I have at home this wired setup:
Some router → IPTV box
…|…|______ → computer
…|___________ → computer2
Multicasting is enabled and IPTV box kinda works… There are some problems, which annoy me.
IPTV provider suggests this setup:
simple switch ->Router ->computer
…|…|____ → computer2
…|__________ → IPTV box
That means, the IPTV box is accesed form internet not through router, but through switch, which is before router. It works both ways after I enabled multicast on the router, but there are times when service freezes, some IPTV software updates do not come throught etc. All of them are solved if I connect IPTV to switch, but that extra box annoys me a lot…
I am looking to upgrade router to hEX or hEX lite and want to ask:
Is there a simple posibility to configure it to act as a switch AND a router? I know it sounds weird, but I need that “switch” part not on the home network, but on the WAN → IPTV. I could reserve 1 port for IPTV box to be it simple.
Is it possible with hEX or hEX lite?
