar/02 00:12:16 ipsec,debug,packet 61010000 800b0001 000c0004 00015180 80010003 800e0080 8003fde9 80020001
mar/02 00:12:16 ipsec,debug,packet 80040012 03000028 62010000 800b0001 000c0004 00015180 80010003 800e0080
mar/02 00:12:16 ipsec,debug,packet 8003fde9 80020001 80040011 03000028 63010000 800b0001 000c0004 00015180
mar/02 00:12:16 ipsec,debug,packet 80010003 800e0080 8003fde9 80020001 80040010 03000028 64010000 800b0001
mar/02 00:12:16 ipsec,debug,packet 000c0004 00015180 80010003 800e0080 8003fde9 80020001 8004000f 03000028
mar/02 00:12:16 ipsec,debug,packet 65010000 800b0001 000c0004 00015180 80010003 800e0080 8003fde9 80020001
mar/02 00:12:16 ipsec,debug,packet 8004000e 03000028 66010000 800b0001 000c0004 00015180 80010003 800e0080
mar/02 00:12:16 ipsec,debug,packet 8003fde9 80020001 80040005 03000028 67010000 800b0001 000c0004 00015180
mar/02 00:12:16 ipsec,debug,packet 80010003 800e0080 8003fde9 80020001 80040002 03000028 68010000 800b0001
mar/02 00:12:16 ipsec,debug,packet 000c0004 00015180 80010003 800e0080 8003fde9 80020001 80040001 03000024
mar/02 00:12:16 ipsec,debug,packet 69010000 800b0001 000c0004 00015180 80010001 8003fde9 80020001 80040015
mar/02 00:12:16 ipsec,debug,packet 03000024 6a010000 800b0001 000c0004 00015180 80010001 8003fde9 80020001
mar/02 00:12:16 ipsec,debug,packet 80040014 03000024 6b010000 800b0001 000c0004 00015180 80010001 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040013 03000024 6c010000 800b0001 000c0004 00015180 80010001
mar/02 00:12:16 ipsec,debug,packet 8003fde9 80020001 80040004 03000024 6d010000 800b0001 000c0004 00015180
mar/02 00:12:16 ipsec,debug,packet 80010001 8003fde9 80020001 80040003 03000024 6e010000 800b0001 000c0004
mar/02 00:12:16 ipsec,debug,packet 00015180 80010001 8003fde9 80020001 80040012 03000024 6f010000 800b0001
mar/02 00:12:16 ipsec,debug,packet 000c0004 00015180 80010001 8003fde9 80020001 80040011 03000024 70010000
mar/02 00:12:16 ipsec,debug,packet 800b0001 000c0004 00015180 80010001 8003fde9 80020001 80040010 03000024
mar/02 00:12:16 ipsec,debug,packet 71010000 800b0001 000c0004 00015180 80010001 8003fde9 80020001 8004000f
mar/02 00:12:16 ipsec,debug,packet 03000024 72010000 800b0001 000c0004 00015180 80010001 8003fde9 80020001
mar/02 00:12:16 ipsec,debug,packet 8004000e 03000024 73010000 800b0001 000c0004 00015180 80010001 8003fde9
mar/02 00:12:16 ipsec,debug,packet 80020001 80040005 03000024 74010000 800b0001 000c0004 00015180 80010001
mar/02 00:12:16 ipsec,debug,packet 8003fde9 80020001 80040002 00000024 75010000 800b0001 000c0004 00015180
mar/02 00:12:16 ipsec,debug,packet 80010001 8003fde9 80020001 80040001 0d00000c 09002689 dfd6b712 0d000014
mar/02 00:12:16 ipsec,debug,packet 12f5f28c 457168a9 702d9fe2 74cc0100 00000014 afcad713 68a1f1c9 6b8696fc
mar/02 00:12:16 ipsec,debug,packet 77570100
mar/02 00:12:16 ipsec sent phase1 packet MikrotikIP.241[500]<=>ciscoIP.10[500] 8d8ce4832f371fcb:0000000000000000
mar/02 00:12:16 ipsec,debug ===== received 52 bytes from ciscoIP.10[500] to MikrotikIP.241[500]
mar/02 00:12:16 ipsec,debug,packet 8d8ce483 2f371fcb 41016a35 072a2912 0b100500 00000000 00000034 00000018
mar/02 00:12:16 ipsec,debug,packet 00000001 0100000e 0d0011f4 00000001 00000001
mar/02 00:12:16 ipsec,debug receive Information.
mar/02 00:12:16 ipsec,debug begin.
mar/02 00:12:16 ipsec,debug seen nptype=11(notify) len=24
mar/02 00:12:16 ipsec,debug succeed.
mar/02 00:12:16 ipsec,debug ciscoIP.10 notify: NO-PROPOSAL-CHOSEN
mar/02 00:12:16 ipsec ciscoIP.10 fatal NO-PROPOSAL-CHOSEN notify messsage, delete phase1 handle.
mar/02 00:12:21 ipsec,debug Removing PH1...
mar/02 00:12:21 ipsec,info ISAKMP-SA deleted MikrotikIP.241[500]-ciscoIP.10[500] spi:8d8ce4832f371fcb:0000000000000000 rekey:1
mar/02 00:12:21 ipsec,debug an undead schedule has been deleted.
That would be nice to know if this would work…
At least it is not possible on opnsense/pfsense/junos…and would love to be able to share a company ipsec connection in my home LAN.
thanks this was the missing info
my-id=key-id
my-id=groupID
Hello.
Help me, please.
Can mikrotik work as a cisco vpn client (IPSec Xauth PSK)? How can this be done?
I have a similar issue, I can connect but after 1 minute, sometimes 1 minute and 20 seconds, the connection fall down and reconnect again, but never establishes more that time.
Someone knows how can I fix it?
