IPTV Telefonica Vivo BR not connect multicast
I’ve read several messages on this forum, I’ve seen several videos on the internet about configuring the IGMP Proxy. I performed the requested settings, but the IPTV Vivo connection does not work.
Through wireshark it indicates that it makes a request at 224.0.0.251, but this IP does not appear in the IGMP Proxy MFC.
The main problem is that the TV channels appear to be active for seconds and then drop, generating a GCN11 error, which indicates there is no connectivity. Looking at the forums, everything indicated that it was a multicast problem.
Although the Vivo router demonstrates 2 vLAN (10 Internet and 20 IPTV) the bridge mode output is made in access mode. For this reason there are no VLAN configurations.
The objective is to keep the Telefonica router in bridge mode, without losing the TV.
Thank you if you can help
My configuration is:
eth1-VIVO = PPPoE (Internet) and DHCP IPTV Client
brg-CASA= LAN network
admin@MikroTik-Colchesqui] /routing/igmp-proxy> export
# 2023-09-20 18:31:08 by RouterOS 7.11.2
# software id = **ELIDED**
# model = C52iG-5HaxD2HaxD
# serial number = **ELIDED**
/routing igmp-proxy
set quick-leave=yes
/routing igmp-proxy interface
add interface=brg-CASA
add alternative-subnets=0.0.0.0/0 interface=eth1-VIVO upstream=yes
MFC Connections:
admin@MikroTik-Colchesqui] /routing/igmp-proxy> mfc/print
Flags: A - ACTIVE; D - DYNAMIC
Columns: GROUP, SOURCE, UPSTREAM-INTERFACE, ACTIVE-DOWNSTREAM-INTERFACES
 #    GROUP            SOURCE          UPSTREAM-INTERFACE  ACTIVE-D
 0 AD 239.255.255.250  192.168.15.1    eth1-VIVO           brg-CASA
 1 AD 239.255.255.250  192.168.20.21   eth1-VIVO           brg-CASA
 2 AD 239.255.255.250  192.168.20.221  eth1-VIVO           brg-CASA
 3 AD 239.255.255.250  192.168.20.244  eth1-VIVO           brg-CASA
 4 AD 239.255.255.250  192.168.20.5    eth1-VIVO           brg-CASA
 5 AD 239.130.0.0      192.168.15.1    eth1-VIVO           brg-CASA
 6 AD 239.131.0.0      192.168.15.1    eth1-VIVO           brg-CASA
 7 AD 239.255.255.250  192.168.20.4    eth1-VIVO           brg-CASA
 8 AD 239.130.1.0      192.168.15.2    *FFFFFFFF
 9 AD 239.130.2.0      192.168.15.2    *FFFFFFFF
10 AD 224.0.1.187      192.168.15.2    *FFFFFFFF
11 AD 224.0.1.60       192.168.15.2    *FFFFFFFF
12 AD 239.130.1.0      192.168.15.1    eth1-VIVO           brg-CASA
13 AD 239.130.0.0      192.168.15.2    *FFFFFFFF
14 AD 239.255.255.250  192.168.15.2    *FFFFFFFF
IP Accress
[admin@MikroTik-Colchesqui] > /ip/address/print
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
#   ADDRESS            NETWORK         INTERFACE
0   192.168.20.1/24    192.168.20.0    brg-CASA
1   192.168.15.2/24    192.168.15.0    eth1-VIVO
2   192.168.1.2/24     192.168.1.0     eth2-VIP
3 D 100.71.29.17/32    100.64.134.103  pppoe-VIP
4 D 177.170.251.25/32  187.100.231.46  pppoe-VIVO
5 D 10.77.152.65/21    10.77.152.0     eth1-VIVO
I have the same issue, were you able to solve it?
