IPTV limiting wifi bandwith
Hi, i just got my fiber optics line installed at home and i’m having a small problem with the Wifi.
I own a Mikrotik RB2011UAS-2HnD, and i just got a 100Mbps (down) / 10Mbps (up) line installed.
My IPTV box is connected directly to the Mikrotik device and, when i’m watching tv, if i go to speedtest my speed is around 4Mbps (down) / 3Mbps (up).
As soon as i turn my IPTV box off, or place it in standby, i go to speedtest and my spped is around 96Mbps (down) / 9Mbps (up)
I assume that this is due to some kind of QoS.
I would like to know how can i disable this feature.
Best regards.
QoS not exist, you must add that yourself.
If you not have set anything inside, see how much your tv download when on, or disable tv internal access point… someone probably use your television ap :wink:
