Ipsec
I need to conect using IPSEC
I have a MIKROTIK IPSEC with FW Check Point
This are de Parameters for the FW Check Point
Phase 1 Authentication Method Pre-shared Key(se definirá por teléfono)
Encryption Scheme IKE
Diffie-Hellman Group Group2 – 1024 bit
Encryption Algorithm 3DES
Hashing Algorithm SHA1
Main or Aggressive Mode Main
Lifetime (for renegotiation) 1440 min
Phase 2 Encapsulation (ESP or AH) ESP
Authentication Algorithm SHA1
Perfect Forward Secrecy NO PFS
Lifetime (for renegotiation) 3600 seg
Lifesize in KB (for renegotiation) n/a
Key Exchange For Subnets? Yes
Something like this:
/ip ipsec proposal
add name=checkpoint auth-algorithms=sha1 enc-algorithms=3des lifetime=3600s pfs-group=none
/ip ipsec policy
add ipsec-protocols=esp proposal=checkpoint sa-dst-address=[remote peer IP] sa-src-address=[local peer IP] dst-address=[remote protected network]:any src-address=[local protected network]:any level=require action=encrypt protocol=all
/ip ipsec peer
add address=[remote peer IP]:500 dh-group=modp1024 enc-algorithm=3des exchange-mode=main generate-policy=no hash-algorithm=sha1 lifetime=1440m auth-method=pre-shared-key secret=mySharedKey
You’re not stating what your authentication method is, the peer above assumes PSK. You’re also not stating what traffic to protect, the above assumes all IP traffic.
http://wiki.mikrotik.com/wiki/IPsec for details
any results? Anyone did ipsec between Checkpoint and Mikrotik? Is it real?
Did any of you get this resolved?
I make site-to-site IPsec from a RB1100AHx2 to a checkpoint RX60
Thank you.
