IPsubnet calculator container
Based on old work of mine I have created a simple IP Subnet Calculator html5 web container:
The source of the calculator is from:
https://github.com/jmpep/IPsubnet
The container details are at:
https://github.com/elico/ipcalc-container
To install the container you can use the next commands and then access it using http://172.17.0.3/ and if you want you can define a customized domain name for that:
/interface/bridge/add name=dockers
/ip/address/add address=172.17.0.254/24 interface=dockers
/interface/veth/add name=veth3 address=172.17.0.3/24 gateway=172.17.0.254
/interface/bridge/port add bridge=dockers interface=veth3
/container/config/set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
/container/add dns=172.17.0.254 remote-image=elicro/ipcalc:latest interface=veth3 root-dir=disk1/ipcalc  start-on-boot=yes
